This stream auto-updates
  1. Past hour
  2. Getting ready to head out now.
  3. Today
  4. I am looking for a 156x80x15 run flat for my 2002 RSV. If anybody knows of one please let me know. thank you
  5. I run 165x80x15 on my 2002 RSV, and get 25k. love it
  6. I got 16k on my 1st nexen, 165x80x15. Was impressed with it. I put 10k on it in 2 trips and 23 states, rode dragon tail and mounts 1000s of miles. Love the way it handles. Had flat and will have to change because side wll damage fron a nail.
  7. I love my 98 RSTD, but the issues continue. The bike idles great with the choke in, when warmed up it idles great...until it gets heated up. Once I've ridden for about half an hour or so, when I gear down the idle goes wild, revving very high. I have turned down the idle screw but to no avail. While riding it sounds great. Any thoughts? Thanks in advance.
  8. Yesterday
  9. I run tires in the 70 to 90 dollar range and am satified.
  10. How will the G-force hold up if you have a flat???? Will it stand without air till you can get it fixed??? Have you let air out while standing to see if it holds up.
  11. I got 40k on a front shinko. great tire
  12. I have worn dunlaps out at 4500 miles and regulat bike tires out around 8 to 10k. I got 40k out of a shinko on my front, took it off because started to get a little wobble in handle bars, still had good tread. Put on another shinko, great tire in my opnion.
  13. I have been lookking for a run flat for my 2002 RSV, size 165x80x15, but can not find one. I would love to try one if I can find one.
  14. I used a Federal 674 from walmart and got 25k, then put on nexen and had flat at 16k and tire still looked like new, It has hole on edge of side wall, when I pluged it, it made a bludge in side wall. Will not trust it, will put new tire on. I just put on a Peltas tire that I ordered. Have not ridden it yet.
  15. Did ride the '06 double dark. I'm not double dark on the 2018 either. On it I still run the factory model. 45K miles and only 3rd front. Which I don't mind the mileage on the front. The back was killing me. I did the factory model as the second tire on the back and only go 5100 miles before having to replace it. Complained to the shop and they agreed to prorate the 3rd with a factory model and got 6000 miles on it. That's wen I pulled the trigger on the g-force. BTW: I believe the G-Force has a run flat that some use on the 2018 and newer.
  16. Got back home last Friday from Sturgis Motorcycle Rally on the bike. 970 miles in two days!!,and yesterday afternoon I was rotating tires on the car and checking tire pressures. I thought “why don’t I do all the vehicles as long as I have everything out?” So I crawled under the right saddlebag to check the rear tire and found the muffler hanging down. I had lost the rear mounting bolt and rubber isolator. So I dig around in my treasures and come up with a suitable replacement and voila!, she is up and running again!
  17. Voltage reg is common on the second gens. Stater or stater connections are also worth checking.
  18. RDawson
    Vogel 2025
    Anybody heading down today beware of flooding in the Chattanooga area if that’s your route.
  19. We’re pulling out this morning to head down there.
  20. Right now I’m running a Shinko front. The fronts last long enough I haven’t gone double dark.
  21. what tire do you darksiders run on the front then?
  22. I’m headed to the Vogel rally today, mountain twisties darkside annually. Turning isn’t an issue.
  23. Additionally, I thought there was a little more counter steer when I first went dark but that feeling dissipated quickly. I 100% notice better stopping and better handling in wet weather. There was no difference in cornering traction. Tires have lasted 20 -30 K miles compared to 5 - 8 K with MC tires.
  24. On the '06 I ran a Nexan. on the '18 I run a g-Force 2 205/55/16
  25. +1 on the Nexen. Easiest tire change I've ever done and great ride/performance.
  26. Yep Nexen is what I use. Look under the forums tab and scroll down to darksiders.
  27. Last week
  28. Lisa and I will be heading down Thursday morning.
  29. The carb tuner is sold.
  1. Load more activity
