User Tag List
Page 1 of 2 12 LastLast
Results 1 to 15 of 21
Thread: 09 Venture has oil in air plenum above carberators
  1. #1
    Join Date
    Mar 2016
    Edmonton
    Canada
    AB
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default 09 Venture has oil in air plenum above carberators
    Noticed a misfire developing last 500 miles. Finished changing plugs today on my 09 Venture. It has 38000km or about 25000 miles. About 2500 miles since last oil change. Oil level is middle of glass. When I pulled fuel tank off I noticed some oil on the outside of the air plenum on shifter side. Pulled plenum off that side and there was some oil on inside too. Cleaned up all inside and out. No oil in plenum on brake side. Carbs are clean, but seem to be a bit sticky. Any ideas why oil would be there? Only mod to bike is previous owner took baffles out of mufflers. I've put 17000 km since I bought it in 2016.
    I cleaned everything up, planning on spraying inside of oily carbs with a bit of carb cleaner.
    Pulled air filters and they are good.
    New plugs installed.
    Throttle doesn't return to idle position if you twist it when bike is not running. (Never noticed this when riding)
    Open to suggestions.
    Thanks
  2. #2
    Join Date
    Aug 2006
    Brantford
    Canada
    ON
    Post Thanks / Like
    Mentioned
    104 Post(s)
    Tagged
    0 Thread(s)
    Default Re: 09 Venture has oil in air plenum above carberators
    Throttle cable needs to be lubed and/or is running too tight. It does need a little bit of slack, not much but can't be totally tight.
    My question for the oil issue, did you have the bike idling on the side stand for some time maybe? Just a straw I'm pulling at here, seeing as you already checked the sight glass and air filters. Did you have the bike straight up when checking the sight glass?
    It's nice to be the same
    But
    It's great to be different!
  3. #3
    Join Date
    Apr 2014
    Wilmington, NC
    NC
    Post Thanks / Like
    Mentioned
    19 Post(s)
    Tagged
    0 Thread(s)
    I don't think it's that unusual for oil to be blow up into the air intake since that is where the engine base is vented in most cases. Some owners are putting catch cans on the vent line on autos to catch the oil that would have been blown into the air intake. The harder you run the engine, the more likely this can happen. I wouldn't worry about it unless it's excessive.
    I have noticed my Kawasaki blows some oil into the air intake. I mostly ride it around town and I love winding it up in the gears!
    2007 Yamaha Royal Star Venture 23k miles
    1989 Yamaha Venture Royale 6k miles
    1985 Kawasaki ZN700 4cyl shaft 5k miles
  4. #4
    Join Date
    Mar 2016
    Edmonton
    Canada
    AB
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Checked back through some old posts and oil level seems to be the most common. Old plugs all looked good, so I'm not sure if I've fixed the misfire issue yet. Cleaned everything and will reassemble in morning. What a PIA to change plugs. Looks like fuel filter will be a challenge with my big mitts!
    I check oil level in garage and bike level.
    Thanks.😎
  5. #5
    Join Date
    Jan 2016
    Stephenville
    TX
    Post Thanks / Like
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Oil level too full causes oil in the plenum. With bike level, maybe someone to help,
    have oil fill in the center of the marks.
    Hidden Content
    Bill Donohue
    2001 RSV 44689 miles
  6. #6
    Join Date
    Jun 2009
    Kitchener, Ontario
    Canada
    ON
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Doesn't put the bike completely straight up but put a 2x4 under the kickstand (make sure it has a slight lean to the left....you don't want it going over the other way). Oil should be at or around the halfway mark in the glass.
    Maybe someone else can comment on the throttle cable...but aren't there two? Maybe one of them is binding or broken.
  7. #7
    Join Date
    Sep 2010
    Dunlap, IL
    IL
    Post Thanks / Like
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    At midpoint on the sight glass I will get oil in the air inlet so I keep mine just below midway
    Hidden Content
    The current 2 wheel fleet:
    2012 Venture, 1980 Kawasaki KZ750, 1978 Honda CB750,
    1977 Honda GL1000, 1977 Honda GL1000,
    2007 Kymco Grand Vista
  8. #8
    Join Date
    Dec 2013
    Green Valley
    AZ
    Post Thanks / Like
    Mentioned
    118 Post(s)
    Tagged
    0 Thread(s)
    Just pulled my plenums off today to check plugs and clean up scoot. My left side was a bit gunked up as well...and I keep my oil level at 1/2 mark on site glass standing straight up. I've heard that's normal as the left side is the low side on the stand so any vented crankcase fumes get left there..leaving some gunk. Just cleaned and put back together is what I did. Not worrying about it.
    USAF
    AFRTS Turkey
    1970-1973
    Patriot Guard
    "Some mistakes are too much fun to only make once." - Well worn saying
    "Great ideas often receive violent opposition from mediocre minds." Albert Einstein
  9. #9
    Join Date
    Jun 2009
    Kitchener, Ontario
    Canada
    ON
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    This thread has a diagram of the throttle - from what I see there are two throttle cables.
    https://www.venturerider.org/forum/s...hrottle+cables
    There are pictures in this thread of a 1st gen but the carbs are almost the same - https://www.venturerider.org/forum/s...hrottle+return
    Here is a write up on installing new throttle cables - https://www.venturerider.org/forum/s...hrottle+return
  10. Likes videoarizona, Steven G. liked this post
  11. #10
    Join Date
    Dec 2013
    Green Valley
    AZ
    Post Thanks / Like
    Mentioned
    118 Post(s)
    Tagged
    0 Thread(s)
    Pull the tank and look down on the left side. You can see the pulley where the cables meet. Clean and lube the cables, then do the Adjustments/freeplay suggested by manual at the bottom first, then at the handlebar last. You can buy a cable lube gadget that clamps on the cables and helps get the lube where you want it. Cheap.
    USAF
    AFRTS Turkey
    1970-1973
    Patriot Guard
  12. #11
    Join Date
    Mar 2016
    Edmonton
    Canada
    AB
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Took bike for a 160 km test ride today. Added seafoam to tank and topped up with 10L of premium. Misfire still seems to be there. Dealer wants 4 to 6 hours to sync carbs. I'll use a FLIR camera next week when I'm back at work to check exhaust pipe temps.
    Are there any adjustments I can try before taking to dealer?
    Thanks
  13. #12
    Join Date
    Mar 2017
    Dexter
    KY
    Post Thanks / Like
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Uturn 780 View Post
    Thanks
    The first adjustment I'd make is to find a dealer that will synch the carbs and only charge for the hour or less that it actually takes.
    Faded Blue is the fastest.
  14. #13
    Join Date
    Mar 2008
    Leduc
    Canada
    AB
    Post Thanks / Like
    Mentioned
    23 Post(s)
    Tagged
    0 Thread(s)
    Thanks
    E&S Motorsport in Ft. Sask. charges an hour for syncing on RSV. Id be dropping any dealer who is quoting a 4-6 hour job. Wow! Doug
    "The smallest act of kindness trumps the greatest of intentions"
  15. #14
    Join Date
    Mar 2016
    Edmonton
    Canada
    AB
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by divey View Post
    That's who quoted me 4 hrs.!!
  16. #15
    Join Date
    Mar 2017
    Dexter
    KY
    Post Thanks / Like
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    There are multiple synch gauge set ups out there for sale for diy jobs, I use a simple two bottle homemade rig. Read in the tech library for instructions, it's not hard to do. You can buy the tools cheaper than 4-6 hrs of stealer labor and do it yourself. I check mine a couple times a year, once you do it once it's quick and easy.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
