mike042 Posted April 17, 2024 #1 Posted April 17, 2024 All of a sudden now when I turn on key, I don't hear any clicking as before, but bike is running good, rode for couple of hours with no problems, only thing I questioning is no clicks as it was before. 2011 RSV . little over 23000 miles on it
RDawson Posted April 17, 2024 #2 Posted April 17, 2024 Had you hearing checked?🤣🤣🤣 Was the tank full? Possible it was gravity feeding the carbs if enough gas in the tank. I’d definitely check the pump points. 1
bpate4home Posted April 18, 2024 #3 Posted April 18, 2024 15 hours ago, RDawson said: Had you hearing checked?🤣🤣🤣 Was the tank full? Possible it was gravity feeding the carbs if enough gas in the tank. I’d definitely check the pump points. I actually had this issue on the '06 I had. Everything seemed to work fine until I was on a long ride several weeks later. Took it to a shop who basically held me up because I was running darkside on the bike. The bike Started and ran fine until it didn't, as they say. No issues after a new fuel pump.
mike042 Posted April 18, 2024 Author #5 Posted April 18, 2024 Thanks all for confirming my thought. Just what I thought it was, but I'm not an expert 😁. Going to change the pump now, I had bought a spare fuel pump last year as partzilla had the for decent price, and had a feeling I might be running into it soon. Worked out perfect I just took it out of winter storage and was just going to change oil and get it ready for the season . I'm in new england so only about 7 or 8 months of riding .
RDawson Posted April 18, 2024 #6 Posted April 18, 2024 1 hour ago, mike042 said: Thanks all for confirming my thought. Just what I thought it was, but I'm not an expert 😁. Going to change the pump now, I had bought a spare fuel pump last year as partzilla had the for decent price, and had a feeling I might be running into it soon. Worked out perfect I just took it out of winter storage and was just going to change oil and get it ready for the season . I'm in new england so only about 7 or 8 months of riding . Replace the points in the old one and you’ll still have a spare. 1
VentureFar Posted March 1, 2025 #8 Posted March 1, 2025 Just want to pop my head up and say thanks for this thread. I used to be active on this forum but now my Venture has pretty much sat for 4 years as I play with a Tenere 700. Went to go for a ride with the wife today and all I got was a slow idle and no clicking. I took off the side cover and tapped the fuel pump and voila ! gas. This isn't my first rodeo with replacing the points but didn't remember the part number. Thanks @Du-Rron 1
VentureFar Posted March 8, 2025 #9 Posted March 8, 2025 Bought the points off amazon. Replaced the fuel pump points at about 16,000 miles and now at 60,000. I don’t get many miles to points on my 2007 RS Venture. this is why I remain subscribed even though o only ride my Venture a few times per year. 2
Woody Posted April 15 #10 Posted April 15 ok I realize this is an old thread, but I'M in need of a fuel pump and I see them from 20 bucks to 400. where is the most reliable place to order from? FIL decided after two years he wanted to try to ride the trike and guess what cranks and dies and there is no noise or vibration from fuel pump, found a blown fuse but it blew again as soon as I connected the fuel pump back up.
etcswjoe Posted April 15 #11 Posted April 15 4 hours ago, Woody said: ok I realize this is an old thread, but I'M in need of a fuel pump and I see them from 20 bucks to 400. where is the most reliable place to order from? FIL decided after two years he wanted to try to ride the trike and guess what cranks and dies and there is no noise or vibration from fuel pump, found a blown fuse but it blew again as soon as I connected the fuel pump back up. Get a Mr Gasket from Oreillys, but you don't have a Venture.
Woody Posted April 16 #12 Posted April 16 1 hour ago, etcswjoe said: Get a Mr Gasket from Oreillys, but you don't have a Venture. Father in law does 1
Paul Martin Posted April 16 #14 Posted April 16 https://www.venturerider.org/forum/forums/topic/58615-what-did-you-do-to-your-venture-today/page/58/#findComment-819668 Check this out. I've driven just over 1300 miles since removing the fuel pump from my 2001 RSV. No issues.
Woody Posted April 16 #15 Posted April 16 10 hours ago, RDawson said: Points stuck? removed the cover and I could open them with no problem, ordered him one with a new filter from ebay
Woody Posted April 16 #16 Posted April 16 8 hours ago, Paul Martin said: https://www.venturerider.org/forum/forums/topic/58615-what-did-you-do-to-your-venture-today/page/58/#findComment-819668 Check this out. I've driven just over 1300 miles since removing the fuel pump from my 2001 RSV. No issues. I did try that but could not get it to work, may have been because it just had 2 gallons of gas in it. I drained the tank because the gas was so old.
Woody Posted 18 hours ago #17 Posted 18 hours ago Well the new fuel pump came in, I replaced the pump and filter but the still only runs with the choke pulled out and will not rive up at all, goes dead as soon as the choke or the throttle is moved. But I can hear the pump run and shut off when the pressure builds up, the old one never even made a noise.
BlueSky Posted 12 hours ago #18 Posted 12 hours ago (edited) 5 hours ago, Woody said: Well the new fuel pump came in, I replaced the pump and filter but the still only runs with the choke pulled out and will not rive up at all, goes dead as soon as the choke or the throttle is moved. But I can hear the pump run and shut off when the pressure builds up, the old one never even made a noise. Probably need to remove the carbs and clean out the jets. this video shows the jets. And another video showing fuel pump points replacement Edited 12 hours ago by BlueSky
Woody Posted 2 hours ago #19 Posted 2 hours ago Bluesky I agree with you, after letting it sit with some seafoam in it I finally got it to rive up but it still will not idle without the choke. I have not tried it this morning but even if it runs I think it will need the carbs cleaned.
