Yammer Dan Posted November 30, 2015 Share #1 Posted November 30, 2015 No reponce from keyboard when i try to use it on desktop. I have wireless and a wired one ? Hate this i pad any ideas? Link to comment Share on other sites More sharing options...
cowpuc Posted November 30, 2015 Share #2 Posted November 30, 2015 Try turning the machine off, reach around back and make sure the cable from the key board is plugged all the way in. If its a wireless keyboard you probably have a dead battery. Link to comment Share on other sites More sharing options...
M61A1MECH Posted November 30, 2015 Share #3 Posted November 30, 2015 No reponce from keyboard when i try to use it on desktop. I have wireless and a wired one ? Hate this i pad any ideas? If it is an Apple product, the best solution I found for their products is turn them off and leave them off for several minutes, (personally I would turn them off and leave them off if could) after waiting a few minutes turn them back on and generally they start working correctly again. Otherwise what cowpuc said is good advice. Link to comment Share on other sites More sharing options...
billmac Posted November 30, 2015 Share #4 Posted November 30, 2015 If you have auto update on sometimes after the update you need to reboot. that's what I do and then it works fine. Not every update needs rebooting but sometimes my key board needs the reboot. Link to comment Share on other sites More sharing options...
Yammer Dan Posted November 30, 2015 Author Share #5 Posted November 30, 2015 Tried all this so far. All of the wireless stuff will light up and fade out as soon as it does. It is. Not working during this short time it. Does show signs of life. Wehave a wired keyboard and mouse and a. Wireless set. We did get the wired mouse to work but nothing with the wired keyboard. It is also effecting the printer. I am learning to hate this I pad. I can look at sites but can not respond to anything so do not get to answer things I usually do. Link to comment Share on other sites More sharing options...
Yammer Dan Posted November 30, 2015 Author Share #6 Posted November 30, 2015 Have changed all the batteries, checked all connections and rebooted a 100 times. Nothing. When you hit keyboard it is just as dead as the throttle on a Hardley. Link to comment Share on other sites More sharing options...
Eck Posted November 30, 2015 Share #7 Posted November 30, 2015 Check for a Loose nut between key board and chair..... Link to comment Share on other sites More sharing options...
SilvrT Posted November 30, 2015 Share #8 Posted November 30, 2015 Try a different keyboard ... process of elimination. Link to comment Share on other sites More sharing options...
Yammer Dan Posted November 30, 2015 Author Share #9 Posted November 30, 2015 I tried a different keyboard and the Warden is doing this I am just passing info soI won't tell her what you thinkofher Eck! I taught her to shoot. Til she started outshooting me!! Or i just have to be carefull whenI tell her what ECK said. Done all the scans available to us. We still have windows 7. Trying not to upgrade to 10 but don't think that could have anything to do with it. It seems computer is just not seeing keyboard or any of the wireless devices. We did get the wired mouse to work but that is all. So i can sneakinand read site. I guess The Boss finally figured out a way to keep me in my corner and quiet!! I'm sorry Boss:bawling:Can I come out and play now?? Link to comment Share on other sites More sharing options...
SilvrT Posted November 30, 2015 Share #10 Posted November 30, 2015 OK, I'm confused (doesn't take much these days) ... your original and successive posts suggest you're using an iPad yet now you mention Windows 7. Does not an iPad use iOS (apple) operating system? or is this keyboard connected to a PC using a Windows OS? Link to comment Share on other sites More sharing options...
utadventure Posted November 30, 2015 Share #11 Posted November 30, 2015 Go to the Control Panel, System, Device Manager. Find the Keyboard and check for an Updated Driver, then restart. If that fails: Go back to the Device Manager and delete the Keyboard, then restart. The computer should find the "new" keyboard and install the driver. Link to comment Share on other sites More sharing options...
MiCarl Posted November 30, 2015 Share #12 Posted November 30, 2015 You don't mention whether your keyboards are USB (wired and wireless). Is your printer USB? If all of those things use USB you might have a problem with the USB hardware. Link to comment Share on other sites More sharing options...
Yammer Dan Posted November 30, 2015 Author Share #13 Posted November 30, 2015 wired and wirelessthat fails Link to comment Share on other sites More sharing options...
SilvrT Posted November 30, 2015 Share #14 Posted November 30, 2015 Try this (from a Dell fix) -Unplug the computer and disconnect all devices. -Press and hold power button for 10 seconds to drain the capacitor to prevent electrical shock. -Open computer case and locate the 3 pin jumper block (located next to the 4 SATA harddrive connection points on the motherboard). The jumper is blue and will be connected to two of the three pins on the motherboard. -Remove the jumper block for a second (apparently this clears the memory?) then reconnect it back to it's original postion. -Close it up and that should do it! The Dell tech guy said the memory was corrupted or looped and this procedure cleared it out. Link to comment Share on other sites More sharing options...
oldgoat Posted November 30, 2015 Share #15 Posted November 30, 2015 on the back of your key board do you have a little reset button to sync the mouse and keyboard? Link to comment Share on other sites More sharing options...
Beau-Kat Posted December 1, 2015 Share #16 Posted December 1, 2015 No reponce from keyboard when i try to use it on desktop. I have wireless and a wired one ? Hate this i pad any ideas? Maybe you need to get a Gen II keyboard. I've heard they're faster. Link to comment Share on other sites More sharing options...
M61A1MECH Posted December 1, 2015 Share #17 Posted December 1, 2015 Try taking your dongle out and then putting back in, sometimes that will make it work. Link to comment Share on other sites More sharing options...
cecdoo Posted December 1, 2015 Share #18 Posted December 1, 2015 Try taking your dongle out and then putting back in, sometimes that will make it work. Hey Steve, Thanks for a "Good Laugh" I needed it! Craig Link to comment Share on other sites More sharing options...
SilvrT Posted December 1, 2015 Share #19 Posted December 1, 2015 Try taking your dongle out and then putting back in, sometimes that will make it work. Hey Steve, Thanks for a "Good Laugh" I needed it! Craig ya, I heard the more times you do it ..... Link to comment Share on other sites More sharing options...
Yammer Dan Posted December 1, 2015 Author Share #20 Posted December 1, 2015 The Warden got it Done!!! Told me how but I didn't understand it... That girl has a couple gray cells working. I suggested taking it somewhere to get it fixed and zbout got my head bit off with a "I'll Do This!!" And she claims I'm stubborn?? Don't know what I would do without her. Now if she would just work on that 2nd Gen. I got the 1st Gens......... Link to comment Share on other sites More sharing options...
SilvrT Posted December 1, 2015 Share #21 Posted December 1, 2015 The Warden got it Done!!! Told me how but I didn't understand it... and yer just gonna leave us "dangling" in suspense ... forever wondering what the solution was??? yer a mean, mean man! Link to comment Share on other sites More sharing options...
bongobobny Posted December 1, 2015 Share #22 Posted December 1, 2015 Does anyone else wonder how Dan typed his posts if his keyboard didn't work????? Link to comment Share on other sites More sharing options...
Yammer Dan Posted December 1, 2015 Author Share #23 Posted December 1, 2015 Does anyone else wonder how Dan typed his posts if his keyboard didn't work????? With the Warden's I-Pad. Link to comment Share on other sites More sharing options...
Flyinfool Posted December 1, 2015 Share #24 Posted December 1, 2015 With the Warden's I-Pad. And that is why she was in such a hurry to get yours fixed, before you broke hers...... Link to comment Share on other sites More sharing options...
Yammer Dan Posted December 2, 2015 Author Share #25 Posted December 2, 2015 And that is why she was in such a hurry to get yours fixed, before you broke hers...... Ya got to think outside the I Pad......:backinmyday: Link to comment Share on other sites More sharing options...
