venture101 Posted August 15, 2008 Share #1 Posted August 15, 2008 I just bought the Craftsman lift jack but have never used one. I read the thread and replies on lifting an RSV, using the lift adapter, hockey pucs, 2x4's, etc. Seems pretty simple. I am usually alone when doing anything in the garage so the question I have is what is the best way to hold the bike staight up while getting the jack positioned and lifted? I know another person would be the easiest but not always possible. Link to comment Share on other sites More sharing options...
KeithR Posted August 15, 2008 Share #2 Posted August 15, 2008 Get yourself a block of wood and put it under the stand to level it. Keith Link to comment Share on other sites More sharing options...
Bubber Posted August 15, 2008 Share #3 Posted August 15, 2008 OK before everybody jumps in here and tells you to go look in the classified for Carbon1 lift adapter I will. Go look in the classified for Carbon1's lift adapter. LOL You'll like I promise. Steve aka Bubber Hope that helps. Link to comment Share on other sites More sharing options...
Squidley Posted August 15, 2008 Share #4 Posted August 15, 2008 Here's the listing in the classifieds, I can't recommend it enough, I have 1 http://www.venturerider.org/classifieds/showproduct.php/product/69/cat/7 Link to comment Share on other sites More sharing options...
Steve S Posted August 15, 2008 Share #5 Posted August 15, 2008 Here's the listing in the classifieds, I can't recommend it enough, I have 1 http://www.venturerider.org/classifieds/showproduct.php/product/69/cat/7 Correction Squidley, you HAD one. I "stole" it and have been using it quite frequently here lately. And you are right of course. It is a great addition to the jack that I also pinched. It holds the bike steady while you lift it and even steadier after you put the legs on it and take the jack out from under it. If one is not in the budget at this time, do as I did and catch someone not home and "borrow" thiers. LOL:dancefool: Seriously, if you do not have a jack or lift adapter, the boards will work OK. Just be cautious because they are not quite as steady. Good Luck Link to comment Share on other sites More sharing options...
pegscraper Posted August 15, 2008 Share #6 Posted August 15, 2008 Get yourself a block of wood and put it under the stand to level it. Keith Works fine for me. Link to comment Share on other sites More sharing options...
GigaWhiskey Posted August 15, 2008 Share #7 Posted August 15, 2008 I have not seen the need for a motorcycle lift/jack. What does a motorcycle lift/jack do that a regular floor jack can't do other than making it nicer to R&R the rear wheel on a dresser when the area below the tire opens up. I did my 6 mounts with a floor jack. Lastly, I am not lifting my bike on the pipes. Link to comment Share on other sites More sharing options...
V7Goose Posted August 15, 2008 Share #8 Posted August 15, 2008 I just use 4 pieces of 2x2 wood. I slide the jack under the bike and position the first two pieces under the left side frame rail (one in front of the kickstand switch). Just make sure the jack is not pushed too far in, as the bike will pull back to the right as it stands upright. With the wood in place on the jack rails, I just slowly start raising the jack, which gently stands the bike straight up. There is plenty of time to adjust the position of the wood blocks under the right frame rail before they touch as the bike stands up. Nothing to it! Link to comment Share on other sites More sharing options...
Freebird Posted August 15, 2008 Share #9 Posted August 15, 2008 I have the lift adapter but other than that, I do it exactly the way Kent does. Just slide it under the bike and start jacking. The bike will come up straight and lay right over on the lift as it should. Easy one man job. Link to comment Share on other sites More sharing options...
venture101 Posted August 16, 2008 Author Share #10 Posted August 16, 2008 Thanks for the info. Sounds like one guy can do this without a problem. I'm sure I'll be buying a lift adapter eventually, hopefully not right after I tip 'er over. Thanks again. Link to comment Share on other sites More sharing options...
Eddie Fulmer Posted August 16, 2008 Share #11 Posted August 16, 2008 I have to run my front wheel up on a piece of wood before I can get my jack under it. Not a problem really. Otherwise I have to stand it almost straight up to get the jack under. It's a little hairy holding the bike with one hand and the jack with the other. That's the reason for the board. Link to comment Share on other sites More sharing options...
