Ozlander Posted September 15, 2012 Posted September 15, 2012 Yep. Or, you could just use some MAP sensors and a volt meter. True, a 6 volt battery, 4 MAP sensors, four cheeeep multimeters, some tubing and a little wire. Done. :cool10:
tz89 Posted September 15, 2012 Author Posted September 15, 2012 (edited) Yep. And really one multimeter would do. Someone handy could build something solid in minutes. Get 4 old MAP sensors, or 4 cheap vacuum sensors (like board mount), and you are good to go. The MAP sensors just drop the signal voltage from the reference voltage in as vacuum increases. They're like a pot (potentiometer). Edited September 15, 2012 by tz89
pmelah Posted September 15, 2012 Posted September 15, 2012 TZ89 pm sent i will attempt to build one and build a nice little portable box for it :cool10:
rbig1 Posted December 25, 2012 Posted December 25, 2012 dang i want to try and build one. but the wife just quit her job. will have to wait till she is back to work. hope i dont loose this thread. need a good challenge other than bike itself. getting tired of it fighting me. might just as well go way over my head. would that work with digital display instead.:pushups: no smiles with smoke over head.
tz89 Posted December 25, 2012 Author Posted December 25, 2012 You can just search for your own posts and find your way...like breadcrumbs in the forest. I'm waiting for my new google phone to arrive and then while it is still raining in Oregon I hope to tackle that alternative display project.
First_N_Last Posted December 26, 2012 Posted December 26, 2012 Really cool... but I'll keep it simple & stick with my 4 port Mercury Sync Tool. JohnnyB
Flyinfool Posted December 26, 2012 Posted December 26, 2012 dang i want to try and build one. but the wife just quit her job. will have to wait till she is back to work. hope i dont loose this thread. need a good challenge other than bike itself. getting tired of it fighting me. might just as well go way over my head. would that work with digital display instead.:pushups: no smiles with smoke over head. Just go to the blur bar at the top of this thread and click on "Thread Tools" and then "Subscribe to this thread" There will be a list of all of the threads that You subscribe to in the "User CP"
Snaggletooth Posted December 26, 2012 Posted December 26, 2012 Or..... go to the bottom right corner to Edit Tags and give it a tag name. Then you can do a tag search from the top search menu and pull it up any time.
motorcycle.jockey Posted June 27, 2013 Posted June 27, 2013 I know this thread is a bit old. I came across someone who did a similar project using some of the same equipment http://www.instructables.com/id/Arduino-Throttle-Body-Syncronization-Shield I'm working on using a Arduino bord like the link above, but I want to use my Android tablet or phone do display 4 graphs. It's going to take me a bit to do this because I need to learn the programming.
tz89 Posted June 27, 2013 Author Posted June 27, 2013 (edited) Thanks for posting this. My project is coming along, but more slowly than I want. I have the graphic display on a computer or cell phone working. Bluetooth is looking like more trouble/expense than benefit, so a cable connection. I am wondering about the practical vs geeky value of on-board vs off-board display. I'm leaning on-board this week. My main push right now is to re-think the MAP sensor solution. The article you posted showed a custom board with 4 surface mount sensors. I have those, but they are about $15 a piece unless you buy a large quantity. The board mount arrangement looks fragile but if done well would hold. My guess is that people working on their bikes want simple, reliable and lower cost, rather than geeky neato. It's gotta be tough. Go ahead and use the latest code version I posted on your own projects. This is so easy to do there is no use copywriting and sinking money into it. I want this to be a low cost do-it-yourself project for bikers so inclined. I'll have updates and photos soon, or at least intend to. Tom Edited June 27, 2013 by tz89
motorcycle.jockey Posted June 27, 2013 Posted June 27, 2013 Thanks for letting me/us the use of your code. I'm thinking of using this Arduino bord, as it has USB compatibility with Android. http://www.adafruit.com/products/563?gclid=CJzM0rqjhLgCFe3m7AoddFwABw I'm using this project as a learning setping stone for another project I have in mind. I want to make a replacement dashbord for my bike using an Android tablet as the display.
Big Lou Posted June 27, 2013 Posted June 27, 2013 CUT THE END OFF AN OLD TIMING LIGHT AN WIRE IT IN THEN JUST CLIP IT ON FOR TACH..
tz89 Posted June 27, 2013 Author Posted June 27, 2013 Interesting. Keep us posted on that dashboard project. I've wondered about it, specifically if one could find technical data sheets or somehow figure out the the incoming signals. I imagine one could build a TCI, too.
GilliganJ Posted June 27, 2013 Posted June 27, 2013 If so you may be able to find development motivation with Zackybilly1 over on the GL1800riders forum his thread http://gl1800riders.com/forums/showthread.php?304851-I-modified-my-Wing-cat-is-out-of-the-bag&highlight=zack is now 581 posts long and quite an entertaining read if you have a lot of spare time that may appeal to other creative minds like TZ Tom's
motorcycle.jockey Posted June 27, 2013 Posted June 27, 2013 CUT THE END OFF AN OLD TIMING LIGHT AN WIRE IT IN THEN JUST CLIP IT ON FOR TACH.. All you need to do fo a tach on the sync gauge is to have the software count the vacume pulses on one of the cyclinders and caluclate the RPM. At least I think that would work. At the shop we have a digital vacume gauge that has an RPM option and it only connects to the vacume ports.
tpak Posted August 21, 2013 Posted August 21, 2013 @tz89 I have been working on a similar project with a couple of folks over on the Yamaha Super Tenere forum and the ADV forum. There was a guy making one called a "Harmonizer" but he has stopped for the time being so some of us are giving it a go. I stumbled across your work after getting going. I am using off the shelf components from FreeScale to hook up with the Arduino. If it is OK with you I am going to use some of your code - I'll publish what I come up with over on the S10/Adv forums and perhaps on GitHub as opensource. Is v01r06 the latest and greatest? If you want to PM me we can exchange email address' - I am just a short term guest on here since I don't have a related m/c. Thanks Chris
tz89 Posted August 21, 2013 Author Posted August 21, 2013 PM sent. I'm still working on the next version. I hope to have something to post with pictures soon. I lent my first version to my brother and it worked fine for him. Please continue to post your ideas and your own attempts to build. I looked up some info on Goldwings. It seems they have an intake manifold on each side and so only have two carbs. That's easy. Honda Valkyries have six carbs, and my next version may help with that.
tpak Posted August 21, 2013 Posted August 21, 2013 PM sent. I'm still working on the next version. I hope to have something to post with pictures soon. I lent my first version to my brother and it worked fine for him. Please continue to post your ideas and your own attempts to build. I looked up some info on Goldwings. It seems they have an intake manifold on each side and so only have two carbs. That's easy. Honda Valkyries have six carbs, and my next version may help with that. Excellent! 6 ... that'd be pain to tune! The S10 is only 2 and my VStrom is only 2. FWIW, you can always tune one at a time keeping one of the ports as a reference. Not perfect but it will do the job.
mrmrva Posted October 7, 2013 Posted October 7, 2013 I registered here just to comment on this great project TZ89, thanks for sharing with everyone. I will take this as my winter project and report how it goes.
tz89 Posted October 7, 2013 Author Posted October 7, 2013 Thanks. I'll be curious to see how far you push it along.
tz89 Posted January 27, 2014 Author Posted January 27, 2014 Yep. Post pics and stories when you get it going.
dna9656 Posted February 9, 2014 Posted February 9, 2014 And SIMPLE TOO!!! If you would make these and shake them down into a handy case I bet you could sell them on e-bay and through other forums. There's nothing like a little spare cash. This is WAY over my head.
billmac Posted March 27, 2014 Posted March 27, 2014 I'll just stay with my Carb tune. I can read four bars easy enough and the hook up will be the same.
tz89 Posted July 5, 2014 Author Posted July 5, 2014 One thing I forgot to mention in the original write up is the benefit of the hose configuration. The hose needed to connect to the MAP sensor is larger than the hose that connects to the carb body. When I was researching this project several builders of the oil-in-tube style mentioned that they needed something to provide vacuum damping to smooth out the readings. So when I built this I carefully cut the larger tube into identical short sections and used a good step-down connector to the other hoses. In this way I'm hoping to provide that vacuum damping and smooth out the readings. Seems to work. btw - my brother in WI is using it today. He says it is fun and why do it any other way (than digital not necessarily my contraption).
