Bwhite Posted May 3, 2012 Share #1 Posted May 3, 2012 I have a brother that just purchased a very well taken care of '86 Goldwing. It puffs some blue smoke at cold start-up for a few seconds. He was told to try Bars Leaks engine stop leak with conditioner. He's wondering if it will mess with the clutch plates. With the wealth of knowledge on this site, maybe you'd have some comments. Thanks Ventureriders. Brian in Mankato, MN 2000 RSV Link to comment Share on other sites More sharing options...
09RSTD Posted May 3, 2012 Share #2 Posted May 3, 2012 Well how do I put this? No. No. and NO!!!!!! Don't do it. A little bit of blue smoke at start up isn't abnormal for an older bike with some miles on it. Bars leaks is not going to help with worn piston rings. Just leave it alone. Don't do anything. Link to comment Share on other sites More sharing options...
flb_78 Posted May 3, 2012 Share #3 Posted May 3, 2012 It'd probably be easier to replace the valve seals. Link to comment Share on other sites More sharing options...
FreezyRider Posted May 3, 2012 Share #4 Posted May 3, 2012 The older 4 cyl Wings ALL puff a bit of smoke at startup. When you lean it on the sidestand, those left cylinders are pointing down and a small amount of oil will seep in. This isn't harmful....best to just monitor the oil level and let it go if it isn't burning more than that. Or, use only the centerstand. Link to comment Share on other sites More sharing options...
BlueVenture87 Posted May 3, 2012 Share #5 Posted May 3, 2012 My '82 GL1100 puffs a bit sometimes and it's been doing that for years now. It's no big deal really and it's never been enough to cause an issue with oil levels. Hold your breath and ride away! At least it doesn't leave a mess on the driveway! -JK Link to comment Share on other sites More sharing options...
SilvrT Posted May 3, 2012 Share #6 Posted May 3, 2012 puffing blue on startup generally indicates valve oil seals leaking a bit. nothing to be concerned about unless it's excessive. Link to comment Share on other sites More sharing options...
MikeWa Posted May 4, 2012 Share #7 Posted May 4, 2012 It's the automatic valve stem lubricators doing their job. Mike Link to comment Share on other sites More sharing options...
BOO Posted May 4, 2012 Share #8 Posted May 4, 2012 The older 4 cyl Wings ALL puff a bit of smoke at startup. When you lean it on the sidestand, those left cylinders are pointing down and a small amount of oil will seep in. This isn't harmful....best to just monitor the oil level and let it go if it isn't burning more than that. Or, use only the centerstand. I agree, I don't know if they all do it or not but the one I had does but it wasn't enough for me to have to add oil between changes. Just gives the Harley guys something to rag on you about. BOO Link to comment Share on other sites More sharing options...
djh3 Posted May 4, 2012 Share #9 Posted May 4, 2012 If its only on start up I have to agree, leave it be. Besides it just keeps them from wearing on the intial startup where oil aint flowing. Link to comment Share on other sites More sharing options...
dacheedah Posted May 4, 2012 Share #10 Posted May 4, 2012 nothing to get excited about but the cheep fix will cost u more in the long run Link to comment Share on other sites More sharing options...
Yammer Dan Posted May 4, 2012 Share #11 Posted May 4, 2012 Leave it alone!!! Link to comment Share on other sites More sharing options...
Pegasus1300 Posted May 4, 2012 Share #12 Posted May 4, 2012 Ummmm I thought Bars Leaks was for radiators and cooling system leaks ?? But in any case you don't really need to do anything other then keep an eye on the oil level.A little blue on start up is ok and wont hurt anything.Like one post said automatic ring and valve lube. Link to comment Share on other sites More sharing options...
Flyinfool Posted May 4, 2012 Share #13 Posted May 4, 2012 I use the Bars Leak Rear main seal "repair" in my truck. I have to add it every other oil change. With the bars leak the truck uses less than 1 quart of oil between changes. This the oil consumption that it had since the day I bought it new. Without the bars leak it leaks 2 quarts out the rear main seal between changes. Very messy but does help to keep the bottom of the truck from rusting. I know it should not be leaking yet, it only has 300K on it. Someday I'll get real ambitious and replace the rear seal. It does not sound like this would help your problem at all. Link to comment Share on other sites More sharing options...
Rick Haywood Posted May 4, 2012 Share #14 Posted May 4, 2012 Dont do it on the bike my old gold wing did that for 85,000 miles. It never got low between oil changes. someone told me to try synthetic and it would stop that. It worked in my old pickup with 190,000 miles on it but not sure about the bike. Also put a 2x4 under the kickstand and that will help it a bunch this way it doesn't lean over so far. Link to comment Share on other sites More sharing options...
