- Past hour
You have friends??? Still??
Marcarl started following Bike just quits! and 2009 RSV with under 38k km ( approx 23,600 miles)
You might check the air inlet on the gas cap. Could be creating a vacuum if plugged.
- Today
Morning! Got the bike out for an actual ride on Sunday. Only put about 150 miles on, but it sure felt nice. I'm having a pilot jet slightly plugged on one of my cylinders though, so some work will come my way I guess.
Okay, so here I am again with yet another issue on my 98 RSTD. It's running great, but every once in a while it just quits, usually at higher speeds. Sometimes I can kick down a gear and it basically "jump" starts, other times it just quits and I have to pull off the road and try to restart, which it will do...eventually! So has anyone else had this issue? I'm thinking faulty kick stand sensor or even faulty ignition. Thoughts and thanks.
- Yesterday
- Last week
I'm perplexed! I lost my highway lights, so checked fuses, ok. Took lights apart and while there is power to the slave (left) light, I can't get a power reading on the right, switch side. What confuses me is if there is no power at the switch, how come there's power to the slave? I'm thinking bad switch. Thoughts and thanks.
- 1
Vibration on hard acceleration
Precious replied to Precious's topic in Royal Star and Royal Star Tour Deluxe Tech Talk
Thank you. I haven't done that. Will try to find someone who can. -
RDawson replied to Precious's topic in Royal Star and Royal Star Tour Deluxe Tech Talk
Have the carbs been synched? It will cause a vibration under load if they’re unequal. -
Selling my beautiful 2009 RSV. Low mileage, lots of extras. Garmin Zumo GPS, highway pegs, aftermarket seat, backrest, trunk spoiler with light, second aftermarket brake below the truck, chrome crash protection bars for the bags, LED headlight bulb included but no yet installed. New battery this year. Asking $9,000.00 Canadian safetied. Would be interested in a trade for an 1800 Goldwing.
I did somer major restoration work on one a friend of mine bought last summer. I should ask to see if it was him.
Both replies are good options, Paul I have read about the bootable usb drive but have not thought about the second hard drive idea, I have a few old hard drives laying around.
Woody started following Windows 10 to 11
Hello Misty, Welcome to Venture Rider. Please feel free to browse around and get to know the others. If you have any questions please don't hesitate to ask. Misty joined on the 06/09/2025. View Member
Misty joined the community
Good morning to all! Got called in to work over the weekend and the weather was a little bit unsettled, so just caged it. Grass cut Monday is inevitable.
'99 Intermittent Starting - Bad Ground?
BratmanXj replied to BratmanXj's topic in Royal Star Venture Tech Talk ('99 - '13)
Wouldn't the ignition bypass relay shut down the entire bike electrical system? Or does it see the load when you hit the starter button? The last month was all about the safety interlocks like the clutch switch, stand switch, neutral switch...but yes I plan to go through them again. I wondered if it's something on the low side of the starter solenoid that I don't even get the click. I'll dive into it later this week -
If you want to play with Linux, I've found one of the easiest to install and has similarity to Windows is Linux Mint. If your hardware is old, there's a 'light' version of Linux Mint. You can also try before you commit to it by creating a bootable Linux Mint USB using a Windows app called 'Rufus'. Yet another option - buy a new hard drive and use the bootable Linux Mint USB to install it to the new hard drive. Keep your Windows drive hooked up in the computer, and you will be able to browse the old drive.
RDawson replied to BratmanXj's topic in Royal Star Venture Tech Talk ('99 - '13)
You would hear the relay if it was the starter. Possibilities off the top of my head: do you have an ignition bypass installed? Check that relay if so. ignition switch, sidestand switch, cables/wire connection clean and tight at the starter relay and battery. -
After a month of methodically picking away at the clutch-neutral-kill switch interlock system I THOUGHT I had the problem resolved. Multiple short trips around town and no issues with restarting. Went to take a nice ride yesterday and after 30 min I stopped for gas and the bike wouldn't crank. Pushed the bike into a parking spot and walked next door for lunch. After an hour the bike restarted and I headed home. 30 min ride home and in the driveway the bike wouldn't crank. Wait an hour and it turns over just fine. As noted above, its a purely starter/electrical issue... bike turns on, fuel pump primes, but hit the starter and no-crank, not even a solenoid click. I haven't started back into the system yet and figured I'd post on here for moral support. I assume its a heat-soak issue either at the safety interlock relay that's right in front of the battery box, the starter solenoid, or the starter. -
N3FOL started following Windows 10 to 11
I've been on that similar dilemna in the past and I decided to keep my best and mostly used computer at home and buy a very dependable computer that I carry around to and from work and for leisure use, while away from home. I you are computer savvy and love to work on operating systems and have tons of time to do so, Linux is a great way to explore its potential. I tried Linux, but decided to stay with Windows to do digital comms as a long time ham radio operator. My suggestion to you is to just get rid of your old Win 10 computers since they are 'rarely' used and simply upgrade your current and mostly used computer to its full potential and enjoy it. It is true, the end of Win 10 is coming to an end just like anything else.
Ok, trying to decide what to do I have three computers that I use although two are rarely used. One is W-11 and the other two are W-10 and are not capable of being upgraded they are like me just to old I guess. Never tried Linux and after looking into it there are several to choose from so what are my options Linux, new computer or disconnect the two W-10's from the internet. The end of 10 is coming
My first was a two tone blue '84. Sold it to my brother, who eventually sold it to a retired fire chief. The fire chief was scared of it and parked it behind his barn, outside, no cover, in 2005. It's still behind the barn, twenty years on.
Hello YamahaX3, Welcome to Venture Rider. Please feel free to browse around and get to know the others. If you have any questions please don't hesitate to ask. YamahaX3 joined on the 06/07/2025. View Member
