wolfrider Posted August 20, 2011 Share #1 Posted August 20, 2011 Ive got a Yamaha light bar on my 2005 RSTD. One of the driving lights got busted in it. Anyone know of an aftermarket 4 1/2" sealed beam light or replacement light I can replace it with? Yamaha said they're on back order till Oct ? Cheers, Steve Link to comment Share on other sites More sharing options...
Snaggletooth Posted August 20, 2011 Share #2 Posted August 20, 2011 I don't have a 2nd gen but I have a set of 4.5" Drag Specialty driving lights on my '84. I had read several posts in the past about different options for the 2nd gen driving lights and they all fit my DS housings. Wouldn't about any 4.5" replacement light from somewhere like NAPA or Auto Zone be a standard fit? Got to be cheaper than a Yammy light. Mike Link to comment Share on other sites More sharing options...
MikeWa Posted August 21, 2011 Share #3 Posted August 21, 2011 NAPA has sealed beams. Mike Link to comment Share on other sites More sharing options...
Preacher Dude Posted October 20, 2011 Share #4 Posted October 20, 2011 I got mine from a cycle shop here in town. 1/2 the price Yammy dealer wanted Link to comment Share on other sites More sharing options...
TheKid Posted October 20, 2011 Share #5 Posted October 20, 2011 i went with 4.5 led from northern tool and equipment. part number 127757 they fit perfect and are bright. i light them much better than oem and they match my hid. Link to comment Share on other sites More sharing options...
guns_usn_20 Posted October 29, 2011 Share #6 Posted October 29, 2011 The 4.5" lamps are commonly called PAR 36, You can get them at most auto parts stores, in a pinch Wal-mart sell's them. as tractor lamps. Jim Bell 07 RSTD Bagram AF Afghanistan 2b1ask1 Link to comment Share on other sites More sharing options...
geep Posted October 30, 2011 Share #7 Posted October 30, 2011 If you wanna replace both lights and want BRIGHT lights check out PAR 36 LED work lights...down side is big $$$$ Link to comment Share on other sites More sharing options...
ragtop69gs Posted October 30, 2011 Share #8 Posted October 30, 2011 If you wanna replace both lights and want BRIGHT lights check out PAR 36 LED work lights...down side is big $$$$ But aren't work lights a flood light? not a beam that would reach out into the darkness? Link to comment Share on other sites More sharing options...
wes0778 Posted October 30, 2011 Share #9 Posted October 30, 2011 i went with 4.5 led from northern tool and equipment. part number 127757 they fit perfect and are bright. i light them much better than oem and they match my hid. Just curious, did you take the bulbs out of the housing, or use the housings as shown on N/T's web page http://www.northerntool.com/shop/tools/product_200407598_200407598?issearch=127757 Do they create any electrical "noise" which interferes with the radios? Link to comment Share on other sites More sharing options...
a1bummer Posted November 1, 2011 Share #10 Posted November 1, 2011 But aren't work lights a flood light? not a beam that would reach out into the darkness? According to this site, they come in a flood or spot. http://www.truckntow.com/showproduct.aspx?affiliateid=10050&ProductID=25814 Link to comment Share on other sites More sharing options...
Obber Posted November 1, 2011 Share #11 Posted November 1, 2011 Tractor Supply. About $15.00 http://www.tractorsupply.com/trailers-towing/trailer-parts/trailer-lighting/trailer-light-bulbs/wagner-incandescent-sealed-beam-4411-bulb-0169498 Link to comment Share on other sites More sharing options...
FreezyRider Posted November 1, 2011 Share #12 Posted November 1, 2011 Here is a link to the ones I always used. I felt they were brighter than the ones with the cut or fluted glass. http://www.tractorsupply.com/wagner-incandescent-sealed-beam-4416-bulb-0169545?zoneMarketInfo=2-28&reqUrl=TopCategoriesDisplayView&langId=-1&storeId=10551&lbzipcode=46733&catalogId=10001&ddkey Link to comment Share on other sites More sharing options...
pofarm Posted November 27, 2011 Share #13 Posted November 27, 2011 I needed to replace one of mine. The number was a Wagner 4449. The price was 35.00 each, but the parts store didn't have any in stock. I ended up getting a pair of 4416 bulbs. They are the same beam pattern and wattage, but a higher candlepower rating, and the price was under 25.00 for the pair. They are clear lenses instead of fluted. Link to comment Share on other sites More sharing options...
Trader Posted November 27, 2011 Share #14 Posted November 27, 2011 Would it be highjacking this thread if I asked for ideas of what to use and install on a mkII> I like the look of rectangular running lights....mounted on the horn brakets????? I also like the idea of CHEAP!!!!!!! I"d love to see some pictures and ideas! Link to comment Share on other sites More sharing options...
Snaggletooth Posted November 27, 2011 Share #15 Posted November 27, 2011 Would it be highjacking this thread if I asked for ideas of what to use and install on a mkII> I like the look of rectangular running lights....mounted on the horn brakets????? I also like the idea of CHEAP!!!!!!! I"d love to see some pictures and ideas! Wally World has the "Burner" line that has several different models to choose from. I used to have the round chrome ones on my '84 before I installed the 4 1/2 inch housings. They have a model that you might like. It was a retangular light at 65 watts each with replaceable bulbs. Same watt power as I had and they are bright. About $20.00 bucks for the set. I have the upgraded stator so they mever bothered me for power drain. I think I had them before the stator but I can't remember for sure. They held up well anyway, still got em on the shelf. Mike Link to comment Share on other sites More sharing options...
dingy Posted November 28, 2011 Share #16 Posted November 28, 2011 Here is a picture of a set of Wally World units mounted to the fairing. I think they were around $25. They light up the sides of the road better than the projector lights do. Gary Link to comment Share on other sites More sharing options...
Jayceesfolly Posted November 28, 2011 Share #17 Posted November 28, 2011 Steve: Here is a photo of the rectangular ones on my 89 VR. They are mounted on the horn brackets. I bought them from Wally World and are cheap. They are plastic housings. About $20 (USD). They are 55 watt each and do a good job of lighting up the road. Jim Link to comment Share on other sites More sharing options...
wes0778 Posted November 29, 2011 Share #18 Posted November 29, 2011 Here is a link to the ones I always used. I felt they were brighter than the ones with the cut or fluted glass. http://www.tractorsupply.com/wagner-incandescent-sealed-beam-4416-bulb-0169545?zoneMarketInfo=2-28&reqUrl=TopCategoriesDisplayView&langId=-1&storeId=10551&lbzipcode=46733&catalogId=10001&ddkey I needed to replace one of mine. The number was a Wagner 4449. The price was 35.00 each, but the parts store didn't have any in stock. I ended up getting a pair of 4416 bulbs. They are the same beam pattern and wattage, but a higher candlepower rating, and the price was under 25.00 for the pair. They are clear lenses instead of fluted. From what I see they say "Off Road" on the box have you had any problems from any LEOs? BTW my passing lights are always on, but look yellow compared to the HID main light. Link to comment Share on other sites More sharing options...
spke Posted November 29, 2011 Share #19 Posted November 29, 2011 Just curious, did you take the bulbs out of the housing, or use the housings as shown on N/T's web page http://www.northerntool.com/shop/tools/product_200407598_200407598?issearch=127757 Do they create any electrical "noise" which interferes with the radios? TheKid and I are both using these lights and we both love them. (I just picked up 2 pair for another friend as well) They have more dispersion than the stock incandescants, but are quite bright and light up the sides of the road nicely. My main concern/objective for running lights is being seen and these def do that. There is no Radio interferance. The bulbs come out of the rubber housing and drop right in to the stock housing on the bike. You will need to add some spade lugs on the bare wires. I reccommend using the weatherproof type and always use dielectric grease on the connections sp!ke Link to comment Share on other sites More sharing options...
Condor Posted November 29, 2011 Share #20 Posted November 29, 2011 Steve: Here is a photo of the rectangular ones on my 89 VR. They are mounted on the horn brackets. I bought them from Wally World and are cheap. They are plastic housings. About $20 (USD). They are 55 watt each and do a good job of lighting up the road. Jim I have a similar pair in chrome on my '91 mounted the same way. And... they have hi/lo beam. Haven't looked at them closely enough to find the manufacture. Not my doing.... P.O.'s Link to comment Share on other sites More sharing options...
mm482 Posted December 2, 2011 Share #21 Posted December 2, 2011 http://www.northerntool.com/shop/too...ssearch=127757 I just ordered a set of the Northern Tool lights. Earl:big-grin-emoticon: Link to comment Share on other sites More sharing options...
Yamamike Posted January 4, 2012 Share #22 Posted January 4, 2012 But aren't work lights a flood light? not a beam that would reach out into the darkness? Not only that but you'd piss of everyone in the on-coming traffic with the wide beam. Just sayin. Link to comment Share on other sites More sharing options...
wes0778 Posted March 5, 2012 Share #23 Posted March 5, 2012 http://www.northerntool.com/shop/too...ssearch=127757 I just ordered a set of the Northern Tool lights. Earl:big-grin-emoticon: Have you installed them? What's the verdict??? Link to comment Share on other sites More sharing options...
mm482 Posted March 5, 2012 Share #24 Posted March 5, 2012 No, they are still in the box. I hope to get them put on by the end of the month. I had hip surgery on Jan 12th and I am just getting back in the work mode. I will let you know when I get them in. Earl Link to comment Share on other sites More sharing options...
Riderduke Posted March 25, 2012 Share #25 Posted March 25, 2012 i went with 4.5 led from northern tool and equipment. part number 127757 they fit perfect and are bright. i light them much better than oem and they match my hid. Hey Kid. Thanks for the info. I got them and poped them in . Very bright. Now I'v got to get a HID headlight.Which HID did you get? :mo money: Have you installed them? What's the verdict??? So far so good. very bright and easy to put in.went for a 6hr ride and no problems so far. Link to comment Share on other sites More sharing options...
