mashley Posted July 26, 2008 Posted July 26, 2008 Hey, I recently purchased my 08 RSTD and I would like to add some extra brake lights to the bike. The problem is I cant really decide where or what kind I want to go with. I have the wrap around saddle bag guards on the bike. If you could please give me some suggestions and pics of what you have done if you have them. Also has anyone installed a headlight pulsator on there RSTD would like to know how well that works. Thanks to all!
VTirelli Posted July 26, 2008 Posted July 26, 2008 I added the wing on mmy trunk lid, I guess you can't do that on a RSTD though. What I also added was Hyperlites................ www.hyperlites.com, I like the way they look and work. I also put the LED rings in. They glue to the rear turn signal lenses and run as running lights and also as extra brake lights, but the turn signals stay amber. http://www.electricalconnection.com/other-lighting/tsk-star&sport.htm No pics but the back of my 05 is pretty well lit up. Others had added the Harley set up but I dont have a link. Hope this helps
RedRider Posted July 26, 2008 Posted July 26, 2008 This is what the tail end of a Venture looks like with the Harley lights. Easy to hook up and they look great. Still have the standard bulbs in 'em. You could get more light with LEDs. RR http://2000rsv.smugmug.com/photos/332730279_exZhQ-M.jpg
seforeman Posted July 26, 2008 Posted July 26, 2008 These attachment show what I did. Most of which was purchased from Signal Dynamics (Light Bar) or Custom Dynamics (License Plate Frame) Stu
KeithR Posted July 26, 2008 Posted July 26, 2008 Vin The LED Rings that you installed from Electrical Connection come as a complete kit ? Does it add much in the way of lighting? It appears to be an easy install. Keith
Eddie Fulmer Posted July 26, 2008 Posted July 26, 2008 Seforeman has the right information for you. There is nothing as cheap, or more expensive that looks as good. I have one on my bike and it works great and many people comment on how good it looks. Here's the address to the light. http://signaldynamics.com/products/LightBars/15ultra.asp Go to the hardware store and buy 2= 1 inch bushings that you can put a #10 screw through. I got some made from plastic at the local Lowe's lumber store. These move the light bar out from under the trunk just enough so that it doesn't touch the trunk. Get 2 #10 x 1 1/2 inch stainless screws and some self locking nuts. Pull the rubber back on the helmut mounting rig under the trunk and the holes in the led light bar will line up with these perfectly. You can mount the light without even drilling a hole!!! I can't remember the wiring colors for it but you can figure it out easily. Hope this helps. You won't be dissappointed. It looks like it's made for the bike.
V7Goose Posted July 27, 2008 Posted July 27, 2008 Check out the pictures in my profile for some ideas: http://www.venturerider.org/forum/vbpicgallery.php?do=view&g=161 Goose
GlennTuc Posted July 27, 2008 Posted July 27, 2008 Thanks Guys. I went to the SDC web site and ordered the 15" Ultra Light Bar. Goose, QuickSilver is a good looking RSV. Glenn
friesman Posted July 27, 2008 Posted July 27, 2008 A guy I have met a few times has changed out the signal light sockets and bulbs on his scoot and done some rewiring so that when he puts the brakes on one filament in the signals come on also. the signals run on the other filament in the new 2 filament bulb. I was thinking this might be a way to be a bit more visible without a lot of modding and messing around. I am wondering if it would be legal tho..... Brian
karbar99 Posted July 27, 2008 Posted July 27, 2008 For the Tour Deluxe or the Venture I highly recommend this. http://www.phatperformanceparts.com/ProductDetails.asp?ProductCode=9011%2D10 VERY BRIGHT Tail & Brake Light!
V7Goose Posted July 27, 2008 Posted July 27, 2008 A guy I have met a few times has changed out the signal light sockets and bulbs on his scoot and done some rewiring so that when he puts the brakes on one filament in the signals come on also. the signals run on the other filament in the new 2 filament bulb. I was thinking this might be a way to be a bit more visible without a lot of modding and messing around. I am wondering if it would be legal tho..... Brian It is legal only if you have red lenses on the signals. Goose
Bummer Posted July 27, 2008 Posted July 27, 2008 Here's my rear end! Love that RadiantZ tail light board. Too bad they don't make 'em like that anymore. I note that they do make what appears to be the same board for the VTX. I've sent them an email about whether it's the same one turned upside down, and/or if it'll work. I love this light! It's poke your eye bright, probably not really legal since the feds say the light can not glare, but I don't care. It's bright even in the day time.
VTirelli Posted July 31, 2008 Posted July 31, 2008 Vin The LED Rings that you installed from Electrical Connection come as a complete kit ? Does it add much in the way of lighting? It appears to be an easy install. Keith Yep, came with everything. Adds a nice touch, not really bright but every lil bit of light helps back there. I think it was about 50 - 75 bucks.
Switch Posted July 31, 2008 Posted July 31, 2008 This may sound like an over-simplified fix, but I took one of those leds light things that bicyclers wear on their leg or arm and scotch taped it between the upright bars on the passenger backrest. At night when I ride, I simply push the top activator button for which ever one of six different combinations of the six lights that I want to have flashing. This is not a brake light but rather just a flashing warning light for cagers approaching from the rear. Hope I explained that correctly.
AmnChode Posted July 31, 2008 Posted July 31, 2008 (edited) The LED Rings that you installed from Electrical Connection come as a complete kit ? Does it add much in the way of lighting? It appears to be an easy install. Keith Keith, I have the rings as well and yes it is a complete kit. Pretty simple install, just remove the turn signals to run it through the stems...trust me, lots easier. I ended up wiring them up behind the license plate. Works like a champ... I flash them a little with the Radiantz tail light 1:05 in... http://www.youtube.com/watch?v= for the youtube deprived, direct link of mp4 vid: Clicky, clicky Keep in mind, broad daylight (~1300hrs)...I work swing shift and the quite bright when I am riding..... attached are a couple of pics at dusk.... Edited July 31, 2008 by AmnChode added a couple more pics...
KiteSquid Posted July 31, 2008 Posted July 31, 2008 I dont know what is in your bike, but on the RSV I replaced the bubls with either 2357LL or 2357A bulbs. I had to cut off one of the indexing pins, but I got a lot of light for very little $
yamahamer Posted July 31, 2008 Posted July 31, 2008 I added the wing on mmy trunk lid, I guess you can't do that on a RSTD though. What I also added was Hyperlites................ www.hyperlites.com, I like the way they look and work. I also put the LED rings in. They glue to the rear turn signal lenses and run as running lights and also as extra brake lights, but the turn signals stay amber. http://www.electricalconnection.com/other-lighting/tsk-star&sport.htm No pics but the back of my 05 is pretty well lit up. Others had added the Harley set up but I dont have a link. Hope this helps here is some video of the rings installed on mine. http://www.venturerider.org/forum/showthread.php?t=18431
2WHEELSFORME Posted July 31, 2008 Posted July 31, 2008 You have already ordered but the SOMA light bar is very clean application. Small and bright and has both run and brake lights. http://www.chromeglow.com/store.asp?pid=12781
