Pioneer e-mailed last night while I was working on lawn tractor in garage. Said parts were in except less 3 bolts and he mentioned that they were back ordered(didn't say that when ordered) so he is looking into seeing when and if he can get them.
For what it’s worth I re-used them all on my 07 last year. So far so good. Not advising you to do it but mine were still pliable.
Edited by RDawson
I know I am one of the biggest proponents of OEM or at least Japanese after market for gaskets, BUT...
The one time cheap worked was with the valve cover cushions. The valve cover gaskets I got with them were worthless, but the bolt cushions worked fine with an OEM gasket on my '83.
unfortunately no luck with any dealerships locally or out of the area.  The ETA on 3 of the bolts is mid-january, so I would just suggest sitting tight on this project for a couple of weeks.  I'll let you know when all are here.  Thanks Phil and Merry Christmas.
Chad Armstrong
Pioneer Motorsport
Just got this e-mail last night. Hopefully this will work time wise what with lock-down imposed!  What you think?
  On 12/23/2020 at 7:36 PM, XV1100SE said:
Let me relate an actual story ....
My first bike was a Kawasaki KZ305 (cruiser).  Don't remember why (probably leaking gaskets) but I rebuilt the motor.  Took the valves in to a shop to get them lapped and was told 3 needed to be replaced but the 4th was fine.
Rode the bike for about 2 months....was running better than when I got it.  On my way to work one day the motor started spinning up and I lost power.  One of the valves broke and bounced around inside the cylinder.  Ended up having to buy (after finding one) a new motor.
Guess which valve broke.
Now I don't skimp when doing repairs.  If one headlight burns out I know the other won't be far behind so I'll replace both.  That is your hint on which valve broke.  Learned from experience.
Expand
 Even if you had put a new valve in it may still have broke because Valves do not usually break on their own. there is usually  an underlying cause. improperly seated keeper coming out, broken spring, if adjustable rockers the Jam  nut could have come loose, foreign object causing the valve to bend poor lubrication cause a partial seizure which could result in piston / valve collision, or over revving the engine. Just say,n   :confused24:
  • 1 month later...
E-mailed Chad from Pioneer last week and he contacted me to-day saying to contact him as the last pieces came in. I will call him in morning to pay for them and then he will ship as soon as he can.
 Yes those are the 16 bolts with rubber seals! On my 2012 they are mounted on the bolt itself but on XV1100SE's 2009 they are separate.
Also Don parts are paid and he going to try and ship today!(gaskets and bolts)
Follow up dumb question, does anyone have the part number for the valve cove bolt seals for the 1999 RSV. I’ve been searching the net and still unclear.
thanks
Ok just found this on partzilla, looks like 1999 is a separate bolt and seal.
Bolt: 90109-066F0-00
Seal: 5EA-1111G-00-00
Also, partzilla appears to have the best price at $10.61 ea for the seals.
Edited by RoTorKev
@XV1100SE has same bike. He could tell you. Found this in previous post of his.
I'm impressed with Performance Cycle!  I didn't realize that there was a difference in parts for the 2012/2013 RSV but apparently there are differences.
For "up to 2011"... there is sealing rubbers 5EA-1111G-00-00 @ $16.31 that goes over bolt 90109-066F0-00 (didn't ask for price). Cost of the rubber is $16.  For 2012/13 there is 5SL-1119E-00-00 (which are bolts with rubbers).  The 2012/2013 bolt/rubber is $5.95 but back ordered.  I don't know if these parts are interchangeable as no part numbers are listed as replaced by another.
Thru Performance Cycle I have ordered :
sealing rubbers # 5EA-1111G-00-00 up to 2011 $16.31 quantity 16
valve cover gasket # 4NK-11193-00-00 @ $44.71 quantity 2
  • Like 1
I got my parts from Pioneer Motor Sports Chaffee NY (check website)   with a Venturerider discount (I think it is 10%)
I talked to Chad Armstrong.(owners son)
I just googled part number 5EA-1111G-00-00 and found them on e-bay for $47.00 for all 16 seals. Only took about 2 weeks to get them. Wasn't in a huge rush so saved about $150 by waiting.
Ron
  On 2/16/2021 at 4:12 PM, XV1100SE said:
Show off !!
You got a really good deal !
Expand
I did get lucky, just wanted to post this so if anyone else is looking to purchase these just found more on eBay for about same price.
  • Like 1
  • 2 weeks later...
Hey Everyone, This will be my final update on the Shim Kit Saga. I received word from USPS saying they were NOT going to honor the Insurance Claim because they were used parts, and I wanted to keep the shims that actually made it all the way home! In other words, they would take possession of 55 shims, the Bucket Tool, Feeler Gauges, and the busted up case, and give me $200.00. I said, "No Thanks"! So in the future, I won't be wasting my money on USPS Insurance! On another note, The "New" Shim Kit is all back together, with about 90 shims in it, and all of the tools you will need to complete this service. At this point, I want to thank EVERYONE that has kicked in to help me replace the shims. I want to assure you that I spent every penny on new shims for the kit.
And lastly, I am not back to work at my "Day Job" yet from my recent surgery, but I am on the mend and getting around pretty good these days. All of my kits I offer, as well as the Shim Kit Loan are being offered again. The only exception to this would be the Block Off Plates. I haven't been allowed to fire up the milling machine yet by my wife. If everything goes well at my next doctor's visit, I should be back to work mid March. I can't tell you how grateful I am to be sitting here still on this planet, and chatting with this wonderful group of people! So, if anyone needs the Shim Kit, or anything else for that matter, just let me know! Also Thank you EVERYONE for the support during this trying time!
Earl
  • Like 7
So they wont insure "used parts". But yet every salvage yard on E-bay ships stuff UPS and USPS n FedX. Hmm So what do you do about shipping next time. Tell them its all new parts?
  • Like 1
  • 2 weeks later...
Hey Dion,
The issue was about the fact that USPS wanted to take possession of ALL of the remaining Shims, the Bucket Tool, and the rest of the tools in the kit and THEN pay me the #200.00. The contents of the kit that made it back to me were worth WELL over the $200.00 offered. I declined to accept that pultry offer, and opted to keep everything that made the trip, and rebuild from there. I hope this clears this up a little better for you.
Ah OK. Low ball offer so you would go away. Did they have possession of parts when they made the offer? If not I would have sent them a few pieces and told them pay up. But I understand, sometimes its better to just walk away and not fight a battle that is not worth going that way. But it sounds like buying their insurance is not worth the time of day.
  • Like 2
The part that really bothers me the most is that kit has been mailed and insured how many times? They’ve made money every time it ships and won’t stand  behind it. Thanks again Earl for what you do, that kit saved me a lot of time and headache.
