Chaharly Posted January 31, 2012 Share #1 Posted January 31, 2012 I have an 83 1200 and i need the complete carb rebuild kit. I'm looking for a cheap one, and hopefully someone can help. Any info would be much appreciated Thanks -CJ Link to comment Share on other sites More sharing options...
utadventure Posted January 31, 2012 Share #2 Posted January 31, 2012 (edited) If I remember correctly, there isn't a "kit" available, you have to purchase the parts separately. Clean it well. You might not need any internal parts. Remove the diaphrams and check them for rips or pinholes. Pinholes can be fixed but tears should be replaced. There was a special price worked out for replacements. A little searching will find them on the site. http://www.venturerider.org/forum/showthread.php?t=32943 While you have it apart, you might want to adjust the needles. This can improve the fuel mileage. Again, if you needles don't have adjusters, you can change it changing the washers. There are instruction on the site also. http://www.venturerider.org/forum/showthread.php?t=28432&highlight=needle+shim Dave Edited January 31, 2012 by utadventure Link to comment Share on other sites More sharing options...
Chaharly Posted January 31, 2012 Author Share #3 Posted January 31, 2012 If I remember correctly, there isn't a "kit" available, you have to purchase the parts separately. Clean it well. You might not need any internal parts. Remove the diaphrams and check them for rips or pinholes. Pinholes can be fixed but tears should be replaced. There was a special price worked out for replacements. A little searching will find them on the site. http://www.venturerider.org/forum/showthread.php?t=32943 While you have it apart, you might want to adjust the needles. This can improve the fuel mileage. Again, if you needles don't have adjusters, you can change it changing the washers. There are instruction on the site also. http://www.venturerider.org/forum/showthread.php?t=28432&highlight=needle+shim Dave Thank you very much Link to comment Share on other sites More sharing options...
Cougar Posted January 31, 2012 Share #4 Posted January 31, 2012 http://www.randakks.com/ His stuff is the BEST, I used a kit for a 1100 and worked great tried the cheaper one's but they failed. his stiff is worth the money spent Link to comment Share on other sites More sharing options...
motorcycle.jockey Posted January 31, 2012 Share #5 Posted January 31, 2012 I've heard that the 1200 Vmax carb rebuild kits will also work. Link to comment Share on other sites More sharing options...
djh3 Posted January 31, 2012 Share #6 Posted January 31, 2012 Give this place a look over. When I needed some parts for my Kawai they had best prive. http://www.powersportsplus.com/ Link to comment Share on other sites More sharing options...
Squidley Posted February 1, 2012 Share #7 Posted February 1, 2012 I have an 83 1200 and i need the complete carb rebuild kit. I'm looking for a cheap one, and hopefully someone can help. Any info would be much appreciated Thanks -CJ CJ, Here are the kits I purchased from this ebay seller that were just installed in my carbs I rebuilt. http://www.ebay.com/itm/Yamaha-VMX12-V-Max-Carburetor-Repair-Kits-VMX1200-VMAX-/380406812168?_trksid=p4340.m185&_trkparms=algo%3DSIC.NPJS%26its%3DI%26itu%3DUA%26otn%3D5%26pmod%3D380375065642%26ps%3D63%26clkid%3D6009930292903665511 Link to comment Share on other sites More sharing options...
