BigBoyinMS Posted July 20, 2008 Posted July 20, 2008 (edited) I guess this is my first real post since joining a few weeks ago. I finally found and bought an '07 Venture this past Sunday. I also have a Road Star that I know pretty well now since I luv to tinker. FYI, I'm coming from having nothing but H-D's for the last 32 years. Here is my problem. (Or not, may be normal for this bike) I have noticed in a lean that there is a sort of grinding noise (guess I feel it more than hear it) that gets more pronounced as you lean more. There is hardly any noise when riding straight up. The PO gave me a new tire for the front that I had installed and now it's less noticeable but still there. The guy that installed the tire said the bearings felt ok. Any ideas? Edited July 20, 2008 by BigBoyinMS
mashley Posted July 20, 2008 Posted July 20, 2008 I have an 08 tour deluxe and my bridgestone tires howl like a wolf when in a lean. Can't wait for them to wear out so I can get some avons. There are many threads on here about similar problem. Just noisy tires I guess.
flb_78 Posted July 20, 2008 Posted July 20, 2008 Tire whine. It goes well with cheese. The Clutch whine makes a fine accompaniment with cedar plank salmon.
BuddyRich Posted July 20, 2008 Posted July 20, 2008 Run your hand over the rear tire. If it feels cupped on the edges that's your noise. The Michelin Commanders are noisy in the turns brand new. Good news is the bike has a 5 year warranty.
royalstarjac Posted July 20, 2008 Posted July 20, 2008 Welcome to the forum! As someone stated above, it's most likely the tires. Switch to Avons now if you can afford it. You'll be glad you did! BTW, what made you switch from HD after so long?-Jack
Squidley Posted July 20, 2008 Posted July 20, 2008 Run your hand over the rear tire. If it feels cupped on the edges that's your noise. The Michelin Commanders are noisy in the turns brand new. Good news is the bike has a 5 year warranty. When they cup they get louder, Avons have been the quietest tires I have use thus far
V7Goose Posted July 20, 2008 Posted July 20, 2008 Disgusting stock Brickstone tires will do that after about 3,000 miles, even when they still look and feel perfect. Dump 'em! Goose
Dano Posted July 20, 2008 Posted July 20, 2008 Since he's been on an HD for the last 32 years, he might even be scraping the pegs and not know what it sounds like!!!!!! Seriously, I would tend to agree on the tires. Dan
BigBoyinMS Posted July 20, 2008 Author Posted July 20, 2008 (edited) Welcome to the forum! As someone stated above, it's most likely the tires. Switch to Avons now if you can afford it. You'll be glad you did! BTW, what made you switch from HD after so long?-Jack I figured tires. The rear was installed 4000 miles ago (per the previous owner) and he had a new matching front that he have me so I'm sorta stuck with these (I'm cheap) unless there is a problem with them. I'll check closer for cupping on the rear. They are Metz 880's. I put Avon Venoms on my Roadie as soon as I got it and luv'em. As far as changing to Yami from H-D... The last few H-D's had been uncomfortable and underpowered plus everytime I rode my back and knee acted up within 30 miles so I had decided to stop riding. After about 3 years my wife made a comment about missing riding so I decided to get something similar but less expensive just to see if I might be able to ride again. The closest thing I found to what I was used to was a Yami Road Star. I now call it a "FatBoy done right". It handles and rides much better than any softtail I've had and no knee or back pain. The reason I got the Venture is because I wanted a bike I could change to my taste (MY bike, the Roadie) and one for us both (OUR bike,the Venture). FYI, I just noticed that we have the same Venture! 2007 Galaxy Blue/Raven Edited July 20, 2008 by BigBoyinMS
V7Goose Posted July 20, 2008 Posted July 20, 2008 Wow, you just muddied the water with that reply! Metzeler 880s on the RSV are quite dangerous IMHO (research many other threads on Metzeler here), but to the best of my knowledge, they don't howl in a lean. They have the same type of tread pattern as Avons and Dunop E IIIs, which are some of the quietest tires you can get! Need to cogitate on this a while to try and grok what is really happening. Goose
BigBoyinMS Posted July 21, 2008 Author Posted July 21, 2008 Well, I guess I'm not going to be riding it much till I can find time to get the rear off the ground and check it out more. I took a quick look and it's either cupping or the "squares" are delaminating. The corners of some (or all) of the "squares" are higher than the rest of the tire. The more I read, the more I think the way to go on the rear is... a car tire.
BuddyRich Posted July 21, 2008 Posted July 21, 2008 I'd go with a Venom. They are great tires. I usually get about 15k out of one.
flb_78 Posted July 22, 2008 Posted July 22, 2008 Well, I guess I'm not going to be riding it much till I can find time to get the rear off the ground and check it out more. I took a quick look and it's either cupping or the "squares" are delaminating. The corners of some (or all) of the "squares" are higher than the rest of the tire. The more I read, the more I think the way to go on the rear is... a car tire. http://lifeisaroad.com/images/darkside.jpg
Roy Hoffman Posted July 23, 2008 Posted July 23, 2008 I had terrible noise when leaning into turns, got rid of the Dunflops and added Venoms no noise at all now. ROY:bighug:
marke Posted July 24, 2008 Posted July 24, 2008 (edited) Like others have mentioned I suspect it might be the tyres. I have been riding for over 30 years and never heard a set of tyres whine like the Dunlops do when you lean the bike. At first I thought I had a problem somewhere in the drive train. Changed to the Venoms and now the bike runs silent. Edited July 24, 2008 by marke typo
Steve S Posted July 24, 2008 Posted July 24, 2008 Well, I guess I'm not going to be riding it much till I can find time to get the rear off the ground and check it out more. I took a quick look and it's either cupping or the "squares" are delaminating. The corners of some (or all) of the "squares" are higher than the rest of the tire.quote] I have been running ME 880s ever since I changed out the stock tires on the 04 "Black Beast". (yes I know, some have seperated). I have noticed that they do develop a "lean whine" after they get about 8K miles on em. It seems to come more from the rear tire than the front. My milage has been running pretty good too. I just turned 54K on the bike last week. I have been getting around 12K on the rear and 18 to 20K out of the front tire. Other than a nail at 4K on one rear tire, I haven't had any problems out of them.
Ponch Posted July 24, 2008 Posted July 24, 2008 Hay BigBoy! Welcome to the site. Regarding the Metz'ers. I have heard and read much about the Metzlers delaminating, but I can only offer you my experience. I bought an 04 used with 16,000 miles on her. She had brand new Metzler 880's. 10,000 miles later, the rear tread had flattened and cupped severely. It still handled ok, but I didn't like the feel of running on the flattened out tread. I didn't notice any unusual noise, but then I'm practically deaf any way. I decided to replace it. My dealer only carries the Metzler. Said he had to much trouble with Avons and switched to Metzler. I thought hard about ordering another brand from somewhere else, but at the last minute bought the 880. So far its great. But I suspect any new tire would feel great compared to a flattened out tread pattern with cupping. It never did delaminate, though. Regards, Ponch
PBJ Posted July 24, 2008 Posted July 24, 2008 Well, I guess I'm not going to be riding it much till I can find time to get the rear off the ground and check it out more. I took a quick look and it's either cupping or the "squares" are delaminating. The corners of some (or all) of the "squares" are higher than the rest of the tire. The more I read, the more I think the way to go on the rear is... a car tire. Like there isn't a subject that hasn't been beat to death!
