etcswjoe Posted December 23, 2011 Share #1 Posted December 23, 2011 I have a chance to pick up a 2006 Little Guy 5 wide trailer for a steal from a dealer, he just can't sell it he has had it since it was new. My question is it too big for my 99 Venture? It pulls ok and I can see around it fairly well but it is tall. http://www.golittleguy.com/teardrops/models/5-wide-platform/ Link to comment Share on other sites More sharing options...
Mickey Posted December 23, 2011 Share #2 Posted December 23, 2011 It would be great for a compact car, but at 970 pounds, that would double the weight of the bike, not including passengers and cargo...... too much load on the brakes I would say. Mike Link to comment Share on other sites More sharing options...
wes0778 Posted December 23, 2011 Share #3 Posted December 23, 2011 My thoughts are 1. Tongue weight? 2. Ability to STOP it? 3. Ability to see around it in the mirrors ? 4. would definitely need a clutch up grade! Link to comment Share on other sites More sharing options...
Sylvester Posted December 23, 2011 Share #4 Posted December 23, 2011 It would be a load for the trailer hitch. I haven't seen a trailer hitch for a motorcycle rated for a 2" ball. Quite a load even if it had electric brakes I would be hard pressed to pull it. Think about the weight, it would be like pulling you and your wife/girl friend plus six or more others. Link to comment Share on other sites More sharing options...
Yammer Dan Posted December 23, 2011 Share #5 Posted December 23, 2011 Looks a little large but would be nice. Link to comment Share on other sites More sharing options...
etcswjoe Posted December 23, 2011 Author Share #6 Posted December 23, 2011 I only pulled it flat, but it probably would be a bear to stop loaded or down hill. I can get it for around 2K so I may still get it for my Colorado. Link to comment Share on other sites More sharing options...
steamer Posted December 23, 2011 Share #7 Posted December 23, 2011 I think it would be to big even for my trike. Don't forget about sail surface. It could blow you over in a side wind. I,m looking at a couple of used Time out tent trailers tomorrow,they weigh in at under 300lbs and are made for towing with a bike. they are roomy and are off the ground. Both are $2000.00 or less. hoping less. Link to comment Share on other sites More sharing options...
etcswjoe Posted December 23, 2011 Author Share #8 Posted December 23, 2011 I think it would be to big even for my trike. Don't forget about sail surface. It could blow you over in a side wind. I,m looking at a couple of used Time out tent trailers tomorrow,they weigh in at under 300lbs and are made for towing with a bike. they are roomy and are off the ground. Both are $2000.00 or less. hoping less. Think that may be the way to go, Little Guy Trailers responded to my question and said they would not recommend it. Link to comment Share on other sites More sharing options...
Rick Haywood Posted December 23, 2011 Share #9 Posted December 23, 2011 Way to unsable to pull with a bike.....don't do it Link to comment Share on other sites More sharing options...
rickardracing Posted December 23, 2011 Share #10 Posted December 23, 2011 No freaking way!! 970 pounds...with a bike.....before it's loaded with gear...... Link to comment Share on other sites More sharing options...
skydoc_17 Posted December 24, 2011 Share #11 Posted December 24, 2011 I have seen a Second Gen. regularly pull a folding tent trailer that weighed 420 lbs. fully loaded, but basically, that bike NEVER came out of 4th gear. Brake pads lasted less than half as long, and the clutch diaphragm spring went Bye Bye at 19,000 miles. The R1 brake upgrade and the Clutch Spring Upgrade Kit along with the VMAX final drive solved these problems for the owner of this bike, but if you doubled the weight of the trailer, there is no way you would be able to stop it safely. You want to be shopping in the 300 lb. range empty, and then plan on doing some mods to the brakes and clutch unless you just want to park this rig in your garage and polish it all the time! A deal isn't a deal if it isn't PRACTICAL! If you don't believe me, go look in your wife's closet, and count the pairs of shoes! I rest my case! Earl Link to comment Share on other sites More sharing options...
Mel Posted December 24, 2011 Share #12 Posted December 24, 2011 970 pounds wa-a-a-a-y too much weight! Add your gear and you are looking at 100+ pounds tongue weight. How would you stop it, drag your feet? You certainly could not deal with an emergency/avoidance situation. Unless you have something else to pull it, it's not a bargain if you can't use it. No way should you use it behind a motorcycle. I doubt if your hitch/mount would handle that much stress. There is absolutely no way to tow it safely behind a motorcycle. Link to comment Share on other sites More sharing options...
etcswjoe Posted December 24, 2011 Author Share #13 Posted December 24, 2011 Thanks all for the inputs and have a Merry Chirtsmas. Link to comment Share on other sites More sharing options...
steamer Posted December 24, 2011 Share #14 Posted December 24, 2011 QUOTE=etcswjoe;644859]Thanks all for the inputs and have a Merry Chirtsmas. :sign yeah that:right Back at u Link to comment Share on other sites More sharing options...
Brake Pad Posted December 24, 2011 Share #15 Posted December 24, 2011 You can build it out of very light weight materials. trailer/camper & bed 225 lbs (42"X6.5') everything from Home Depot/Harbor fright trailer project for the winter months, sell this trailer and start on mine. Darn trailer has been sitting in the garage for 8 months in the box:mo money: Link to comment Share on other sites More sharing options...
Carbon_One Posted December 24, 2011 Share #16 Posted December 24, 2011 The Little Guy trailer might be OK for a triked RSV but even then it'd be quit a heavy load to be behind you. Like Doc says more wear and tear on clutches & brakes. Just pulling my small teardrop trailer at 300 lb + load is all I ever want behind me. For a small car or truck I think that Little Guy would be great. Larry Link to comment Share on other sites More sharing options...
CaptainJoe Posted December 24, 2011 Share #17 Posted December 24, 2011 lets just say I have a 26 foot camper for sale but I wouldn't recommend towing that either behind your venture... LOL:buttkick: Link to comment Share on other sites More sharing options...
etcswjoe Posted December 24, 2011 Author Share #18 Posted December 24, 2011 I feel kinda of like an idiot for posting this once I realized what the real weight was, but as usual I have received awesome feedback. Link to comment Share on other sites More sharing options...
CaptainJoe Posted December 24, 2011 Share #19 Posted December 24, 2011 Theres no such a thing as a dumb question. A rule of thumb for towing is you need 10% of the weight of your trailer on the tongue.... Working backwards 45lb. max. toungue weight for our ventures? would give you a Max. trailer weight, fully loaded and balanced of 450 lbs. Must use a scale to do this... believe you can use a typical bathroom scale The problem is if you don't get the 10% on the tongue it is probably aft heavy...Have you ever seen a dog wagging its tail? well the problem is with an incorrectly balanced trailer you never know it till you either hit the magic speed... say 55 mph or a pothole being your on a bike makes it worse as far as consequences go... You have a Merry Christmas my friend... Link to comment Share on other sites More sharing options...
steamer Posted December 24, 2011 Share #20 Posted December 24, 2011 Hey Joe, I might have a line on a "95" full size Timeout, If the guy ever gets back to me. I bought the smaller version today. Price was right. this other one that i heard about has some extras but he will not go below $2000.00. Considering they are around $4000.00 plus new I guess thats a far price. Link to comment Share on other sites More sharing options...
