- Past hour
That's dry weight, curb weight is 869 if i remember correctly. What I'm looking for is how much of that weight is on each wheel.
- Today
Specs say 807 lbs. dry weight.
ragtop69gs started following 2nd gen weight bias?
Does anyone have an idea of the weight bias of a 2nd gen venture? I'm going to be loading my bike and our Saturn Sky Redline on my 21 foot car trailer and am trying to decide if I put the bike or car on first to get close to a good tongue weight.
Click forums and scroll down to”darksiders”. Lots of info there
i have an 04 midnight venture royal star and am thinking of going darkside. any cocerns? size needed?
- Yesterday
Yes I'll have the coffee ready
- Last week
We’re looking at one this afternoon for the wife.
Well I'm a bit late posting this as it occurred on this past April 19th, and on that day, I replaced the standard manual petcock with a vacuum operated petcock. Got tired of remembering to get up and go shut it off hours after parking the bike. But also on that same day I did something that some may consider controversial if not downright heretical - I removed the fuel pump from my 2nd gen 2001 RSV. I've only ridden 675 miles since then. With no issues. Many of those miles in the twisties of the Blairsville, GA area including hwy 129, as well as high speed interstate cruising. Gravity seems to work just fine! So if you're on the road and your fuel pump gives out, just re-route that fuel line directly from the petcock into the carb inlet and cruise on!
Black Cherry got her yearly bath this morning. A little late this season, but I've been on the road a lot this year.
GadgetDan changed their profile photo
GadgetDan started following Looking for verification on my rebuild
M61A1MECH replied to muellercandd's topic in Royal Star Venture Tech Talk ('99 - '13)
Did the motor come from a Venture or did it come from a Royal Star. Yamaha built standard Royal Star cruiser models from 1996 to 2000 or 2001. The Ventures came out in 1999 and were built until 2013. They use the same basic motor, but the Venture models and later model Tour Deluxe made from 2005 to 2010 had more horse power, bigger carbs and special fake fins on the front cylinders, those special finned covers had two attach points for the front "dog bones" that support the motor. Also the air boxes for the original Royal Stars are a lot different that the ones on the Venture or Tout Deluxe. If you received a Royal Star cruiser motor instead of a Venture Touring motor there is likely to be small differences in some of the plumbing like for the AIS. Good news is if you did receive a Royal Star cruiser motor, most of the parts from your original Venture motor should bolt right on, bad news is , it still lack in horsepower. If you post photos of the motor it could help us help you. -
I have ridden 2 175-mile trips in the past week and did really good with the Venture. I'm going to keep riding it solo for a while but want a Spyder to ride with the Wife. Going to look at one Sunday and I'll share how that goes next week.
Recently I was given a 2000 Venture for helping a friend move, catch is, there is a hole in the top of block behind the left rear cylinder. I get it home, make a quick table and put the bike on it and begin to pull the motor. I drain the oil and only coolant comes out. After talking with a dealer who informed me that any engine from a royal star of a given age will make a great motor to swap. I go to ebay and find a 96-00 royal star motor. It showed up today and I noticed one thing. My bad motor has a hose connection at the top of every exhaust manifold. The replacement does not. I spent some time here and believe this is part of the AIS system? So, what I would like to do is verify that yes, this is the AIS system, and that it is ok to use the replacement motor without out the AIS system and not switch out the heads. If I can do this, can completely delete all of the components, hoses and diaphragms, from the AIS system or is there something else also running off those components that I do see? Thanks FreeBird and Papa Fred for the two posts I found to help to get to this point
I have the LS2 and I love it. I like the way it fits and the way the chin bar flips to the back so the wind does not catch it. Also the cheek pads are removeable in a emergency should you have a accident The built in sunshield is nice. There is a switch you can slide forward or back to raise or lower it.
Hello muellercandd, Welcome to Venture Rider. Please feel free to browse around and get to know the others. If you have any questions please don't hesitate to ask. muellercandd joined on the 07/03/2025. View Member
muellercandd joined the community
Hello Fester119, Welcome to Venture Rider. Please feel free to browse around and get to know the others. If you have any questions please don't hesitate to ask. Fester119 joined on the 07/03/2025. View Member
When I use ABS glue I put a large ABS patch on the back side. I buy sheets and heat gun it to mold to the shape, glue, and clamp it.
Fester119 joined the community
We booked today. They said you n I are the only ones on the book.
Yamaha support of new parts for our older bikes
LeesBike replied to LeesBike's topic in General Tech Talk
Most of the time, the non yamaha parts are junk, and the yamaha parts are $$$$ -
Just booked our room at Season’s Inn. What time will you have the coffee on?
Rear master cylinder
frankd replied to frankd's topic in Venture and Venture Royale Tech Talk ('83 - '93)
Thanks! I ordered the rear master rebuild kit and it should arrive in a few days. I replaced the brake fluid in the clutch system about a month ago. I should replace the fluid in the brake syster also. I'l have to bleed the rear system anyway because of all the air pumped in, I'll just push the calilpers back and get that old fluid out. Frank -
Ron, you just saying that because it's true
Marcarl started following Starter gear train help
Marcarl replied to ca_mccar's topic in Venture and Venture Royale Tech Talk ('83 - '93)
IMHO there should be a washer between the gear and the aluminum case -
yah, ABS cement not the best option and the process and prep work is also important.
