Midrsv Posted April 14, 2009 Share #1 Posted April 14, 2009 Last weekend I decided to synch my carbs again, it's been a few months. I hooked the carbtune up and the carbs were pretty close but I had to adjust one to get them perfect. After that I decided to switch the connection tube around at the top of the carbtune. They were out of synch agian. So I started experimenting with the different tubes. Took one carb tube and moved it through all four positions and found a different reading at each position. So I kept making adjustments based on a single gauge position until I had the same reading from each carb at that one gauge position. Then reconnected all four and there was some variance between the gauge tubes. Has anyone else experienced this? DT Link to comment Share on other sites More sharing options...
1sttenor Posted April 14, 2009 Share #2 Posted April 14, 2009 I have only did mine once, but is there a chance that one of the hoses has a blockage? Link to comment Share on other sites More sharing options...
Midrsv Posted April 14, 2009 Author Share #3 Posted April 14, 2009 I have only did mine once, but is there a chance that one of the hoses has a blockage? I don't think so. I kept the same hose on each carb and moved it from one gauge tube to the next. Had there been a blockage it should have still read consisitently across the gauge. DT Link to comment Share on other sites More sharing options...
midnightventure Posted April 14, 2009 Share #4 Posted April 14, 2009 I suspected this but then my mercury carb stick was always having the mercury separate and I didn't totally trust it. I believe the Carbtune needs to be as perpendicular as possible. Link to comment Share on other sites More sharing options...
davecb Posted April 14, 2009 Share #5 Posted April 14, 2009 I believe you are supposed to start on a certain carberatur. Not sure which one, but I have read that somewhere.... Link to comment Share on other sites More sharing options...
KiteSquid Posted April 14, 2009 Share #6 Posted April 14, 2009 I don't own one ,but does the owners manual for the Carbtune have a procedure for adjusting the channels??? BTW this is the main reason I have a four Chanel mercury manometer (AKA Mercury carb stick) nothing to go out of adjustment. Link to comment Share on other sites More sharing options...
N3FOL Posted April 14, 2009 Share #7 Posted April 14, 2009 I've never really thought about switching hoses after my initial carb synch. The next time I do my carbs, I may as well give it a try and see the variation. So far, I've never had any problems and synching my carbs seems to help a lot on performance and peace of mind. Link to comment Share on other sites More sharing options...
Midrsv Posted April 14, 2009 Author Share #8 Posted April 14, 2009 I've never really thought about switching hoses after my initial carb synch. The next time I do my carbs, I may as well give it a try and see the variation. So far, I've never had any problems and synching my carbs seems to help a lot on performance and peace of mind. I would be interested in your results. I would like to add that my carbtune has only been used 5 or 6 times. DT Link to comment Share on other sites More sharing options...
dans87vr Posted April 14, 2009 Share #9 Posted April 14, 2009 I didn't purchase a carbtune, but got one from dennis kirk. It came with a multi port manifold (6 hose connections on one plastic tube). In the instructions it said to connect all 4 lines to one carb to calibrate the sync tool (get all 4 bars level). It had adjustment screws at the bottom of each bar on the sync tool. Before I sync my carbs I do this procedure just to make sure all four levels are the same. After the first time there has been little or no adjustment needed to calibrate the sync tool. Most auto stores will have a multi port hose connector or using 3 T-connectors will also get the job done. Link to comment Share on other sites More sharing options...
V7Goose Posted April 14, 2009 Share #10 Posted April 14, 2009 I didn't purchase a carbtune, but got one from dennis kirk. It came with a multi port manifold (6 hose connections on one plastic tube). In the instructions it said to connect all 4 lines to one carb to calibrate the sync tool (get all 4 bars level). It had adjustment screws at the bottom of each bar on the sync tool. Before I sync my carbs I do this procedure just to make sure all four levels are the same. After the first time there has been little or no adjustment needed to calibrate the sync tool. Most auto stores will have a multi port hose connector or using 3 T-connectors will also get the job done. This is interesting. There are multiple reasons why I dislike the Morgan Carbtune, but one of the biggest is that the instructions on a brand new one that I looked at last summer specifically stated that it could NOT be adjusted or calibrated after it left the factory! And to make matters worse, that particular one had one rod that read significantly low from the other three. Maybe you are saying that you bought a DIFFERENT sync tool? With any vacuum or pressure reading tool designed to read multiple inputs simultaneously, it is imperative that the tool be checked for exactly equal readings before the first use and periodically after that. The best way to do this is by using a simple manifold that connects all the ports together and to a single vacuum source. There are lots of ways to make a manifold like that, but one of the easiest is to simply buy a 4-port air valve at an aquarium shop. Goose Link to comment Share on other sites More sharing options...
KiteSquid Posted April 14, 2009 Share #11 Posted April 14, 2009 (edited) AFAIK there are four afordable carb sync tools on the maket for four cylinder motorocycles. The Morgan Carbtue Motion Pro Emgo Guage Set And my personal choice the mercurey manometer (AKA mercurey Carb Sick) that costs about $55 and will NEVER go out of adjustment, however the mercurey is not a nice substacne to have around your home... See photos below. http://www.carbtune.co.uk/Images/SSL11411SC.jpg http://www.motionpro.com/images/enlarged/08-0411.jpg http://www.denniskirk.com/denniskirk/b2c/product_images/3/8/0/600pix/38040005.jpg http://www.saber-cycle.com/store/media/parts/08-010.jpg Edited April 16, 2009 by KiteSquid Link to comment Share on other sites More sharing options...
dans87vr Posted April 14, 2009 Share #12 Posted April 14, 2009 Mine is the motion pro, here is a link from dennis kirk http://www.denniskirk.com/jsp/product_catalog/Product.jsp?skuId=&store=&catId=&productId=p282760&leafCatId=&mmyId= Link to comment Share on other sites More sharing options...
BuddyRich Posted April 14, 2009 Share #13 Posted April 14, 2009 Also check the hoses. If you get a 5 way vac splitter and connect one to the bike and 4 to the carbtune they should all read the same Since its only 1 vac source. A 5 way spliiter is fairly cheap. Or a 3 way and a 2 way connected together ( so you wind up with 5 inputs)That's what I do to calibrate it. Found it was dirty once. Cleaned it and it was fine afterwards. Link to comment Share on other sites More sharing options...
Midrsv Posted April 14, 2009 Author Share #14 Posted April 14, 2009 I didn't purchase a carbtune, but got one from dennis kirk. It came with a multi port manifold (6 hose connections on one plastic tube). In the instructions it said to connect all 4 lines to one carb to calibrate the sync tool (get all 4 bars level). It had adjustment screws at the bottom of each bar on the sync tool. Before I sync my carbs I do this procedure just to make sure all four levels are the same. After the first time there has been little or no adjustment needed to calibrate the sync tool. Most auto stores will have a multi port hose connector or using 3 T-connectors will also get the job done. I like the sound of being able to calibrate prior to synching. I'm buying a motion pro unit. Dennit Link to comment Share on other sites More sharing options...
Dano Posted April 14, 2009 Share #15 Posted April 14, 2009 I bought a motion pro synch pro, do not like it. Easy to suck the liquid out of it, if liquid separates its a PITA to get the air bubble out. I have found since, that to synch the tool, both of the screws on the middle channels have to be backed out all the way. If I borrow my next door neighbors mercury stick, no adjustment neccesary. That's IF I get to borrow it from him! Dan Link to comment Share on other sites More sharing options...
RossKean Posted April 14, 2009 Share #16 Posted April 14, 2009 Has anyone used the Emgo mechanical vacuum guage unit? Price seems good but I am wondering if they are sufficiently precise to set these carbs up properly. Ross Link to comment Share on other sites More sharing options...
N3FOL Posted April 14, 2009 Share #17 Posted April 14, 2009 AFAIK there are three afordable carb sync tools on the maket. The Morgan Carbtue Motion Pro Emgo Guage Set See photos below. http://www.carbtune.co.uk/Images/SSL11411SC.jpg http://www.motionpro.com/images/enlarged/08-0411.jpg http://www.denniskirk.com/denniskirk/b2c/product_images/3/8/0/600pix/38040005.jpg I have the Morgan Carbtune and have used it twice with no problems. I will be more concerned with the condition of the rubber hoses after a few years or perhaps after using it 10 times or more. It is just like the rubber caps on the carbs...they deteriorate over time. Link to comment Share on other sites More sharing options...
V7Goose Posted April 14, 2009 Share #18 Posted April 14, 2009 Has anyone used the Emgo mechanical vacuum guage unit? Price seems good but I am wondering if they are sufficiently precise to set these carbs up properly. Ross I have been using a set of four sealed mechanical vacuum gauges for 30 years that look very similar - even bought them from JC Whitney way back when. Frankly, not only are they trouble free, they are much more accurate than the Morgan carbtune. Goose Link to comment Share on other sites More sharing options...
Squeeze Posted April 14, 2009 Share #19 Posted April 14, 2009 I don't like the Carbtuine either. Found my Buddies Set sticking on 3 of 4 Rods, but all were different. I use a 4 Gauge Vacuum Dial Set. Problem solved(i.e. wasn't existing to begin with). Link to comment Share on other sites More sharing options...
Midrsv Posted April 14, 2009 Author Share #20 Posted April 14, 2009 I bought a motion pro synch pro, do not like it. Easy to suck the liquid out of it, if liquid separates its a PITA to get the air bubble out. I have found since, that to synch the tool, both of the screws on the middle channels have to be backed out all the way. Dan Now you've got me reconsidering my last post. Does anyone know if the 4 dial gauge set can be calibrated? DT Link to comment Share on other sites More sharing options...
KiteSquid Posted April 15, 2009 Share #21 Posted April 15, 2009 It should be able to calibrate it, you would probably have to remove the gauge glass and adjust. Why did the EPA have to make mercury so inaccessible????????? I have a set of mercury carb stick, so mine will NEVER go out of adjustment!!!!!!! I just have to NOT spill my mercury.... Link to comment Share on other sites More sharing options...
coltrain Posted April 15, 2009 Share #22 Posted April 15, 2009 I'm having the same EXACT problem with my morgan carbtune man! Link to comment Share on other sites More sharing options...
V7Goose Posted April 15, 2009 Share #23 Posted April 15, 2009 Now you've got me reconsidering my last post. Does anyone know if the 4 dial gauge set can be calibrated? DT The dial gauges can be calibrated. The instructions specifically tell you to remove the glass and reposition the pointer if necessary. Just make sure you pull the pointer off the shaft and replace it instead of trying to turn it! Goose Link to comment Share on other sites More sharing options...
Jrichard Posted April 15, 2009 Share #24 Posted April 15, 2009 HEY COLTRAIN---------------I AM in sterlinga!!! off of Sterling blvd.------------I have a carbtune. if u r interested in checking the integrity of the one u have w/ mine!! Link to comment Share on other sites More sharing options...
skydoc_17 Posted April 15, 2009 Share #25 Posted April 15, 2009 Has anyone tried to contact Morgan to find out what they will do for you if your Carbtune isn't calibrated correctly? I was just wondering. Earl Link to comment Share on other sites More sharing options...
