Yammer Dan Posted April 28, 2018 Share #1 Posted April 28, 2018 OK out of gas. It ran for a little while making sure this was what was going on. Clicking like mad!! Turned off, put gas in it, turned back on. NO CLICK!! No Start!! I couldn't have burnt that pump up that easy??? Link to comment Share on other sites More sharing options...
mm482 Posted April 28, 2018 Share #2 Posted April 28, 2018 Tap on the fuel pump and see if it starts pumping. Thepoints are probably stuck. If they stickone time more than likely they will stick again. Link to comment Share on other sites More sharing options...
VentureFar Posted April 28, 2018 Share #3 Posted April 28, 2018 Tap on the fuel pump and see if it starts pumping. Thepoints are probably stuck. If they stickone time more than likely they will stick again. I agree. Do you know where the fuel pump is and what to look for? Left side above the left passenger foot pad. Fuel pump is a 3 inch round cylinder with a black rubber cap. Tape off the cap and see the points. Mine were burned uneven at 15,000 miles. Totally stuck together but possible to unstick just by tapping on them with the key on. If so, buy points not a very expensive fuel pump. Venturefar... Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Bert2006 Posted April 28, 2018 Share #4 Posted April 28, 2018 Common issue on 2nd gens. I bought a new pump, replaced the points in the old one and keep it in the trunk as a back up when on road trips. Link to comment Share on other sites More sharing options...
Yammer Dan Posted April 29, 2018 Author Share #5 Posted April 29, 2018 Warden made sure I didn't get to garage today!!! Link to comment Share on other sites More sharing options...
s.tyler58 Posted April 29, 2018 Share #6 Posted April 29, 2018 Warden made sure I didn't get to garage today!!!Remind that Warden that in London they change the guard 3 times a day! Sent from my SM-T580 using Tapatalk Link to comment Share on other sites More sharing options...
Yammer Dan Posted April 29, 2018 Author Share #7 Posted April 29, 2018 Well That didn't work. Might get time tomorrow to pull it and look over. Have one on way for 15 bucks. Link to comment Share on other sites More sharing options...
Yammer Dan Posted April 30, 2018 Author Share #8 Posted April 30, 2018 Is there a fuse for this thing??? Still learning to speak 2nd Gen..... Link to comment Share on other sites More sharing options...
Bert2006 Posted April 30, 2018 Share #9 Posted April 30, 2018 Well That didn't work. Might get time tomorrow to pull it and look over. Have one on way for 15 bucks. Be really careful with the cheap pumps. There are reports of folk experiencing hydro lock ln engine as a result of fuel being allowed to get from tank to cylinders when bike is off. The OEM pump has backvalve to avoid this. Link to comment Share on other sites More sharing options...
Drews Posted April 30, 2018 Share #10 Posted April 30, 2018 be really careful with the cheap pumps. There are reports of folk experiencing hydro lock ln engine as a result of fuel being allowed to get from tank to cylinders when bike is off. The oem pump has backvalve to avoid this. yes this happened to me stay with the oem or the facet pump Link to comment Share on other sites More sharing options...
vzuden Posted May 1, 2018 Share #11 Posted May 1, 2018 Or remember to turn fuel off at petcock every time you turn off engine. Link to comment Share on other sites More sharing options...
videoarizona Posted May 1, 2018 Share #12 Posted May 1, 2018 Or remember to turn fuel off at petcock every time you turn off engine. :sign yeah that: I make that a habit and do so every time I shut down. Link to comment Share on other sites More sharing options...
videoarizona Posted May 1, 2018 Share #13 Posted May 1, 2018 By the way, the link that I found to order just the pump took me to a Canadian site that won't let me order from the states. I did find another older link but that page doesn't exist. If anyone has a link to a good set of points for the 2nd gen, I'd appreciate it. I do have 2 cheapie fuel pumps...#1 , the points are already bent so they won't last...but the other looks really good. So I'll keep #2 but want to carry points around just in case. TIA Link to comment Share on other sites More sharing options...
Yammer Dan Posted May 1, 2018 Author Share #14 Posted May 1, 2018 I put petcock on reserve and leave it!! This another shortcoming on 2nd Gens?? Link to comment Share on other sites More sharing options...
Flyinfool Posted May 1, 2018 Share #15 Posted May 1, 2018 On a 2nd gen if a float valve leaks, the tank being above the carbs will fill the engine with gas. On the other hand, if a fuel pump fails while on the road, you can gravity feed the engine to get home. Link to comment Share on other sites More sharing options...
Bert2006 Posted May 2, 2018 Share #16 Posted May 2, 2018 By the way, the link that I found to order just the pump took me to a Canadian site that won't let me order from the states. I did find another older link but that page doesn't exist. If anyone has a link to a good set of points for the 2nd gen, I'd appreciate it. I do have 2 cheapie fuel pumps...#1 , the points are already bent so they won't last...but the other looks really good. So I'll keep #2 but want to carry points around just in case. TIA Try this link: https://www.jpcycles.com/product/zz34308/k-l-supply-co-universal-fuel-pump-point-switch-kit Link to comment Share on other sites More sharing options...
videoarizona Posted May 2, 2018 Share #17 Posted May 2, 2018 Try this link: https://www.jpcycles.com/product/zz34308/k-l-supply-co-universal-fuel-pump-point-switch-kit Thanks! Ordered one! Link to comment Share on other sites More sharing options...
djh3 Posted May 3, 2018 Share #18 Posted May 3, 2018 Man $31 bucks for points? Get a pointless pump to replace. Link to comment Share on other sites More sharing options...
Yammer Dan Posted May 4, 2018 Author Share #19 Posted May 4, 2018 Made it to garage with new pump. Got sidetracked. Where did I put that Thing?? Link to comment Share on other sites More sharing options...
rbig1 Posted May 4, 2018 Share #20 Posted May 4, 2018 well at least I'm not the only one. every time I put stuff down I swear it moves. Link to comment Share on other sites More sharing options...
Yammer Dan Posted May 4, 2018 Author Share #21 Posted May 4, 2018 I swear I took it to the garage and laid it on Silver. Fooled around for a while thought I would look it over again. Now I'll have to hunt it up!!! Gotta put some of that stuff away!! Link to comment Share on other sites More sharing options...
