- Past hour
Found parts; ordered used replacement. Still have to order o-rings and crush washers. Have heard that it is possible to remove without removing carbs; I hate to mess with the carb boots as I'm afraid they might be brittle and/or crack (106,000 miles) and lead to bigger more gnarly things. Also wondering if I placed new seals on water pump shaft properly... Replacing radiator, fan, possibly thermostat next week to prep for long trip Juneteenth; would like to check pump and Twinkie at the same time (I think pump will be easier with radiator out). I have to stop this oil in coolant thing before it causes anything more. Any advice is greatly appreciated; anyone in the Tampa area who might have knowledge and be willing to help would also be appreciated.
- Today
Marcarl started following Thank You VentureRiders and Starting Issues on 2009 Royal Star Tour Deluxe
On the left side of the engine there should be a cover for the stator, in the middle of that cover should be a large chrome srewcap, (flat head). Take out that screw cap behind it will be a nut. That nut is on the end of the crank shaft. See if the engine will turn over by turning the nut. With the plugs out it should turn easy. No gasket needed, it has a rubber seal.
I wish I had that riders riding skills!
Thank you everyone for your feedback and suggestions. I drained and replaced the oil this morning. It definitely had some gas in it. I refilled with fresh oil and changed the filter. Then I moved on to removing the tank and pulling the plugs. Right rear plug appeared wet, the others were dry. I tried to turn the motor with the plugs out, but it won't turn. Solenoid clicks. Also, can't seem to get it into first gear. Not sure what to do next, but this is more than a carb problem. Any suggestions for next steps?
Stick around, you never know what might be beneficial down the road and who you can help.
BlueSky started following Thank You VentureRiders , Goldwing dirt bike and New Helmet
Who knew a Honda Goldwing could double as a dirt bike?
- 1 reply
- 1
I retired from riding back in September. I'm not leaving here tho. Too many friends to just walk away from. I just wont be leading anymore rides.
A Biker is always a Biker, like a 5 year old child on his bicycle. Don't fade away because you don't ride anymore, just rejoice with the ones that still do, Later-
- Yesterday
I've had one for a few years. I miss the convenience of a half or 3/4 being able to drink some water while riding though.
- Last week
Nice. Never had one but they are one of the best.
Thinking about a spring ride for June. Here in Wisconsin.
OrlinEngh replied to OrlinEngh's topic in Watering Hole
The only one with rooms left is Website https://www.wyndhamhotels.com/americinn/viroqua-wisconsin Phone 608-637-3100 It gets busy around here on weekends. Give them a try if not there are places in Westby. -
dueyk1111 replied to OrlinEngh's topic in Watering Hole
was wondering the name of the motel close by to stay at? -
vzuden replied to OrlinEngh's topic in Watering Hole
I will need to wait until the next time. We just bought another house last week and there is too much to get done with moving and prepping it -
RDawson replied to OrlinEngh's topic in Watering Hole
I was hoping to make it but my nephew is getting married that weekend. Can’t skip that. -
How is it looking for some company. Looking to seeing some Venture Riders -
Have fun on your test ride. The Voltage at 13.7V is what you want. Healthy voltage! I think your riding season has just started and thousands of miles ahead...
no need to leave the forum
I bought some Prestone antifreeze that said was compatible with Aluminum and Cast Iron but didn't get any positive response about using it so bought from dealer who got this at a good price and I paid $13can for it! Bought 3! Checked all fluids and topped them up,started bike and meter showed 13.7v at idle and increased with throttle so hopefully take for test run tomorrow and my charging problems are solved!
Happy Trails
What @N3FOL said! You can still keep intuch with everyone here even if you don't ride anymore!
N3FOL started following Thank You VentureRiders
Take care @uechi kid, but we will still be here talking about bikes and everything else. Hope to hear from you time to time in this forum. Enjoy your summer!
uechi kid started following Thank You VentureRiders
The time has come for me to say goodbye. I haven’t ridden much in the past 5 years so I sold my Venture. I need to make sure I thank everyone here for being such a great community. You’ve made being a diy guy so much easier. The expertise here has saved me time, money and a lot of aggravation. It’s been great. Ride safe. Rich Flay
09 Venture Saddlebags
dudexit2 replied to dudexit2's topic in Royal Star Venture Tech Talk ('99 - '13)
How much for just the saddlebags?
