User Tag List
Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: Cold Weather/Winter Gear
  1. #1
    Join Date
    Oct 2019
    Atlanta
    GA
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Cold Weather/Winter Gear
    Good Morning Everyone!
    Lately I've seen a lot of posts where people talk about riding to work or taking rides with temps in the 40s. Apparently I'm a wimpy southerner, because once the temps drop below 60, I struggle. Granted I ride a RSTD without any kind of fairing and rarely use my windshield (which I know would help). Last night I went for a night ride and the temp was 54 degrees. Honestly, I live in atlanta and as such should be able to ride mostly year round. I want to get better at riding in the cool/cold.
    My question: What is the best cold weather gear you use? Any must have items that you can't live without in the cold? Any tricks or tips? Or am I just a wimp? Also, anyone in cold areas wear an open face helmet? I love my Bell Custom 500 and cant stand the steaming up of a full face.
    Just curious what everyone's thought/feelings are.
    Thanks,
    Sean
  2. #2
    Join Date
    Aug 2006
    Wadena
    MN
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Cold Weather/Winter Gear
    When I was still working(Retired) I would ride my RSV to work 50 miles one way from spring till fall in north central MN. Sometimes temp would be in the high 20's. I wore an old one piece snowmobile suit, insulated gloves and I would have a flip shield on my open face helmet. On the really cold days I would add a really thin facemask. I would wear those knee high all rubber boots to try and keep my feet from freezing. Stay warm
  3. #3
    Join Date
    Feb 2018
    Drums
    PA
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Sean,
    Between work and life I don't get the chance to ride as much as I would like.
    So anytime I get the opportunity I take it and that means if the temps are on the low side I bundle up.
    I have a 1st gen mkII 86, so it has a full fairing and windshield, but you still can feel the wind and cold.
    Only time I don't ride is if there is extremely windy or there is a chance of ice and/or wet leaves all over the place.
    Went for a 100+ mile ride last weekend. Temps were in the low 40's to 50's.
    I have ridden when the temperature was in the 20's.
    I wear a set of insulated brown duck coveralls, flannel shirt and insulated boots.
    Add insulated under garments depending upon the expected temperatures.
    Best recommendation is to have an outer layer that will break the wind and adjust inner layers as required.
    I use a full face modular helmet that allows the face to flip up.
    It has enough room that I can wear a knit head covering that covers everything but my eyes and nose.
    It is long enough to cover my neck both front and back.
    That along with keeping the coverall collar up and closed keeps the air off the back of my neck.
    As to fogging up, an anti-fog spray can help, but I just crack the face shield up a notch and/or open the vents on the helmet.
    The biggest problem that I personally have is with gloves.
    I have relatively small hands and too much thick insulation makes it difficult to hold the grips comfortably.
    Here again, gloves that break the wind help a lot.
    I find that I mind the colder weather as I get older.
    Never bothered me when I was younger.
    Argo
  4. Likes uncledj liked this post
  5. #4
    Join Date
    Apr 2014
    Wilmington, NC
    NC
    Post Thanks / Like
    Mentioned
    19 Post(s)
    Tagged
    0 Thread(s)
    I used to ride in the cold with a full face helmet and a ski jacket that was made with hollow fibers. It had a high collar. The cold did not penetrate that jacket at all. I still have that jacket but, alas, it must have shrunk over the years because I can't zip it up now.
    Currently, I have a heavy coat that I wore when I worked in Wisconsin. that and a full face helmet will keep my upper body warm except for my hands. Leather chaps for the legs might work.
    2007 Yamaha Royal Star Venture
    1989 Yamaha Venture Royale
    1985 Kawasaki ZN700 4cyl shaft
  6. #5
    Join Date
    Jan 2009
    Bessemer City, NC
    NC
    Post Thanks / Like
    Mentioned
    16 Post(s)
    Tagged
    0 Thread(s)
    All good advice, and you need a set of gaunlet style electric gloves (easily installed to batterry with an in-line fuse). I like the Tourmasterbrand jacket and pants which come with liners (not cheap).
    Jim aka Sylvester
    Where did all the years go? I'm trying to catch up with my father.
  7. #6
    Join Date
    Apr 2019
    Katy
    TX
    Post Thanks / Like
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    I live in Houston so the weather should be similar. I had the '06 Venture (had full fairing and lower deflectors), now I have the '18 SVTC but no lower deflectors. 55 - 65 I wear Leather Jacket, jeans and thin leather gloves. Around 50 I add a military neck gaiter given to me by my son. Under 50 I just add the liner to the leather jacket. I used to call it quits at 40 but with the SVTC, the heated seat and grips basically take that a lot lower. From just below the knee to the upper thigh would be cold. I've been debating chaps and I do need new gloves (I've worn holes in them). I need to add that I wear a half helmet with the muffs for a Cardo headset at all times, including over 100. My wife just picked up some faux leather from Hobby Lobby ans said she is going to make me a set of mini chaps. Should be interesting. As a kid in NE Ohio I wore long johns, Jeans, heavy leather coat, ski gloves and heavy boots and rode in everything except icy conditions. Even below 0 a couple of times which was awful but when you have nothing else you do what ya gotta do.
    Don't end up in pieces. Riding should be your Peace.
  8. Thanks Sylvester gave thanks for this post
    Likes Sylvester liked this post
  9. #7
    Join Date
    Jul 2012
    Woods Cross
    UT
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    I wear a Tourmaster heated jacket under my Tourmaster mesh jacket with rain liner installed, Gerbings heated gloves, and a modular helmet. ( When I wore an open face helmet I also wore a balaclava.) On the bottom I wear thermal underwear, motorcycle denims, and rain pants. On my feet wool socks and very waterproof cycling boots. I have never had to turn the electric past the mid point settings. I do ride a full faired RSV. Two weeks ago I returned from a weeklong trip were the last day started at 26 degrees and ended at 45 degrees. I had an enjoyable last day. During 50 years of road riding I have cobbled together countless riding outfits attempting to stay warm and dry. And I have experienced many miserable days in the saddle being wet, cold, or wet and cold. I finally started researching quality gear, prioritizing my spending, and those miserable riding days came to an end. You can spend much more and get better gear than I but mine has been more than sufficient. I hope this helps.
    Krod
  10. Thanks Drews gave thanks for this post
    Likes Drews liked this post
  11. #8
    Join Date
    Sep 2010
    Dunlap, IL
    IL
    Post Thanks / Like
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    I ride to the office - about 30 minutes (one way) of primarily 65MPH interstate highway almost every day. I wear a Tourmaster jacket with a liner that is about 10 years old, full face helmet, and gauntlet type gloves. Just jeans, casual shoes, and a long sleeve shirt otherwise. The lowest temperature when I leave home (before daylight) is 28 degrees with daytime highs in the 40's. If there is heavy frost or ice I don't ride. If am going for a longer ride in these temps I will wear leather chaps, leather boots, add a sweatshirt, glove liners, and a neck cover thing. I usually can ride, in central Illinois, until Thanksgiving or the first week of December.
    Always a full face/modular helmet regardless the time of year but when the temps start dropping below 50 I add the pin lock screen to the visor. Best thing ever for no fogging.
    The current 2 wheel fleet:
    2012 Venture, 1980 Kawasaki KZ750, 1978 Honda CB750,
    1977 Honda GL1000, 1977 Honda GL1000,
    2007 Kymco Grand Vista
  12. #9
    Join Date
    Jul 2014
    Prince Edward County
    Canada
    ON
    Post Thanks / Like
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Got a wicked Flashback decades back while stopped at an early Walmart on I-75 between Cinci and Atlanta.
    Here's a young Kid on a naked 650-ish Yammy, so cold he's leaning over a coffee held with both hands, and couldn't stop shivering.
    We didn't have much extra US cash left, but slipped him $20 and said: "Buy a rubberized rain jacket 'n pants."
    Wasn't gonna help heat, BUT at least stop the wind. Can't remember destination, but it was a long way to go, and the poor Kid had to be at work the next day. By the time he got home, that bike's tank would have knee dents on both sides of the tank.~
    Rgds, WRIDR
  13. #10
    Join Date
    Jul 2016
    Youngstown
    OH
    Post Thanks / Like
    Mentioned
    10 Post(s)
    Tagged
    0 Thread(s)
    I'm in NE Ohio and ride as long as the roads are clear. I wear a set of cold weather gear from XElement bought from Leatherup.com. The set I have is about 10 years old so it may not be available anymore. I think I paid around $150 for the jacket and pants together. I wear a full face modular helmet and a full face gator when it's below 35 deg. or so. I did spend a good amount of $ on a pair of water proof Joe Rocket insulated gloves and and boots. I might consider going heated when I replace the gloves and boots.
    TANSTAAFL
  14. #11
    Join Date
    Oct 2019
    Sanford
    FL
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have found that leather chaps make a big difference on the legs due to their wind blocking properties. My personal cut-off temp for riding is 32F but that is just because I do not care to go ice skating on a bike.
  15. #12
    Join Date
    Jul 2019
    Atlanta
    GA
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sean,
    I just got back from a little 10 mile ride in 40 degree weather (sunny out). I wanted to see how light/moderate riding gear would do in the cold.
    I just wore regular jeans socks and shoes, a long sleeved T under a long sleeved button down shirt under a non-lined leather jacket.
    Leather gloves and a 3/4 helmet with a shield. I thought I'd be ok or only a little chilly as it was only 40 degrees out.
    It was an eye opening ride. I froze my ass off.
    I needed wool socks, boots, thermal underwear, (much)better gloves, a thicker motorcycle jacket, a scarf and a ski cap.
    I'm planning on heading back out when it hits 50 degrees, wearing the same gear in order to better judge what cold weather gear I need and/or what temps to try to avoid.
    Bill
  16. Likes Beardyspice liked this post
  17. #13
    Join Date
    Sep 2006
    Burlington, ON
    Canada
    ON
    Post Thanks / Like
    Mentioned
    63 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Atlanta Bill View Post
    Sean,
    Bill
    I used to ride all year round, not so much these days mainly because of the new ice-melting crap they use on the roads now because it eats wiring and connectors like crazy. But a beautiful winter day ride can be very invigorating.I wear full face and a snowmobile suit. I even road my 1975 Canam 250 TNT 15 miles through one of the worst snow storms this area has seen back in the mid seventy's and was the only one to make it into work. The deep snow was no challenge to the bike, but coming home on fresh plowed hard packed snow was. Click image for larger version.
Name:	first ride of 2014a.jpg
ID:	117980Click image for larger version.
Name:	first ride of 2014b.jpg
    I AM A DRINKER OF THE WIND
  18. Thanks Drews gave thanks for this post
    Likes Drews, bpate4home liked this post
  19. #14
    Join Date
    Jul 2019
    Atlanta
    GA
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Saddlebum,
    I bet it was invigorating and a whole lot of fun!
    Mercifully I don't need to ride to work or out of necessity. I just know there will be some cold (for Atlanta anyway...lol ) days coming up when I'll still want to ride.
    It was interesting to learn the leather gloves didn't hack it. I kind of knew just regular jeans with no long johns would be problematic.
    Bill
    ...beautiful bike, btw.
  20. #15
    Join Date
    Feb 2019
    Stockton-on-Tees
    United Kingdom
    UK
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Here's my winter weather gear..
    Underrmour (the stuff runners wear - skin tight top and pants)
    Leather trousers
    Tshirt - Jumper - Fleece - Wax Jacket (oversized to fit the fleece under)
    Full face helmet - Snood - Winter Gloves
    Snug as a bug in a rug - it'll be about 3c (37f) tomorrow and I'll be nice and warm
    Currently riding :
    2002 RSV
    2005 Honda VTX 1300
    2003 Hayabusa
    This will change... Frequently!
Similar Threads
  1. Cold weather car trouble
    By RDawson in forum Jokes and Humor
    Last Post: 02-02-2019, 10:30 PM
  2. Freezing Cold Weather
    By E-Fishin-C in forum Watering Hole
    Last Post: 02-11-2011, 10:38 AM
  3. Cold weather riders!
    By dynodon in forum Watering Hole
    Last Post: 11-28-2010, 01:05 PM
  4. Cold weather trip
    By Iowa Guy in forum Riding Gear
    Last Post: 10-07-2009, 10:14 PM
  5. cold weather gear
    By painterman67 in forum Watering Hole
    Last Post: 12-01-2008, 07:46 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
