frankd Posted June 22, 2012 Share #1 Posted June 22, 2012 I have a small tree growing up through the deck attached to my house. This deck is only a little bit above the ground, so I can't get underneath it to get to it. The only way I see to get anywhere near it is to remove some of the deck boards and reach down. Anybody have any idea how I can get rid of it? Frank D. Link to comment Share on other sites More sharing options...
Shorty Posted June 22, 2012 Share #2 Posted June 22, 2012 Yamahalube Link to comment Share on other sites More sharing options...
Dano Posted June 22, 2012 Share #3 Posted June 22, 2012 Spray it with some Round-up, it'll die and you can just cut it off at the boards Link to comment Share on other sites More sharing options...
MiCarl Posted June 22, 2012 Share #4 Posted June 22, 2012 Seafoam! Link to comment Share on other sites More sharing options...
BlueVenture87 Posted June 22, 2012 Share #5 Posted June 22, 2012 What is the diameter on the trunk? Link to comment Share on other sites More sharing options...
FuzzyRSTD Posted June 22, 2012 Share #6 Posted June 22, 2012 1/4 cup Vinegar,1/2 cup water and 6 tablespoons of salt, stir. Pour it slowly down to the trunk and into the ground. A few days and it will be dead forever. Nothing against trees, but one against or in the porch is not good. There is a mixture for the vinegar,water, and salt that can be used around the yard to kill grass and weeds, but will not harm larger trees. If I remember correctly, it is this; 1. One gallon of water in a spray. (Just double everything for more) 2. Cup of any kind of vinegar. 3. Three heaping tablespoons salt. 4. Three tablespoons of dish liquid, mix lightly (the dish liquid helps hold some of the mixture on the leaf of the grass and weed plant). This will need to be repeated every month to keep the grass and weeds down. But it can be sprayed around large trees and flowers and shrubs without harming them, but keeping the grass and weeds at bay. Fuzzy Link to comment Share on other sites More sharing options...
Guest tx2sturgis Posted June 22, 2012 Share #7 Posted June 22, 2012 Large bulldozer. Oh wait...did you want to keep the house and deck intact? Link to comment Share on other sites More sharing options...
bongobobny Posted June 22, 2012 Share #8 Posted June 22, 2012 Flaqmethrower... Nah, the Roundup will do it. Link to comment Share on other sites More sharing options...
barend Posted June 22, 2012 Share #9 Posted June 22, 2012 Actually, ... Round Up MAY kill it depending on how long the thing has been there. If you cut the tree down and build a deck over the stump you'll be spraying quite awhile! If this is a fairly new sprout, spray it, wait a couple of weeks and remove a plank to pull the dead sapling. Unless you want to look at a cut of branch for the next ten years. 'Course you can skip the whole round up thing and just yank it from the get go. Link to comment Share on other sites More sharing options...
dacheedah Posted June 22, 2012 Share #10 Posted June 22, 2012 Roundup won't get the tree, you need a product called brushmaster ( woodie growth), I would suggest that you upon some boards and girdle it , then cut above. If it is invasive, it will have it try to grow again from the rootstock. Smaller is easier to kill. Try to identity the species. Diesel fuel saturating the root may also help make it no longer. Link to comment Share on other sites More sharing options...
Condor Posted June 22, 2012 Share #11 Posted June 22, 2012 I've never tried it, but I've heard that driving a couple of copper nails into the trunk will kill it..... Link to comment Share on other sites More sharing options...
Flyinfool Posted June 22, 2012 Share #12 Posted June 22, 2012 Use a pruning pole to reach under and cut it off. The pruner will also allow you to pull it out for disposal. Then pour a large amount of salt thru the cracks between the boards to make it stay dead. Put some paper thru the board cracks to act as a long skinny funnel to keep the salt off of the deck so that you do not damage the wood or nails. The pruning pole that I have has a 12 foot reach. If all else fails, a sufficient application of dynamite will make most problems go away. Link to comment Share on other sites More sharing options...
Yammer Dan Posted June 22, 2012 Share #13 Posted June 22, 2012 If all that fails....Build a Tree House!!! With a ramp to get the 1st Gen in... Link to comment Share on other sites More sharing options...
BuddyRich Posted June 22, 2012 Share #14 Posted June 22, 2012 Groundclear may still kill it. Link to comment Share on other sites More sharing options...
Ky. Rider Posted June 22, 2012 Share #15 Posted June 22, 2012 If it is small enough to be under the deck then Roundup should kill it. Or, anything you can think of that would kill a small tree or grass such as salt, diesel, oil product, etc. should kill it. No need to buy a brush killer because you should be able to come up with something you already have that will get the job done. Link to comment Share on other sites More sharing options...
KIC Posted June 22, 2012 Share #16 Posted June 22, 2012 I heard that if you park a Harley over the top of it, it will die from the oil leaks and the embarrassment. Link to comment Share on other sites More sharing options...
DragonRider Posted June 23, 2012 Share #17 Posted June 23, 2012 I used some chlorine bleach on a fire ant pile once and grass never grew in that spot again for a couple of years. Might work on the tree............ Link to comment Share on other sites More sharing options...
Marcarl Posted June 23, 2012 Share #18 Posted June 23, 2012 I know around here I could find somebody to sit on it for a while and if the timing is right almost anything will die from the results,,,, don't you have somebody like that around your area? To bad it's not a venture or a HD sign could kill it as well. Link to comment Share on other sites More sharing options...
bongobobny Posted June 23, 2012 Share #19 Posted June 23, 2012 Let it grow and eventually you will have nice shade on your deck, cheaper than buying one of those umbrellas... Link to comment Share on other sites More sharing options...
BIG TOM Posted June 23, 2012 Share #20 Posted June 23, 2012 I heard that if you park a Harley over the top of it, it will die from the oil leaks and the embarrassment. Still making friends, I see Link to comment Share on other sites More sharing options...
KIC Posted June 23, 2012 Share #21 Posted June 23, 2012 Still making friends, I see You only harass the ones you love.... So they say.... Link to comment Share on other sites More sharing options...
