User Tag List
Thanks Thanks:  0
Likes Likes:  0
Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: Front end
  1. #1
    Join Date
    Jan 2012
    Oldsmar 34677
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Front end
    I just bought a 1999 venture has 37K on it I'm having an issue with the front end being VERY heavy in turns, I actually push the opposite way because of the weight it's like I'm fighting it . it also SEEMS to wobble slightly whe turning sharp at very slow speeds It's hard to explain. Does not seem to be anything loose on the axle etc...rubber is Avon with plenty of tread and looks fine HELP!!!!!!!!!please!!!!!!!
  2. #2
    Join Date
    Aug 2010
    Brooksville
    FL
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Default
    When I bought mine it was that way I hated the way it hancled, I put on a new tire and it was like having a different bike.
    Love Ya Rick & Shirley
  3. #3
    Join Date
    Aug 2006
    Carmichael CA
    CA
    Post Thanks / Like
    Mentioned
    100 Post(s)
    Tagged
    0 Thread(s)
    Default
    A new tire will help, but don't expect it to be as nimble as a lighter bike... Keep the tire pressures up to max... Another thing I found with mine was the steering bearing needed to be tighten. There's a write up on how to do it without tearing everything apart in the tech section...
  4. #4
    Join Date
    Jul 2010
    Port Byron
    NY
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Default
    What brand tires do you have? If they are the stock Brickstones, dump them. It does sound like the steering head needs to be tightened.
    if you can't have fun here, you can't have fun anywhere!
  5. #5
    Join Date
    Jan 2012
    Oldsmar 34677
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Tightening the steering is I think the way to go there's NOTHING wrong with the rubber it's an Avon with plenty of tread and NO unusual wear I let you guys know if that does it THANK YOU!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  6. #6
    Join Date
    Jul 2010
    Port Byron
    NY
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Default
    One more question. Does it have a lowering kit on it. My 99 came with the rear end lowered, handled like a tank. I removed the lowering kit. wow what an improvment.
  7. #7
    Join Date
    Aug 2006
    Ruidoso area, NM
    NM
    Post Thanks / Like
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Default REAR Tire?
    What does your REAR tire look like? If it has developed a somewhat square profile from wear (flat across the middle), it will cause this. Another big cause is pressure too low.
    A lowering kit will absolutely cause it - in fact, one the biggest improvements to the handling of the STOCK RSV (besides good tires) is to RAISE the rear of the bike. A lowering kit just takes a bad situation and makes it worse.
    If your rear brake caliper is below the swing arm, it has been lowered.
    Goose
    V7Goose - Patriot Guard Rider
    Venture Riders meet on Channel 29!
    Iron Horses in the stable: 05 RSV QuickSilver, 79 Guzzi G5 LAPD, 75 Guzzi Eldorado Police, 73 Guzzi Ambassador/hack
    Iron Mules in the stable: 07 Yamaha Rhino 660 Sport, 94 F250 4x4
  8. #8
    Join Date
    Jul 2010
    Port Byron
    NY
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by V7Goose View Post
    Goose
  9. #9
    Join Date
    Sep 2010
    Sebring FL
    FL
    Post Thanks / Like
    Mentioned
    16 Post(s)
    Tagged
    0 Thread(s)
    Default
    I just got mine yesterday and comming from a 900 Vulcan it feels heavey to me too. But I think maybe the way I am going to go is to do the front end lowering. Sounds like from what I have read thats the hot set up. Helps the low speed handling (which I am struggling with) and not any real down side at speed. Also I looked earlier and I think mine has Dunlaps on it. Not my favorite, but hey I have spent toooooo much in the last couple days on stuff like inter comm headsets, parts for highway pegs insurance to name a few to change perfectly good tires. What kind of pressures are guys running? I killed my first set of Dunlaps on my 900 because I followed the "recomended" on the bike. 8K out of the rear and only 10-12K on the front. Dont want to do that again.
  10. #10
    Join Date
    Apr 2008
    Spring City,UT
    UT
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Default
    djh3
    that is actually about normal tire life for dunlop 404. I put up with it because they were relatively cheap and I could get them in WWW front and rear.
  11. #11
    Slab_Ryder Guest
    Default
    My OEM 404's got 28,000 kms (just over 17,000 miles). I get 35,000 kms (just over 21,000 miles) on my Dunlop E3's. I inflate to 40 PSI Front / 41 PSI Rear. I check my pressures every other day.
  12. #12
    Join Date
    Sep 2010
    Sebring FL
    FL
    Post Thanks / Like
    Mentioned
    16 Post(s)
    Tagged
    0 Thread(s)
    Default
    Thanks Slab. I just went out and checked whats on it. It has e 3's on it, so your recomendation of 40/41 is appreciated.
  13. #13
    Join Date
    Aug 2006
    Ruidoso area, NM
    NM
    Post Thanks / Like
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Exclamation Do not overinflate tires!
    Quote Originally Posted by djh3 View Post
    Please check your tire sidewalls - Do Not, EVER, over inflate your tires!!! (Note that the rear Dunlop E3 on this bike has a maximum pressure of 40 psi.)
    Running any tire at maximum pressure, as stamped right on the sidewall, will generally produce maximum tire mileage. However, it does NOT always produce best handling.
    Running any tire at higher pressure than stamped on the sidewall is ALWAYS unsafe.
    Goose
  14. #14
    Join Date
    Sep 2010
    Sebring FL
    FL
    Post Thanks / Like
    Mentioned
    16 Post(s)
    Tagged
    0 Thread(s)
    Default
    When I was researching tires for my Kawasaki, Pierrlli, Shinko and I forgt the other one I contacted about pressures. The pressures they recomended ended up being usually about 4lb under whatever the max was on the tire I think. So like the Pierrli I was running on the rear the max inflation was 41 I think and thier recomended was 38. I'm going to e-mail Dunlap and see what they say.
  15. #15
    Join Date
    Aug 2006
    San Diego
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    There is a lot of weight on the front due to the fork mounted fairing. Going with a smaller tire on the front will help a bunch; dropping the forks 5/8 to 3/4 of an inch will help too. With this big bike you need to use all the skills that are taught in the classes. While you can get away with being sloppy in your technique with small bikes the Venture demands proper technique. Once you get the feel for it the bike will surprise you on how well it handles. Slow, look and press thru the corners and practice it will be fine. Rod
Similar Threads
  1. Replies: 18
    Last Post: 01-19-2012, 06:49 PM
  2. New front rim try # 2
    By dingy in forum Venture and Venture Royale Tech Talk ('83 - '93)
    Last Post: 10-02-2011, 08:34 PM
  3. Front End Squeak???
    By Eddy in forum Royal Star Venture Tech Talk ('99 - '13)
    Last Post: 09-18-2008, 11:43 PM
  4. Lowered Front End How to add air?
    By MikeyJ in forum Watering Hole
    Last Post: 09-10-2008, 07:41 PM
  5. front air deflecters
    By Eddie Fulmer in forum Royal Star Venture Tech Talk ('99 - '13)
    Last Post: 09-10-2008, 07:55 AM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
