Peder_y2k Posted September 12, 2013 Share #1 Posted September 12, 2013 Went for a 270 mile round trip day trip into the Cascade Mtns. of WA today in great weather, and my '88VR (52,500miles) achieved 47mpg with two-up load over three passes. Even passed a few trucks going uphill. Odometer confirmed by GPS. If your bike can't deliver same, it needs work.... -Pete, in Tacoma WA USA Link to comment Share on other sites More sharing options...
MasterGuns Posted September 13, 2013 Share #2 Posted September 13, 2013 Link to comment Share on other sites More sharing options...
dingy Posted September 13, 2013 Share #3 Posted September 13, 2013 Went for a 270 mile round trip day trip into the Cascade Mtns. of WA today in great weather, and my '88VR (52,500miles) achieved 47mpg with two-up load over three passes. Even passed a few trucks going uphill. Odometer confirmed by GPS. If your bike can't deliver same, it needs work.... -Pete, in Tacoma WA USA Nobody likes a bragger. Gary Link to comment Share on other sites More sharing options...
Yammer Dan Posted September 13, 2013 Share #4 Posted September 13, 2013 I've broke 50 several times with those 2nd Gens in front of me..... Link to comment Share on other sites More sharing options...
Venturous Randy Posted September 13, 2013 Share #5 Posted September 13, 2013 (edited) Ya done good. The best I have done was 50 mpg going from about 1,300 feet up over 6,000 feet going from Asheville to Cherokee and back to Asheville on the BRP. I wasn't behind a 2nd gen, but I had one behind me that I had to go slow not to loose him. Is there anything you have done that you want to share with us? RandyA Edited September 13, 2013 by Venturous Randy Link to comment Share on other sites More sharing options...
KIC Posted September 13, 2013 Share #6 Posted September 13, 2013 Dang... mine keeps dropping. I just tightened all the clamps and stuff on the carbs and sealed the aircleaner better and although it runs better it now dropped from 33 to 31. I used to get in the low 40's Link to comment Share on other sites More sharing options...
Peder_y2k Posted September 13, 2013 Author Share #7 Posted September 13, 2013 Is there anything you have done that you want to share with us? Bike is bone stock, and I use cruise when I can, drive couple mph over the posted limit... but I have been keeping up on tuning, valve adjustments, spark plug gap, carb specs adhered to, synched, and idle mixture set as perfectly as I can etc. My test to confirm/check my work is placing the back of my hand 2 inches from the end of the muffler to 'feel' the heat, and if cool enough to keep my hand there as long as I want, then it is running right. If I need to jerk my hand away because of heat, then the carbs are off, either rich or lean, and that causes unburned fuel to combust in the exhaust system causing excess heat. I suppose I could use my non-contact infrared thermometer, but then I'd need to put a new battery in it. I can also 'smell' the exhaust that clings to the back of my hand for indications of unburned fuel, and when my hand smells clean, I know the bike is good. There really is something to those super tuners that can stand behind a car/mc and smell how it is running...... BTW, I'm not braggin'......simply confirming where the standard is, and trying to raise the bar. I'm on the hunt for 51mpg two-up..........in the mountains. -Pete, in Tacoma WA USA Link to comment Share on other sites More sharing options...
sandman Posted September 13, 2013 Share #8 Posted September 13, 2013 Great performance. A loaded weight might be more accurate. Wife and myself are both getting larger. What happened to shrinking with age? We can't pull over 41mpg with 40 being the norm. Do know that I have a float needle,seat, problem. When bike sets overnite fuel pump replenishes bowls that seem empty. Good Job Pete!!! Link to comment Share on other sites More sharing options...
RandyR Posted September 13, 2013 Share #9 Posted September 13, 2013 Using the ski lifts to go up to the top of the mountains and then riding downhill is not the way mileage is usually computed. Link to comment Share on other sites More sharing options...
Bob Myers Posted September 13, 2013 Share #10 Posted September 13, 2013 Mine has fallen from mid 40's to a consistent 37-38mpg, getting a weird surge around 220-2500 at partial throttle. Almost feels like a misfire just above idle when in 2nd or 3rd. Ran a couple cans of SF through it, made no difference. probably the diaphragms? Link to comment Share on other sites More sharing options...
Condor Posted September 13, 2013 Share #11 Posted September 13, 2013 A lot of us have found that riding in the twisties and staying out of 5th gear will generally give them better mpg. Happens all the time with my 1stGen, and even with my 2nd.... Link to comment Share on other sites More sharing options...
Flyinfool Posted September 13, 2013 Share #12 Posted September 13, 2013 With the exception of pulling a trailer at 80+, I seem to get 39-40 no matter how I ride. At 160 miles the warning light comes on, I stop at the next station, and it takes between 4.0 and 4.1 gallons. Link to comment Share on other sites More sharing options...
icebrrg3rd Posted September 13, 2013 Share #13 Posted September 13, 2013 I can pull mid to upper 40's if I watch my speed and right hand while on long, continuous rides. But I'm usually riding in TRUE city conditions, 25-30 mph with MANY stoplights that seem to be timed to catch you at all of them. That and short rides (under 10 miles) with the engine cooled down between them means I'm not running at optimum conditions. I usually pull mid 30's because of that. Still beats the upper teens of my van tho. Wish I could pull out & cruise the mountains, got to go a long ways to leave the city and the flatter lands of the midwest. Congrats on the fine-running bike. -Andrew Link to comment Share on other sites More sharing options...
SpencerPJ Posted September 16, 2013 Share #14 Posted September 16, 2013 I don't care what mine gets, I just love to ride her. Link to comment Share on other sites More sharing options...
Yammer Dan Posted September 16, 2013 Share #15 Posted September 16, 2013 I don't care what mine gets, I just love to ride her. :sign yeah that::sign yeah that: I know the higher the MPG the better she is running!! Link to comment Share on other sites More sharing options...
Condor Posted September 16, 2013 Share #16 Posted September 16, 2013 I don't care what mine gets, I just love to ride her. Wonder if you'd be saying that if you were getting 10mpg and having to stop every 50 miles to fill up.... Link to comment Share on other sites More sharing options...
saddlebum Posted September 16, 2013 Share #17 Posted September 16, 2013 Do not really know what mine gets but I when travelling with a small group, I average $1.00 to $1.10 more at every fill stop than they do. Plugs come out looking very clean despite having almost 30,000 KM on them. Exhaust pipe does indicate a rich mixture since the edges of the pipe are somewhat sooty. However the darn thing runs like a dream. It starts at the touch of a button, runs as smooth as a baby's butt, both at Idle or full throttle and goes like a bat outa H***. Even lifts the front wheel a bit when driving hard (and foolish) when I shift into second gear. It will even pull away from a stand still in third gear (Don't ask). For all those reasons I don't want to mess with it. Link to comment Share on other sites More sharing options...
Flyinfool Posted September 16, 2013 Share #18 Posted September 16, 2013 It will even pull away from a stand still in third gear (Don't ask). You know we have to ask?????? Link to comment Share on other sites More sharing options...
