OrlinEngh Posted August 16, 2013 Share #1 Posted August 16, 2013 I just got a 2000 Venture and am wondering what is average gas milage, I am getting 37 to 40 miles per gallon, but we dont have many flat or straight roads around here:) Orlin Link to comment Share on other sites More sharing options...
Brake Pad Posted August 16, 2013 Share #2 Posted August 16, 2013 on my 2007, One up, 38 to 41, two up 36 to 38, pulling a trailer, 2 up 32 to 36 Link to comment Share on other sites More sharing options...
foyerboy Posted August 16, 2013 Share #3 Posted August 16, 2013 Riding as hard as you can, everywhere you can 1 up, throttle twisted so hard your forearm cramps, 31-32 mpg..... :rotf::rotf: Link to comment Share on other sites More sharing options...
mega2500 Posted August 16, 2013 Share #4 Posted August 16, 2013 Last sat. when we meet I ran I 90 to Elroy at 70mph got 40.000 then to your place and home 41.something I am always 40 and above unless I am over 70mph 45mpg is on a real good 2up slower ride day on back roads just sinc my carbs so look out now Link to comment Share on other sites More sharing options...
Condor Posted August 16, 2013 Share #5 Posted August 16, 2013 All the above are halucinating. All they get is 10mpg!!!!! Link to comment Share on other sites More sharing options...
bongobobny Posted August 16, 2013 Share #6 Posted August 16, 2013 Yah! Around 40, give or take a little is pretty normal. I tended to bge a little more spirited so we generally got just under 40 by a few... Link to comment Share on other sites More sharing options...
cw1263 Posted August 17, 2013 Share #7 Posted August 17, 2013 last tank some 2 up and to and from work 60-70mph 46.6 2006 RSV Midnight bone stock except for Bagger mufflers. Link to comment Share on other sites More sharing options...
djh3 Posted August 17, 2013 Share #8 Posted August 17, 2013 Prior to sync carbs about a month ago it was about 36-38 on a good stint. Now on my normal "work route" where I got 36 I now get 38 after syn carbs. 41 Is about tops I have got. Link to comment Share on other sites More sharing options...
Rick Haywood Posted August 17, 2013 Share #9 Posted August 17, 2013 Orlin that is exactly what I get just rode to birmingham today 1up at 75-80mph and aaveraged 38.4 mpg over 670 miles Link to comment Share on other sites More sharing options...
Squidley Posted August 17, 2013 Share #10 Posted August 17, 2013 Thats right in the range of the Ventures both 1st and 2nd gens. I have gotten as low as 35 on a good running bike, and as high as 42. This is owning 3 2nd gens and 4 1st gens that saw lots of miles between them. Link to comment Share on other sites More sharing options...
N3FOL Posted August 17, 2013 Share #11 Posted August 17, 2013 For some reason, I see very little difference whether I cruise at 65 or 75 mph. Link to comment Share on other sites More sharing options...
OrlinEngh Posted August 17, 2013 Author Share #12 Posted August 17, 2013 Thanks for the info had the Venture for a couple of weeks and put a little over 600 miles on. I am averaging 38 miles per gallon with Sharon and me. Orlin Link to comment Share on other sites More sharing options...
BottomFeeder Posted August 17, 2013 Share #13 Posted August 17, 2013 31mpg at cruising speed ~77mph, '13 rsv. Link to comment Share on other sites More sharing options...
N3FOL Posted August 17, 2013 Share #14 Posted August 17, 2013 31mpg at cruising speed ~77mph, '13 rsv. I will assume you are still in your "break- in" period. Hopefully your mpg will improve down the road. Link to comment Share on other sites More sharing options...
star4772 Posted August 18, 2013 Share #15 Posted August 18, 2013 Did the mileage check today with RSTD 42 mpg 2up 65-70 mph. Link to comment Share on other sites More sharing options...
Guest tx2sturgis Posted August 18, 2013 Share #16 Posted August 18, 2013 Ethanol blended gasoline has less btu per gallon so you will get roughly 10% less mpg than if you can find and use pure gas. Plus, the kind of riding you do, the bike's state of tune, the gasoline grade and quality, your elevation, winds, and geography you ride thru will all make a difference. Most riders seem to get between about 34 to 45. I have seen mine as low as 27 pulling a trailer at high speeds, to about 48 when just slowly putting thru the mountain back roads. Also keep in mind that the odometer may be reading optimistic miles per gallon. When you install a Speedohealer, or compare it with another bike with an accurate odometer, you will have a better idea of actual mileage. Link to comment Share on other sites More sharing options...
Flyinfool Posted August 18, 2013 Share #17 Posted August 18, 2013 Thanks for the info had the Venture for a couple of weeks and put a little over 600 miles on. I am averaging 38 miles per gallon with Sharon and me. Orlin Maybe you are just riding harder trying to get the same performance that you are used to from your old 1st gens...... I know Sharon likes to go fast........ Well someone had to go there...... Link to comment Share on other sites More sharing options...
