This stream auto-updates
  1. Yesterday
  2. I am a true believer of 'Indian Summer' and it always happen. Ride safe and enjoy the ride.
  3. might get to ride this weekend round here, supposed to be inn the upper 60's friday n 70's on sat. may be the last her in northern ill.
  4. Good morning! Cloudy conditions over here in SE Pa. Yesterday, it was so windy that riding was not even on my mind. Today is much better. Have a great day and ride safe.
  5. Last week
  6. It was 37 in Houston this morning. I don't go into the office anymore but it's very near my lower limit. Wouldn't be fun going in but in would be coming home at 70 degrees.
  7. I might throw a blanket over it to give it a warm feeling, fill the gas tank so it don't die from starvation and then park it in a corner so it harder to run away. That's it.
  8. Every time I've seen this, it has been a loose connection at the battery ground or positive terminal.
  9. Just connected the battery tender yesterday and had to wipe back a little tear...
  10. Sounds like a poor connection. Check battery with volt meter, 12.3 is not a good full battery but should start it at least. Try to start it and if everything dies then don't touch anything but check the voltage at the battery, first the posts then the connectors and then the solenoid. Seeing as everything dies I would strongly suspect a poor connection in that area. Note: Do not turn anything off when it all dies, check things when 'under load'.
  11. Check the starter solenoid and main ground for clean and solid connection. If they are good, pull battery and take to auto parts store for load test. Beyond that, possibly a bad connection in key switch or starter button
  12. Chaharly
    V-Max
    Yamaha came out with the 1700 VMax years ago and its been discontinued. Though I still agree. Have the new venture be sleeker and styled more like the new Goldwing with the 1700 V-4 and I would have bought one new sight unseen. Theres a market for it. Just look at the BMW K1600s
  13. 2011 Hannigan Venture, ridden every day since purchase 9/2024. On vacation for 3 weeks; trike was parked and covered. On return, trickle charged battery to 12.5 volts, turned key; everything looked normal. Neutral light, clicking fuel pump, dash lights, 12.3 volts on voltmeter. Touched started switch; all power died. Thought I popped main fuse. Nope. All fuses checked good. Key goes to off; turns to start, power returns and 12.3v. Touch start button, power dies. Key to off, then on; power returns. Pulled and checked battery and cleaned terminals and connectors; all seems good. Trike started and ran well daily until I parked it; maybe it's mad at me for going on vacation without it? Wondering where to look first. Switch? Starter solenoid? Wires to starter? Starter short? Clymer is no real help at this point... Mostly it assumes that bike turns over. No clicking or anything; just completely loses all electrical until I recycle key. Weird. (Also posted in Delphi Yamaha forum.) Anyone have ideas?
  14. Good morning to all! Have a great Monday.
  15. Good morning to all! Was so tired yesterday helping out my cousin find a place near her workplace so she can start working as a nurse. Just five days in this country and she is ready to get to work. After all that searching, we were able to find a safe place that has shuttle service to and from her hospital. Much relieved after all that hard work. Slept pretty much all night like a baby and never had a dream. Have a great weekend and ride safe!
  16. I have a Hagon HD rear shock that lifted the rear slightly and the 18" Stratoliner front wheel with a 130 (narrower) tire... The Shinko 777 I put on the bike this year feel a little twitchy/unsettled at highway speeds and I'm wondering if lowering the rear might "reset" the rake & trail of a factory bike. I know a lot of people use to pull these kits off the bikes, so figured I'd ask before I order a new set. I'm 6'2" with fairly long legs, not a huge deal on the ride height to me.
  17. I did this on my 2000 mm rsv. It helped me flat foot this motorcycle. I put the smaller front tire on also. Also Baron's handle bar risers. It helped me, don't know that affected the ride much. Definitely lower to ground,I hear you can drag mufflers.
  18. Earlier
  19. I have 2 sets of New Original Stock chrome brake caliper covers for the 1983-85 Ventures. You can install these without the rotor covers if you like. I also have a heat shield color insert for the 83-85 Ventures also. Shoot me an offer and you can have one or both caliper covers. Thanks Rick F.
  20. I'm looking to try some different suspension tuning with my '99 RSV and figured I'd ask on here if someone might have a used Barron's Lowering Kit before I reach out and buy one new.
  21. Good morning to all. Ride day today and it is RSV's turn to hit the road. In the low 40's this morning, but manageable with the proper cold weather gear. Ride Safe all and have a great day.
  22. Its been 70 the last two days here in southeast Nebraska. Gonna ask the missuss if I can go for a ride this afternoon. Bike is sitting in the work parking lot ready to roll.
  23. Good morning to all. Back riding today to and from...Finished installing my KUAT rack on the Taco and love I love it! We are hovering between 60° F and down to around 40°F. Truly a big swing in temp this time of the year. Glad I don't have to think about 'cutting the grass'. The way it looks, I may have two more cuts before the end of the year. Also this morning, I saw two riders with no fairing and no windshield riding at 42°F temp on the interstate. Temps are still not too bad. Ride safe.
  24. Good Afternoon to all! Today, I just might give both bikes a nice wipe and check all fluid levels. Looking forward to install a roof rack on my Taco this weekend. Have a great weekend!
  25. Went out for a couple hour ride Wednesday! Not too windy and fairly cool!
  26. Just set a date, will be there, barring a catastrophic event here! I love riding that area, may have to take a trip to the mindoro cut?
  27. cimmer
    V-Max
    My first thought is why is it a 2025 and not a 2026 model and the searched turned up all kinds of different dates on it unveiling, so till it is seen on the Yamaha USA Motorcycle product line I have a tendency to not believe it. and yes they would have done better with the V4 in the Venture than a v2 they used. I am tired of the wannabe Harley look. Rick F.
  1. Load more activity
