- Yesterday
Thinking about a spring ride for June. Here in Wisconsin.
OrlinEngh replied to OrlinEngh's topic in Watering Hole
Me and Sharon have Thursday off also, I do have a dental appointment in the morning but will be home by noon if anyone wants to come over on Thursday you are welcome. -
Fuel pump point set
Paul Martin replied to lomax's topic in Royal Star Venture Tech Talk ('99 - '13)
I've had to click in and out of the playing video to get the sound to start working - it's probably just Microsoft getting even with Apple. -
I agree with @Marcarl. Looks normal to be and sounds like the repair is a success. FWIW, whenever I ride my SVTC, voltage will fluctuate in small increments between 14.1 V to 14.3 volts. At least that is what I see on my display. Have fun this summer @sleepy2 and put a lot of miles on your bike. Ride safe.
It's probably something at my end, but I can't hear any audio in the video. The link takes me to the vid and it plays, just no sound at all.
- Last week
Voltage is determined by the voltage rectifier, called the regulator/rectifier.
Quite normal.
Have been out a few times and the voltage has not gone over 13.5v. I have tried ridding around 60 to 70klms to get the revs up but volts haven't gone up ,maybe 13.6v once or twice!
Fuel pump point set
As promised in previous post - finally - video explanation of the 2nd gen fuel pump delete. https://1drv.ms/v/c/bcd21b151d642b6c/IQCWFiQ3dw9XQYrlmpiDVNxEAVWjzeyKPDfNSJCAZUmeYNI?e=0sQorC -
Semi-retired started following Weird starting problem
Semi-retired replied to megamile's topic in Royal Star Venture Tech Talk ('99 - '13)
......and..........? -
You can sometimes take it apart and clean up the contacts to make it work again. I think instructions are in the read only library. Look in the sale items, a member (can’t remember who) sells or sold a bypass kit that took the load off the switch and ran everything through a relay. The instructions are here somewhere to make your own, pretty simple. I built one for my 07 several years ago.
Good afternoon to all. Today was a hot day, but I redirected a lot of air to my torso for the ride to and from work. 91 degrees and humid and the SVTC did wonderful. Ride safe and enjoy your night.
BlueSky started following Semi-retired
Semi-retired started following BlueSky
Semi-retired started following RDawson
Trust me...I'll now check the relay cables, which I hadn't thought of....but makes sense since that's where the "click" is coming from.....but, pessimist that I am.....if it DOES turn out to be the switch, is there any way these things can be "tuned up"? Like given a good bath in contact cleaner and/or lubricated with something and makes them "glide like new".....but doesn't SHORT everything out? I think I've seen lots of reports from guys who've REPLACED them....but was that because "money was no object" and it was the easier route to go? Or because it was the ONLY thing that would work because the old ones become JUNK?
TWO EXCELLENT IDEAS I'd not likely have thought of.....especially that SECOND KEY thingy.....which I DO believe I have had sitting in a "key box" by the front door for about 20 years!! LOL I'll try both of these, thanks, bud.
BlueSky started following Fussy startup issues
I had a bad battery in my Kawasaki that checked full voltage but would not supply a load. I finally removed it and took it to an Autozone for load testing and it failed miserably. A new battery fixed er up. On my 07 Venture, I was having problems getting the key to turn and I switched to the other key that looked like it had never been used and it worked just fine??????
Check battery cables and cables on the start relay. But probably the switch.
Very nice. You will love the Wing.
Congratulations on the new ride. No shame in going to a trike. It added years to my riding i would not have had. I had my Venture converted with Hannigan. R Dawson is enjoying it now.
Very Nice Trike, Congratulations 🎊
Semi-retired started following Fussy startup issues
Yes, it's still kinda early in the riding season (not really, I know, but I have a garden, too! LOL) so it's only now that I'm running into this issue after about 5 rides in: My ignition switch (on the '03 Midnight) has been a little feisty for a couple of years now...meaning when I just try to turn it to on from off, it tends to "run into a roadblock" so I've been depressing it slightly while turning...and, Bob's your uncle. No problem starting, ever. Yesterday, however, after turning the bike off to speak to someone in a parking lot, when I went to restart, the "dash" lights came on, just like normal, but when I hit the start button, I heard a single, distinct CLICK that sounded as though it came from under the seat/(battery shelf location). The guy I was talking to was actually a friendly parking security guy and he immediately turned to his vehicle and popped out one of those portable jumper devices. He said he'd heard the click, too, and proudly announced, "Your battery's dead!" I said, "I don't think so; maybe loose, but not dead; it's been starting and running like a champ for a couple of weeks." Nonetheless, between his attaching his wonder-device, and my "fooling with" both the ignition switch AND the kill switch.....after a couple of different combinations and flicking back and forth of BOTH of these items, it finally did start. I drove home and parked outside my closed garage. When I went to start it and bring it inside for the night......NO JOY. Couldn't even get lights on. This morning....went out...turned the key, lights on, hit the start button.......CLICK. DEAD. No amount of turning or fiddling could get .......oh, wait a minute...yes, after I go to the trouble of digging out the multi-meter and the charger....(battery shows 12.3, so it's not her).......suddenly, after coaxing through the Acc position to On, I finally see lights.....hit the Start button and.........CLICK. All dead again. So, IS there a fast, inexpensive solution for that ignition switch? (Which I'm 90% thinking is the cause....unless you guys have "less expensive" opinions, which I'm ALWAYS willing to try! Thanks, as always.
dueyk1111 replied to OrlinEngh's topic in Watering Hole
thankz! -
Welcome to 3, Beautiful Trike
Very nice. They are a smooth ride.
N3FOL started following Well, I went to the Dark Side.
Beautiful Trike! Enjoy the ride.
Hello Venture friends. I have finally gotten to the point that I am not comfortable on the Venture any longer. The last few times I have ridden it, I had trouble getting my feet down quickly, so I started putting them down 20 to 30 feet before I got to my stopping point. This worked but made me very uncomfortable. I got to looking at other options and decided a Wing Trike was the way to go. I found a beautiful 2013 with a Champion conversion that I fell in love with. It's low miles and in excellent shape. The owner on had 3 of the same color so it wasn't hard to talk him into parting with it. I only have a couple of pics so far. I plan on cleaning the Venture up good and putting it up for sale. I absolutely loved riding a Venture, having ridden in every one of the lower 48, but it's time to say goodbye. I will still be around checking on everyone. Steve
E9364 Hwy 56 Viroqua 54665 is our address.
