Life Member
  1. Very nice looking combo Larry. With the ice chest mounted do you get many road dings?? Yes I do get road dings but remember I've got two big tires on back but no dings where the cooler sits. I think with your bike there's be much less chance of that happening. For comparison the width of the trikes wheels are about 48", outside to outside. My trailer is 30" wide for the body with an additional 4" per side for the fenders, so it still tucks in nicely behind the 3 wheeler. I has seen other teardrops with the fenders built inside the body thou yours looks exactly like mine. Other dimensions are - 40" height from ground to top of body, 48" body length, & a 38" tongue from center of the coupling to the front of the body. This is the company who built mine. I know there's others out there making them too. http://www.jemanufacturing.com/ Here's a couple links of those: http://www.adventureteardrops.com/index.php?option=com_content&task=blogcategory&id=68&Itemid=125 http://www.adventureteardrops.com/index.php?option=com_content&task=blogcategory&id=68&Itemid=125 http://www.rvcapitalwholesalers.com/shopRVCW/pc/configurePrd.asp?idcategory=198&idproduct=17513 Even teardrop campers if one wanted one. Lots to chose from on the web. Larry
  2. Your choice here Jack. Just to let you know I have the exact same teardrop that I've been pulling behind the trike for the last 3 years. I think either one looks good behind the RSV's.
  3. Gotta ask. What about the passengers comfort? 90% of my riding is with the Mrs. aboard. And we know if she's not happy no one is. Larry
  4. I went down that path myself. Sure was nice getting the pension and then SS later. Makes life somewhat livable again. Good luck to you on your 6 Saturdays and Sunday. Larry
  5. Or try a local hardware or Lowes or Home Depot:080402gudl_prv:
  6. counting to what? Larry
  7. Happy Anniversary Brad & Lonna. :clap2:I'm sure you'll have many more wonderfull years to share together. Yep Life does have it's ups & downs at times but its what we do to smooth that road out that makes life worth living. Larry
  8. I use and like best the gang gauges like these in the following e-bay link -- http://www.ebay.com/sch/i.html?_trksid=p5197.m570.l1313&_nkw=Synchronizer+gauges&_sacat=0 The set I have is those in the black plastic case. The feature I like about these over the others listed is that the gauges already have the restrictor valve built in so no messing around with tubes or adding valves later. Having the case is nice for transporting them well protected as well. http://i.ebayimg.com/t/Vacuum-Carburetor-Synchronizer-carb-sync-Gauge-Honda-GL-1100-1200-1500-Goldwing-/00/$(KGrHqIOKm8E5I-CrzR8BOeWf,L1C!~~_35.JPG I have a Motion Pro mercury stick as well but never use it anymore. Larry
  9. Works for me and that is good info too. Thanks for sharing. Larry
  10. Thanks for sharing this news Bill thou we surely hate to hear/see La in his present condition. While I haven't spent a lot of time with La I surely enjoyed being with him when I was in his presence, the last time at Bill's Eureka Springs rally. Like many here I envied the man for his care free traveling ways, heading off on his bike whenever it took his fancy or where the wind blew him. The first time I met La was at the Fort Collins, Colorado International Rally. Peace to you La as you'll always be remembered. God Bless Larry
  11. Deffineately a V-Star 650 engine in that article. Like Don said somebody screwed up. :rotf: Larry
  12. Glad to hear this chapter in your ordeal will soon be over and while the outcome wasn't quite as much as you wanted at least you feel it a fair one. OH ya looking forward to seeing you two blokes next year too. Peace & God Bless to you & Al. Larry
  13. Will put him in my thoughts and prayers. Larry
  14. Wonder if the BIRD is getting exited yet? LOL
  15. Maybe. Getting the bearings centered for the gear engagement and in a tightly fitted tube will be hardest part for me. We'll see. As far as welding up the exiting box I'm not sure it would last or be strong enough. Larry
  16. I was bored this afternoon so disassembled the old saw to see just what needed replacing. It's not looking good for a rebuild either unless I can fabricate up a gear box. Here's what happened when it died. Output shaft bearing seized up and then the then gear box housing broke. Newer saws don't use this type of box anymore but build it into the upper saw unit so only a cover plate is needed. You can see how thin the cast aluminum box is so it's no wonder they went with a cast in unit on the newer saws. I'll need a gear box, a couple of bearings, a seal, a shaft, and a drive pully. Parts source searching has come up with zip so far too. Larry
  17. With bad back history I'm not taking the chance. Last time I pulled a muscle I could hardly move or sit without pain for about a week. Nope not gonna do that again if it can be avoided. Larry
  18. And the winner is -- http://www.boltonhardware.com/catego...wivel-head.php After researching all I could find I felt this one matched my needs the best with the features I wanted so it's already on a truck heading here from California. Cost was an extra $25 cause I'm having it delivered curbside with a liftgate truck so I can wheel it into the garage with a dolly. At close to 200 lbs I'm not picking it up. Thanks to all for their help & suggestions. Larry
  19. That's a real back breaker to move. Hire a moving company to handle it for you. Looks like that one is made tough with lots of heavy casting. Larry
  20. I did replace the guide bearings a while back by doing just that letting the bearing house match em up. They weren't cheap either for such little things! Larry
  21. Good motor. It needs a drive pully, output shaft, seals, and bearings. Going to take too long to get parts and as old as it is may not even be available. I really need a saw asp so will buy a new one. If I can locate parts I'll fix it and sell it later depending on what it costs to repair. May cost more than its worth for all I know. Larry
  22. No problem
  23. Wrong type but thanks for the help anyhow. Larry
  24. As much as it would be nice to have a bigger garage I don't think that'll happen. I've expanded twice already over the years and running out of room. Don't think I really want to wrestle with city hall anymore either. It was a PIA getting the last addition done. Larry
