to those members who had pinstripping done while attending rallys and probably had a few beers before making the decision to enhance your paint job. how do you remove it without damaging the paint?
5 minutes ago, Marcarl said:
I hear oven cleaner does it nicely without damage.
I have heard the same. just a little apprehensive to try it. hoping to find someone who has had success.
@saddlebum and @xv1100se
This is true, we use easy off oven cleaner to remove pin stripping and painted lettering from all the used trucks we take in as trade in's. You do run into the odd stubborn one but most pin stripping is done with lettering paint. The paint used by he who I cannot remember his name, is such a paint and should come off easily.
Once you remove the lettering, wash with soap and rinse well. When dry you can buff the paint with a very mild abrasive liquid polishing compound and than polish with a good wax. if your lucky and there is absolutely no shadow left, you may be able to go straight to the wax.
Edited by saddlebum
memory not what it use to be, I believe the person who did the pin stripe work said it would come off with laquer thinner. not sure about this.
This is true but a lot of paints can be removed with lacquer thinner. the trouble is you have to be careful  what type of finish is on the bike. Lacquer thinner can dissolve some paints or clear coats. As the fabric cleaning products always say "try in a inconspicuous area first"
Edited by saddlebum
22 minutes ago, sleepy2 said:
@saddlebum I believe the pin-stripper's name you were thinking of was Jay-Bird that was at Maintenance Day in Ohio and at a NY rally a few years ago.
Your right that was it. Thanks!
Oven cleaner.  I did it to my 87 trunk with no damage to paint.  Be warned it will mess up your metal trim so be careful of overspray, either mask it or wipe it clean immediately.
  • Like 1
Thanks for the input. some great info here. The new owners are going to take care of it. they are also new members here.
  • Like 1
I have removed some unwanted stuff off my painted surfaces by sanding with 600 grit sand paper , 1200 grit , 2000 grit ....
Then use a quality brand of polish  , this includes pain runs and orange peal
True this is effective and the sanding should always be done with wet sand paper. But for most sign paint lettering it is not necessary. Easy off oven cleaner followed by polishing compound and then a good wax is all it should normally take.
Tthe exception to this is if someone clear coated over the lettering or used a more durable type paint. In those cases the above technique would have to be used. In some severe cases the clear coat may have to be touched up.
Edited by saddlebum
