ratman50 Posted January 20, 2010 Share #1 Posted January 20, 2010 I want to move the trunk back the one inch that is allowable. Has anyone done this? There are hard rubber guides in the way can they be moved as well or cut with out any problem? Link to comment Share on other sites More sharing options...
Seaking Posted January 20, 2010 Share #2 Posted January 20, 2010 I want to move the trunk back the one inch that is allowable. Has anyone done this? There are hard rubber guides in the way can they be moved as well or cut with out any problem? Ooh Ok I'll ask.. out of curiosity, why move the trunk back an inch? Not sure about how to do it, but it's not hard removing the trunk... Link to comment Share on other sites More sharing options...
ratman50 Posted January 20, 2010 Author Share #3 Posted January 20, 2010 I am short and fat and the wife is also larger then most when wearing clothing she pushes the back rest forward. really I want to try to avoid paying tolls on the 407 Link to comment Share on other sites More sharing options...
LilBeaver Posted January 20, 2010 Share #4 Posted January 20, 2010 I believe that there is actually is an additional set of holes setup so that all you need to do is pull the bolts out, slide it back and re-insert the bolts (you may need nuts for the ends of one of the sets) but on some RSVs (I presume all, but maybe they stopped after a particular year) that's all you've got to do. I believe someone has some pictures in here of how to do it. I know on mine it was pretty easy. Good luck!! Link to comment Share on other sites More sharing options...
Seaking Posted January 21, 2010 Share #5 Posted January 21, 2010 I am short and fat and the wife is also larger then most when wearing clothing she pushes the back rest forward. really I want to try to avoid paying tolls on the 407 Cough cough but if you ride to the left or right of the centre line the camera can't cough cough pick up your plate.. I've never been sent an invoice yet when ever I go through there on the bike.. even on the VStar with it's highly visible plate.. cough cough.. (out of province people will have an invoice sent to them once the camera correlates the plate info to your home address.. ) Link to comment Share on other sites More sharing options...
straycatt Posted January 21, 2010 Share #6 Posted January 21, 2010 when wearing clothing she pushes the back rest forward. Soooo, when she doesn't wear clothes she doesn't push the backrest forward???? Ding, ding, ding, problem solved...... Link to comment Share on other sites More sharing options...
KiteSquid Posted January 21, 2010 Share #7 Posted January 21, 2010 IIRC when I looked at moving mine back, I noted that there is a molded rubber mounting thingey glued to the back bottom of the trunk that you will have to relocate to make the move. Other than that, it looked to be easy to me, but MrsSquid said she did not want it moved. AND IIRC, if you look in the bike assembly manual, there are written instructions. Link to comment Share on other sites More sharing options...
StarFan Posted January 21, 2010 Share #8 Posted January 21, 2010 I want to move the trunk back the one inch that is allowable. Has anyone done this? There are hard rubber guides in the way can they be moved as well or cut with out any problem? Well, why not relocate it thoroughly and move it back about two thousand miles. I´ll PM you my address in Iceland,,,,,,,,,, Link to comment Share on other sites More sharing options...
painterman67 Posted January 21, 2010 Share #9 Posted January 21, 2010 not to point you in another direction, but doesnt the back rest on your bike say solo riding only. Reason I'm asking is mine says solo only. My wife and I are in the same boat so to speak as you. We found that if we removed the back reat she had plenty room and I could just get closer to her and didnt need the backrest. david Link to comment Share on other sites More sharing options...
Freebird Posted January 21, 2010 Share #10 Posted January 21, 2010 I have the Corbin with the built in backrest. If it ever said "solo" only, I never saw it. I do have my trunk moved back the 1". My wife isn't very big but still likes the extra room. Link to comment Share on other sites More sharing options...
Cougar Posted January 21, 2010 Share #11 Posted January 21, 2010 Yes, you can move it back. I have done it. wife likes it better especially with my backrest in front of her. Link to comment Share on other sites More sharing options...
Pic Posted January 22, 2010 Share #12 Posted January 22, 2010 I moved mine back. Have an 07 and had to buy nuts for the back holes. I went ahead and bought longer bolts for the back 2. An inch makes a big difference in room for the passenger. My girlfriend no longer pushes on the drivers backrest. Link to comment Share on other sites More sharing options...
alwrmcusn Posted January 7, 2012 Share #13 Posted January 7, 2012 I'm not finding those pictures to guide me on the relocation of my '09 RSV trunk. Can anyone point them out to me? I'm just not using the right search terminology I guess. Link to comment Share on other sites More sharing options...
Freebird Posted January 7, 2012 Share #14 Posted January 7, 2012 I don't think you really need a guide. Just remove the 4 screws in the bottom of the trunk. Slide it back about an inch and you should line up with the other set of holes. Link to comment Share on other sites More sharing options...
Cougar Posted January 7, 2012 Share #15 Posted January 7, 2012 :sign yeah that:Pretty simple job. no photos needed for this one BUT : If your so inclinded and you do this, TAKE pictures step by step and Freebird will add it to the tech section for the next person to view Link to comment Share on other sites More sharing options...
alwrmcusn Posted January 7, 2012 Share #16 Posted January 7, 2012 Raining for the next few days here in east Tennessee (at least on and off), so when I give it a look see I'll try to get decent photos and make them available. Just four screws? No need to remove anything else like the CB unit?? Link to comment Share on other sites More sharing options...
XV1100SE Posted January 7, 2012 Share #17 Posted January 7, 2012 Unstick the rubber from the bottom of the trunk because when you move it back it won't line up with the rail that currently supports it. Also...there are nuts welded to the support under the trunk where the bolts currently go. Moving the trunk back you might have to put two nuts underneath (trying to recall from memory) Moving the trunk back is usually done when you add passenger armrests. Link to comment Share on other sites More sharing options...
Cougar Posted January 7, 2012 Share #18 Posted January 7, 2012 Nope, Just remove screws and slide trunk back to the next holes, re-install screws thinking I might have had to get a couple longer bolts. not sure as it has been so long ago I did this. you may not have to. I had to move mine back do to my Trike convertion my wife said she was to confined after the install. now she is happy Thanks for the photos. Jeff Link to comment Share on other sites More sharing options...
alwrmcusn Posted January 8, 2012 Share #19 Posted January 8, 2012 Thanks Cougar....planning (hoping at least) to trike my Venture in the next few months. Perhaps I should just wait and let Hannigan take care of the trunk. The reason I was thinking of moving the trunk was because I put the replacement passenger backrest on. Hannah and I thought it would provide a little extra support for her. Since it is about 3 inches taller and the "arms" are a bit longer. Only had it on there for a couple of rides and so far she likes it. Link to comment Share on other sites More sharing options...
Cougar Posted January 8, 2012 Share #20 Posted January 8, 2012 Yep and Yep... WAIT until the trike mod is done before bothering with the trunk. you will have to riase the trunk up just a tad with shock rubber washers to bring the back of the trunk up over the trike rear end (outer trike body lip) anyways. I will almost bet that your wife will get on after the mod is done and she will say this does not feel right and it will feel to closed in for her. I also added arm rest as well, not sure if yours are DimondR's or not. BUT I had to cut ours done 2 or 3 inches and re-welded. worked out GREAT! not sure why they make them so tall wife is happy now with them cut. If you have any qustions feel free to call me. Jeff Link to comment Share on other sites More sharing options...
alwrmcusn Posted January 11, 2012 Share #21 Posted January 11, 2012 The passenger backrest is the STAR unit. It is very similar to the original except about 3 inches higher and the "arms" curl out a couple of extra inches. I believe it is actually built by Corbin but I'm not 100 percent sure. I'm thinking that I will probably take the RSV to Hannigan in Murray, KY for the "triking". It's a VERY expensive job and the $$$ required are somewhat slim this past couple of years. Seems that my Navy retirement and SS checks did not qualify for any sort of increases. They both did qualify for decreases each year however! Link to comment Share on other sites More sharing options...
gunboat Posted January 14, 2012 Share #22 Posted January 14, 2012 just did this little mod myself. found that you do have to unstick the rubber "u" bumper and move it forward. used the same 4- bolts to reinstall. now just have to do some saddle time with the co-pilot to see if she likes it. reguards don c. Link to comment Share on other sites More sharing options...
wrenchrob Posted January 16, 2012 Share #23 Posted January 16, 2012 I am considering trying this also. I have one question for anyone who has tried this. With the passenger sitting further back how does this affect the handling and does it put much more load on the rear shock and ride height? Ok three questions. Link to comment Share on other sites More sharing options...
tommycole Posted January 16, 2012 Share #24 Posted January 16, 2012 I bought a set of carbon ones armrest, i think he had some pics. I didnt move the rubber under rear of trunk but probably should have. Link to comment Share on other sites More sharing options...
gunboat Posted January 16, 2012 Share #25 Posted January 16, 2012 hi rob i can't answer your questions because i have a '99 rsv trike converson from motor trike. but i don't feel you will have any problems. reguards don c. Link to comment Share on other sites More sharing options...
