  • Replies 148
  • Created
  • Last Reply
Top Posters In This Topic
OK...please try again.
...I can see that you are listed...BTW what's the difference between "registered" and "supporting"?:think:
Basically "registered" are trial members. I've removed that one. If we use this the way I am envisioning it, it will primarily be our "assistance list". Only supporting members will have access to that information. Telephone numbers and etc.
It places my marker after I zoomed in. I added the title and text then insert button. Afterwards when I go back to the main link my marker is no longer there.
Guest tx2sturgis
Hmmmm...the entire map comes up but it only shows the one marker for Freebird...no other markers...is this a test mode or should there be other markers visible?
:crying::crying::crying:
Where's the big island down under??
thats cause we dont want you to go back so now you and quick step have to stay :whistling::confused24::confused24:
Same here, once I set a marker , leave and come back later the marker is gone.
Is there a window zoom function that i missed, it is a little clumsy getting down to the street level, doable, but clumsy without a window zoom.
Eileen is used to it. :)
OK....I just took a look and I think I figured it out. A couple of things. I had it set so that I had to approve the entries. I now have it set to auto-improve. I also had to set a cron job so it may be that your information won't show immediately. I have the cron job set to run every 10 minutes.
Those of you who have already entered your information are showing now.
I just made it a sticky but once I determine that it's going to work out OK, and that people like it, I'll add a link to it from the left menu or the upper menu bar.
