VentureFar Posted August 10, 2022 #1 Posted August 10, 2022 I haven't been around much as I have been writing reviews on 2021 Tenere 700 that I got directly from Yamaha for press purposes. It is a fun bike, but I digress. I just got new Metzler 888 Ultras for my 2007 Venture to review and I asked the shop doing the install to check my rear brakes. I am a front brake kind of guy and had the serious wear down of the rear pads before, at about 30k miles. Now with 15k more, the rear pads are a 5%. Basically. gone. This is an issue with the 2nd Gens with uneven wear. Just sharing that if you are new to 2nd Gens, check your rear pads and check them often. 1
BadCatClassics Posted August 11, 2022 #2 Posted August 11, 2022 On 8/10/2022 at 11:16 PM, VentureFar said: I haven't been around much as I have been writing reviews on 2021 Tenere 700 that I got directly from Yamaha for press purposes. It is a fun bike, but I digress. I just got new Metzler 888 Ultras for my 2007 Venture to review and I asked the shop doing the install to check my rear brakes. I am a front brake kind of guy and had the serious wear down of the rear pads before, at about 30k miles. Now with 15k more, the rear pads are a 5%. Basically. gone. This is an issue with the 2nd Gens with uneven wear. Just sharing that if you are new to 2nd Gens, check your rear pads and check them often. Expand Absolutely, since I trail brake often on slow maneuvers I go through rear pads about every 8000 miles. A customer brought a bike in with damage from a fire at the rear caliper as he ignored the noise that indicated metal to metal. The caliper was so hot it actually burned the inspection cover off and melted the inside the of the saddle bag.
Steve S Posted August 11, 2022 #3 Posted August 11, 2022 I was checking out my 2010 RSV in preparation for a long trip and noticed mine were BAD!!! The bike only has 19K miles on it, so I was surprised they were that bad. I've put 13K on it since I bought it in May of 21 so I will be sure to check them closer from now own. Steve
uncledj Posted August 11, 2022 #4 Posted August 11, 2022 Just ordered a set of EBC. I was thinking about it on a recent ride....seemed to make a bit more noise than they should have. Your post prompted me to get that done this weekend....THANKS !!!
RDawson Posted August 11, 2022 #5 Posted August 11, 2022 I’ve got all new pads to install before Asheville, just haven’t had time yet. I got home from Huntsville Monday night to find we were victim to a lightning strike that took out my well pump. Got that replaced yesterday so on to a shop cleaning and bike maintenance.
BlueSky Posted August 11, 2022 #6 Posted August 11, 2022 Could the uneven rear brake pad wear be related to a rear wheel alignment issue? Just wondering?
VentureFar Posted August 11, 2022 Author #7 Posted August 11, 2022 On 8/11/2022 at 1:23 AM, XV1100SE said: Good suggestion mid-summer. Out of curiosity....what are the sizes of the Metzler 888's? OEM sizes? Would like comments regarding how they compare with the E3's especially for wear. I got up to 30,000km on a set of E3's. Expand Yes stock sizes. I am doing a review for UltimateMotorcycling.com and Metzler would only provide them in OEM sizes. I am not looking forward to the 150 front tire and the slow speed handling as well as the harder steering inputs. I am spoiled by the 130 front tire steering. I really won't have that much input on long term wear anymore as I also have a 2021 Yamaha Tenerer 700 that I write reviews on. I have modified this Adventure bike for comfort and it is so fun to ride that literally in the last 12 months I only put 4000 miles on my Venture. I had the original 888's when they first came out and the 880 before that. Just fyi I would get 12,000 miles on the front and 8000 from the rear. I will certainly post my review here. Honestly I think you will get more miles out of the E3 than Metz. Also, I have always liked the rain traction on all the Metz.
VentureFar Posted August 11, 2022 Author #8 Posted August 11, 2022 On 8/11/2022 at 2:31 PM, BlueSky said: Could the uneven rear brake pad wear be related to a rear wheel alignment issue? Just wondering? Expand No, it is a known problem with UNeven wear. At minimum you should swap the inside and outside rear pads when you change rear tires. Fyi pads are not a big deal on this bike.
BlueSky Posted August 12, 2022 #9 Posted August 12, 2022 On 8/11/2022 at 6:01 PM, VentureFar said: No, it is a known problem with UNeven wear. At minimum you should swap the inside and outside rear pads when you change rear tires. Fyi pads are not a big deal on this bike. Expand I checked the rear pads on my 07 and they were wearing evenly.
Joe in WV Posted August 12, 2022 #10 Posted August 12, 2022 Don't know if it was mentioned but you can purchase kevlar? brake pads and they do not lock up as fast. Just replaced all mine and forgot to buy those. Believe they are called EBC . Less rear lock up in a panic situation.
sleepy2 Posted August 12, 2022 #11 Posted August 12, 2022 Just swapped mine from side to side (2012)as they were wearing on inside more than outside.
uncledj Posted August 13, 2022 #13 Posted August 13, 2022 Just ordered a set of EBC. I was thinking about it on a recent ride....seemed to make a bit more noise than they should have. Your post prompted me to get that done this weekend....THANKS !!! Update: Just replaced the rear pads. Inside pad was almost to the metal, so I got to it just in time....Put a little air in the rear shock....(45psi)...Won't clean it up until I get there. Seems that every time I clean her up before hand it'll rain...In any case I'll see y'all there....
BadCatClassics Posted August 15, 2022 #14 Posted August 15, 2022 On 8/11/2022 at 2:31 PM, BlueSky said: Could the uneven rear brake pad wear be related to a rear wheel alignment issue? Just wondering? Expand Not much room for anything to move around. Worn splines on the wheel and bad bearing on the right side might be possible but not likely. Could be a warped rotor or loose caliper. My experience with three of these bikes is they are hard on rear brake pads. When pads start to where they wear most at their hottest spot. Just a function of heavy motorcycle and little brake on the rear.
BlueSky Posted August 16, 2022 #15 Posted August 16, 2022 On 8/15/2022 at 4:27 PM, BadCatClassics said: Not much room for anything to move around. Worn splines on the wheel and bad bearing on the right side might be possible but not likely. Could be a warped rotor or loose caliper. My experience with three of these bikes is they are hard on rear brake pads. When pads start to where they wear most at their hottest spot. Just a function of heavy motorcycle and little brake on the rear. Expand And the rear brake grips really well, maybe too well!
larrydr Posted August 16, 2022 #16 Posted August 16, 2022 Over the years of serving bikes , I have seen a ticking wheel cylinder cause problems much like that ....I like to mount the rotor in my metal lathe and take a power sander to the rotor as it spinning , sometimes tiny bits or road rash and bits of the pads stuck to the rotor cause problems
