skydoc_17 Posted August 12, 2008 Share #1 Posted August 12, 2008 Hi All, As I posted earlier, I work night shift and as I was comming home from work I was almost rearended by a Ford F250 while I waited for a light to change. It got me to thinking how could I make myself more visible for other drivers. I started to work changing all of my lighting to LED's. I also added some more lights. Because of the electronic flashers the first gens. have, I had to add Load Resistors to the 4 turn signal lights to get them to flash properly. I changed all of the 1157, 1156, and 194 bulbs to LED's and added 2 LED light bars to the rear as well as a blue dot tail light lens. the Load Resistors get really hot so I mounted them on metal brackets to isolate them from the plastic of the bike. I have enclosed pics of the upgrade, If anyone has any questions, please feel free to ask. Ride Safe and Bee Seen, Earl and Jean. Link to comment Share on other sites More sharing options...
Moakster Posted August 12, 2008 Share #2 Posted August 12, 2008 You can see that bike in the next County. If the cagers miss that you need to set off fireworks to announce your presence. Moakster Link to comment Share on other sites More sharing options...
Mikealiasmike Posted August 12, 2008 Share #3 Posted August 12, 2008 Now THAT is EXCELLENT. Very nice job. Giving me a few ideas now. See what you started? Ride safe, God Bless. Mike Link to comment Share on other sites More sharing options...
Squidley Posted August 12, 2008 Share #4 Posted August 12, 2008 Nice work Earl I know when I had my '86 it was lit up like Christmas in the back, good job Link to comment Share on other sites More sharing options...
sarges46 Posted August 12, 2008 Share #5 Posted August 12, 2008 That is nice....good work. Link to comment Share on other sites More sharing options...
FozzyUSN Posted August 13, 2008 Share #6 Posted August 13, 2008 How did you get the reflective strip on the tour pack to light up? I've looked at mine a few times and the only way I can figure is to drill holes through the back. I don't really want to put any more holes in her that I don't have to. L@@KS GREAT Link to comment Share on other sites More sharing options...
padavidj Posted August 13, 2008 Share #7 Posted August 13, 2008 Nice to see another Steeler Fan rides a Venture! And now I can see your bike all the way down here in Culpeper! Dave:thumbsup2: Link to comment Share on other sites More sharing options...
skydoc_17 Posted August 13, 2008 Author Share #8 Posted August 13, 2008 Hi Fozzy, Well, it's funny you should ask about that! I pryed the reflector loose very carefully with a butter knife (boy was Jean mad!) the LED light bar I put in there has really small wires, I think 18 gage. I drilled 1 3/16 inch hole and was able to power the running light LED bar and the brake light LED bar thru the one hole. Both light strips mounted with double sticky tape and there are no sockets to mount as used with the regular 194 bulbs that are in behind the rear turn signal lenses for example. I used clear silicone sealer to hold the reflector in place. When I was done, the install looked pretty clean. Hope this answeres your question, Earl Padavej, Glad to see a gent from Va. rooting for someone other than the "Deadskins" nice scoot by the way! Earl Link to comment Share on other sites More sharing options...
FozzyUSN Posted August 14, 2008 Share #9 Posted August 14, 2008 I think I understand ;there is a black plastic backing plate behind the red reflector and that is where you installed the small LED's. I will look on e-bay for another reflector and practice on that before I tear into mine. Thanks for the info. Link to comment Share on other sites More sharing options...
