Marcarl Posted October 25, 2011 Posted October 25, 2011 This is to see if there is any interest in having engine side covers made. The part #s would be: 41R-21731-00-00 and 41R-21741-00-00. They are a 1st gen part only. Will be made from Mirror Finish 18 gauge Stainless. The right side will not be dimpled for the screws, but I figure a couple of nylon washers glued in place should work just fine. Cost would be about $100.00 for the pair and may include shipping. It maybe cheaper, depending on how many we need. We just worked out a maximum price today. The ones shown are chrome, so for identification only.
Trader Posted October 25, 2011 Posted October 25, 2011 The ones shown are chrome, . Ah....I think you forgot something:confused24:
Marcarl Posted October 25, 2011 Author Posted October 25, 2011 Ah....I think you forgot something:confused24: They didn't load right the first time,,, they're there now. Don't you have work to do????
Trader Posted October 25, 2011 Posted October 25, 2011 Hmmm.....you were teasing about mine disappearing while we were working on it....maybe I should go out to the shop and check!!!! What about the side cover vent replacements...did you discuss that with your friend?
Yammer Dan Posted October 25, 2011 Posted October 25, 2011 I have those in chrome and the side cover ones...:whistling:Somewhere!!
Marcarl Posted October 25, 2011 Author Posted October 25, 2011 He could make the inserts for the side covers as well. My guess would be that the material cost would be higher but the labor a little less, so I would guess about the same for them, but if there is interest I would be willing to double check just to make sure.
bongobobny Posted October 25, 2011 Posted October 25, 2011 Hmmm.....you were teasing about mine disappearing while we were working on it....maybe I should go out to the shop and check!!!! What about the side cover vent replacements...did you discuss that with your friend?Hmmmm, I better check for mine as well...
rstacy Posted October 25, 2011 Posted October 25, 2011 I could use a pair of side cover vent replacements. Ray
BradT Posted October 26, 2011 Posted October 26, 2011 Hmmmm, I better check for mine as well... HE was looking in your garage while he was there, it will take a while to figure out what else you might be missing. Brad
friesman Posted October 26, 2011 Posted October 26, 2011 If I remember right when I switched mine from black to chrome, i think I needed to change the brackets behind that the covers bolt to. It might be something to double check when mocking up a set, I apologize that I cant remember for sure. Brian
Jayceesfolly Posted October 26, 2011 Posted October 26, 2011 Carl: I will take a set, too. Can you ship to the US? Jim
Trader Posted October 26, 2011 Posted October 26, 2011 I"ll take a set for my 83 i think I needed to change the brackets behind that the covers bolt to. They don't need special brackets...they just screw in the same holes...at least they do on my 88
Marcarl Posted October 26, 2011 Author Posted October 26, 2011 Carl: I will take a set, too. Can you ship to the US? Jim Yes we can ship the US,, cost will be worked out,,,,, sounds like about $5.00 more... maybe.
Condor Posted October 26, 2011 Posted October 26, 2011 If I remember right when I switched mine from black to chrome, i think I needed to change the brackets behind that the covers bolt to. It might be something to double check when mocking up a set, I apologize that I cant remember for sure. Brian Yeah, you're right Brian. There's a bracket needed to mount to the left side.
friesman Posted October 26, 2011 Posted October 26, 2011 Yeah, you're right Brian. There's a bracket needed to mount to the left side. I thought so, I think it was a slightly longer bracket and moved the holes farther apart on the left side plate. Or if they are making up their own ss plates, they can just use the black plastic ones for the pattern and then they will bolt right up,. Brian
Trader Posted October 26, 2011 Posted October 26, 2011 DOH!! thanks for the correction...don't want to mislead anyone!
Marcarl Posted October 26, 2011 Author Posted October 26, 2011 Yeah, you're right Brian. There's a bracket needed to mount to the left side. So what's so different about that bracket,,,,, I'm missing something here.
friesman Posted October 26, 2011 Posted October 26, 2011 So what's so different about that bracket,,,,, I'm missing something here. Sorry Carl I cant remember whats different but I do remember trying to bolt up the new chrome piece where the black one was and it would match up (I think bolt holes were farther apart,but I am not sure) When I changed out the bracket sent with the chrome stuff it fit fine. Brian
Midicat Posted October 29, 2011 Posted October 29, 2011 Well, when y'all get the mounting details outa the way, y'all can set me up fer a pair. (Sorry, drinkin' Jack Daniels has a funny effect on me. LOL Seriously, I'll take a set)
friesman Posted October 29, 2011 Posted October 29, 2011 Sorry if I am confusing things here, i just wanted to ensure that when you made up the new SS plates, you would use a copy of the black plastic plates. If you use the chrome as a template they wont fit on the left side without changing the bracket. (at least thats the way it was on my 85) Brian
Marcarl Posted October 29, 2011 Author Posted October 29, 2011 Sorry if I am confusing things here, i just wanted to ensure that when you made up the new SS plates, you would use a copy of the black plastic plates. If you use the chrome as a template they wont fit on the left side without changing the bracket. (at least thats the way it was on my 85) Brian Thanks for the heads up. What I priced out and used were my chrome plates, but it seems I'll have to find a buddy who still has the plastic ones and so be able to cross match them first. I'll do that,,, then get back here. WAYNE????????
Wizard765 Posted October 29, 2011 Posted October 29, 2011 Yesser.. I'll pull my plastic ones off and we can compare notes...
bongobobny Posted October 29, 2011 Posted October 29, 2011 Carl, I'll take a pair but funds won't be available until December at the earliest due to being out on DB...
Marcarl Posted November 1, 2011 Author Posted November 1, 2011 Ok, I think I got it done,,,, so far. Engine cover plates, both sides, 18ga mirror stainless, laser cut. Bracket for left side, 12ga plain stainless. You can't see it so no need for mirror. 4 x stainless 10\24 screws. You'll need to tap out the right side to #24 thread. 2 x1\2" nylon spacers to adjust the right side out so that it fits flat Shipping to US or Canada If I get one order the cost will be $150.00 for the package. If I get 10 orders the cost drops to $105.00
