videoarizona Posted April 25, 2014 Posted April 25, 2014 Just got my new-to-me 1989 VR. Wonderful! Scary! LARGE ....Going to be interesting...bit bigger than my 950Tourer...hmm. So far, I've cleaned her up, checked some maintenance items and put the windshield back on. Everything works....so far! Noticed that the rear reflector that wraps around the trunk is held on by what looks like duct tape! Someone looped the tape in little loops and stuck them inside between the reflector and the trunk. Ok.....so this just doesn't seem right to me. The rest of the bike is in excellent shape obviously well taken care of, so I'm curious why the P.O. did this??? Ideas and hints appreciated.... thanks, david
kevin-vic-b.c. Posted April 25, 2014 Posted April 25, 2014 PO did it because they did not know better. Carefully heat the reflector and the trunk body from the inside with a heat gun and work the reflector off VERY carefully. It was original held in place by 2 sided (3M) tape. Go to local auto parts store buy new 3M tape.... clean all areas with something like Methyl hydrate with all old tape removed. I believe the new reflector I bought had 4 strips of about 2 inch long holding it on. Be so careful with this reflector, as far as I know you cannot buy a new one anymore. Welcome to the Venture addiction club
videoarizona Posted April 25, 2014 Author Posted April 25, 2014 Thanks, Kevin. Off to the store tomorrow to get some 3M double sided tape!! david
Marcarl Posted April 25, 2014 Posted April 25, 2014 They might have done things differently in 89, but my 85 was glued in place all around the outer edges. Some of the glue came loose and I had to use an exacto knife to get the rest off. Maybe that happened to your's, kevin, and somebody used two-sided tape, or maybe Yammi decided that the tape was a better idea. Just my opinion though, is that the tape will allow dirt to filter in behind the reflector and make things kind of dirty in there.
Trader Posted April 25, 2014 Posted April 25, 2014 While it is off it would be a good time to put some LED lights in behind as an extra brake light. You have to heat the reflector to loosen the glue and remove the backing plate. But be careful....don't pry on it (I cracked mine) buy a couple of strips of LED lights and wire it up. I used a strip that was like a flat ribbon with the LEDs every inch or so. There was plenty of room to fit between the reflector lens and backing plate. I believe Marcarl just drilled holes in the backing plate for the LEDs....either way it makes a big difference in seeing the brake lights! I always thought just the one brake light just isn't enough....especially buried under the trunk box.
Flyinfool Posted April 25, 2014 Posted April 25, 2014 Is it the red plastic part of the reflector coming off of the black plastic backing, or is it the whole assembly coming off of the trunk? If it is the whole assembly coming off of the trunk, then yes there is double sided foam tape that holds it on, there is also 3 screws from the inside of the trunk to help hold it on there. Someone may have stripped out the screws prying it off and did what they could to get it back on there. I also filled my reflector up with LEDs. Lots of time to do it but well worth it. http://www.venturerider.org/forum/showthread.php?t=41588
Pegasus1300 Posted April 25, 2014 Posted April 25, 2014 If I remember right there a marks in the back of the black backing for places to drill holes to fit light sockets in which could the hold led bulbs or could be used to thread a strip of lets thru.
videoarizona Posted April 25, 2014 Author Posted April 25, 2014 (edited) Well gentlemen, I got the 3M tape and it is great stuff! I didn't get back to check on forum until AFTER I put the tape on. But now know how to get it off as well! (grins) I have the entire wrap around reflector that was taped on with good tape...just not 3M stuff. So I'll be OK regarding LED lights. That will be this summer's project (to hot in Arizona to ride for most of summer) . I'll slip them in the top groove between the reflector and the trunk body. About 1/4 inch. Thanks all! david P.s. Can't get the VR up on center stand. Suspension isn't lowered and air system is working...so no idea at this point. Did read up on how...but that didn't work for me. Tonight a buddy is coming to visit on his HD. We'll take that matter up then. I'm meeting him on the road for dinner, so this will be ride #2 for me and #1 at night. Whoo hoo! Edited April 25, 2014 by videoarizona Add
kevin-vic-b.c. Posted April 26, 2014 Posted April 26, 2014 P.s. Can't get the VR up on center stand. Suspension isn't lowered and air system is working...so no idea at this point. Did read up on how...but that didn't work for me. Tonight a buddy is coming to visit on his HD. We'll take that matter up then. I'm meeting him on the road for dinner, so this will be ride #2 for me and #1 at night. Whoo hoo! Practice ! I could not get my 86 on the center stand at first. I went to a charity thing at a dealer and they had some nice bikini clad young girls washing bikes for a donation....I had to toss in a 20. This gal that was maybe 110 lbs walked over to my bike, spun it around on the side stand pushed it over to the wash area and flipped it up on the center. There must be a trick I say. So.... push down on center stand with right foot until it touches the ground rock bike back and forth til you feel both legs touch. Then as you put your weight on the right foot have right hand on passenger arm rest and pull forward and up. Left hand on left handle bar. Youtube is always a good place to see how.
bongobobny Posted April 26, 2014 Posted April 26, 2014 Also oil up everything that moves on the centerstand...
Rosie1965 Posted April 26, 2014 Posted April 26, 2014 Put all your weight on center stand as you pull up on passenger grab handle, with left hand on left grip as mentioned. I weigh 175 and can pop mine right up. Don't try to fight it and don't try to lift bike. When you pull up on grab handle you are forcing your foot down, not lifting.
paysaw Posted September 26, 2014 Posted September 26, 2014 Is there a difference in the trunk reflectors? I have two of them and they are different thicknesses and the reflector setups are different.One is all red in the back and thin, the other is Red in the center and orange on the sides.Will they still work on all the first gen bikes?
Prairiehammer Posted September 26, 2014 Posted September 26, 2014 Is there a difference in the trunk reflectors? I have two of them and they are different thicknesses and the reflector setups are different.One is all red in the back and thin, the other is Red in the center and orange on the sides.Will they still work on all the first gen bikes? All the factory trunk reflectors were red all around. However, there was an aftermarket accessory trunk light bar that looked just like the OEM reflector, except that it contained light bulbs and had the amber lens at the ends. Perhaps you have one of those and someone has clipped the wires? Or someone replaced the factory red reflectors with the amber lens from the aftermarket? Big Bike Parts, Show Chrome and RIVCO sold the lighted trunk 'reflector' back in the day. If you don't want the red and amber 'reflector', I'll take it.
Condor Posted September 26, 2014 Posted September 26, 2014 Is there a difference in the trunk reflectors? I have two of them and they are different thicknesses and the reflector setups are different.One is all red in the back and thin, the other is Red in the center and orange on the sides.Will they still work on all the first gen bikes? There is a difference between the MKI 83-84, and the 85?.. MKII 86-93. Don't know which MK the '85 trunk falls under... ?
paysaw Posted September 27, 2014 Posted September 27, 2014 I am going to keep it because it it so rare.I tore out the cheesy lighting and installing LED lighting.I will trick it up a little too cause that is what I do.Will post the final product later.Thanks for your help on this guys.
Prairiehammer Posted September 27, 2014 Posted September 27, 2014 There is a difference between the MKI 83-84, and the 85?.. MKII 86-93. Don't know which MK the '85 trunk falls under... ? There is no trunk reflector on the '83 and '84 trunk. The trunk reflector on the '85-'93 is the same for all those years.
cimmer Posted September 27, 2014 Posted September 27, 2014 (edited) Just an FYI, Big Bike Parts still has the replacement lenses for their old rear light bar. You just have to call in to order them is all. I also added a bunch of red led strips to red portion of the light bar to make it a brake light and then added amber LED strips to make the turn signals brighter. I also got a brake light modulator to flash them and it was also able to dim them to 33% brightness as a tail light. http://www.bikevis.com/motorcycle-led-brake-light-modulators.html Here is a link to a previous post with pics.. http://www.venturerider.org/forum/showthread.php?t=71811 Rick F. Edited September 27, 2014 by cimmer added link
Karaboo Posted September 27, 2014 Posted September 27, 2014 All the factory trunk reflectors were red all around. However, there was an aftermarket accessory trunk light bar that looked just like the OEM reflector, except that it contained light bulbs and had the amber lens at the ends. Perhaps you have one of those and someone has clipped the wires? Or someone replaced the factory red reflectors with the amber lens from the aftermarket? Big Bike Parts, Show Chrome and RIVCO sold the lighted trunk 'reflector' back in the day. If you don't want the red and amber 'reflector', I'll take it. So this lighted reflector must be the aftermarket version, correct? It seems like they all should have had the extra turn and tail lights. The extra brake lights are not that bright, though. I will have to fix that this winter.
Condor Posted September 27, 2014 Posted September 27, 2014 So this lighted reflector must be the aftermarket version, correct? It seems like they all should have had the extra turn and tail lights. The extra brake lights are not that bright, though. I will have to fix that this winter. I'd think so. Here's a pic of my '91 and it's a stock reflector. I think the aftermarkets put the end caps in amber as running lights. They didn't need to do that on this '91 since it looks like a Christmas tree when lit up.
Prairiehammer Posted September 27, 2014 Posted September 27, 2014 So this lighted reflector must be the aftermarket version, correct? It seems like they all should have had the extra turn and tail lights. The extra brake lights are not that bright, though. I will have to fix that this winter. Yes, that is the aftermarket with the lighting and amber turn signals in the trunk reflector. Big Bike was the primary retailer for that, although others offered it.
