Venture Capitalist Posted February 5, 2020 Posted February 5, 2020 Hello Everyone. I am new to this site. I purchased a 83 royale a couple of years ago and aside from having to put a new stater in it I haven't had any problems until now. I was sitting at a stop light the other day and all the coolant blew out of the right side onto my leg. It couldn't have been all that hot it didn't do any permanent damage to my leg. Just burned a bit the rest of the day and left a red mark. I am just wondering if this has ever happened to anyone else and if so, what caused it. Where should I start looking to make the repair? I would appreciate any advice anyone can give me
SpencerPJ Posted February 5, 2020 Posted February 5, 2020 Now that it has cooled, I would rinse off with water, let dry, fire it up, and detect where the leak is coming from. If all coolant gone, I would add distilled water or coolant first.
Marcarl Posted February 5, 2020 Posted February 5, 2020 In order to answer your question, I have some in return: How long was the bike running before this happened? Did you ride it easy or hard? What was the outside temp approx? Wear did the coolant come from, appprox area if you know? Did you notice where the temp was on the gauge? Could be that the thermostat got stuck, heated up the coolant in the engine to the boiling point, created steam which then was forced into the rad and blew out the cap or overflow. Solution? replace the thermostat.
Venture Capitalist Posted February 5, 2020 Author Posted February 5, 2020 In order to answer your question, I have some in return: How long was the bike running before this happened? Did you ride it easy or hard? What was the outside temp approx? Wear did the coolant come from, appprox area if you know? Did you notice where the temp was on the gauge? Could be that the thermostat got stuck, heated up the coolant in the engine to the boiling point, created steam which then was forced into the rad and blew out the cap or overflow. Solution? replace the thermostat. First I want to say thanks for the reply. In answer to your questions. I had just ridden it to the store about 3 miles away. The outside temp was really cold. I had to be all bundled up. It came from somewhere on the right side. It shot through that gap in the right side panel onto my right thigh. The temp guage approx. 5 mins before it happened was a little below normal running temp. I always keep an eye on it when riding cause since I got it, it has always had a tendency to run a little hot. Normal for it is about halfway between the halfway point and the red and in the summer at a stoplight sometimes it gets almost all the way up to the red and it has always leaked a little bit of coolant where from I don't know. I just have to add about a cup every month. Once again thanks for the reply Marcarl and hopefully this added info tells you something
MiCarl Posted February 5, 2020 Posted February 5, 2020 It sounds like your temperature is pretty much normal. The fan doesn't kick on until the temp is at the red. It sounds like the coolant may have come from the overflow, although I think the hose should go low enough it doesn't get on you. Any chance it was over filled? What's the level in the recovery bottle cold?
SpencerPJ Posted February 5, 2020 Posted February 5, 2020 Pull the plastics and have a look see . An 83 like mine as well, the question really is: What hose or seal didn't blow . Mine is very temperamental in the cold, the couple times I've had it out below 45, the thermostat housing oring leaked.
cowpuc Posted February 5, 2020 Posted February 5, 2020 All good advice IMHO.. Personally, if it were my 83 I would check the water pump impellar.. 4 of the 6 84/83's that I have retired still had the OEM plastic impellars in them and 3 of those impellars were scalped clean of the plastic edges that push the water. It is pretty hard for them to cool properly if the water pump is not flowing anti freeze. If it were mine and unless it showed that someone had changed the impellar, I would rebuild the pump completely so I didnt end up with an iffy shaft/seals when replacing the impellar.. Make sense?
Venture Capitalist Posted February 5, 2020 Author Posted February 5, 2020 All good advice IMHO.. Personally, if it were my 83 I would check the water pump impellar.. 4 of the 6 84/83's that I have retired still had the OEM plastic impellars in them and 3 of those impellars were scalped clean of the plastic edges that push the water. It is pretty hard for them to cool properly if the water pump is not flowing anti freeze. If it were mine and unless it showed that someone had changed the impellar, I would rebuild the pump completely so I didnt end up with an iffy shaft/seals when replacing the impellar.. Make sense? yah all good advice. I should look at the water pump, but would that cause it to explode out of there. I mean it literally xploded all the coolant onto my leg. In looking at the manual it showed a little rubber plug on the side of the head, would water shoot out of there if the plug popped out? Now the overflow bottle up in the fairing, does that have a hose coming out of the bottom other than the one to the radiator? If so, would it all blow out of there all at once? Sorry if I'm asking stupid questions, this is my first water cooled bike. I have changed water pumps and thermostats on my cars before but that's about it
Venture Capitalist Posted February 6, 2020 Author Posted February 6, 2020 Pull the plastics and have a look see . An 83 like mine as well, the question really is: What hose or seal didn't blow . Mine is very temperamental in the cold, the couple times I've had it out below 45, the thermostat housing oring leaked. pulled the plastic off the side didn't see anything obvious. there are two open ended hoses mounted to a bracket that says see service manual before removing carborator, what do those come from? and is it safe to fill the overflow bottle and fire it up so see if it happens again or I see coolant coming out anywhere?
cowpuc Posted February 6, 2020 Posted February 6, 2020 yah all good advice. I should look at the water pump, but would that cause it to explode out of there. I mean it literally xploded all the coolant onto my leg. In looking at the manual it showed a little rubber plug on the side of the head, would water shoot out of there if the plug popped out? Now the overflow bottle up in the fairing, does that have a hose coming out of the bottom other than the one to the radiator? If so, would it all blow out of there all at once? Sorry if I'm asking stupid questions, this is my first water cooled bike. I have changed water pumps and thermostats on my cars before but that's about it IMHO, DEFINITELY!!! But consider the source here brother,, I am as backyard of grease monkey as they come!! My logic (and it often gets me in trouble) is that if the impellar cannot move water (anti freeze) the coolant in the cooling jackets in the jugs will quickly turn to steam and POOF = high pressure on the entire system and then POOF again - something somewhere is gonna pop.. Also,, (and again,, take this with a grain of back yard wrench spinning thought) I would probably implore a pressure tester on the system (like used on cars) to see if I could detect what blew... Remove the cap, fill the system with water (no since in using anti freeze just for testing), attach the pump, run up to 13 pounds or so and watch for leaks.. Among other obvious places to check, I would look the head coolant bypasses over carefully.. They are located behind the plugs and you hav,, wait a sec,, watch this (with another grain of salt of course LOL):
SpencerPJ Posted February 6, 2020 Posted February 6, 2020 I agree with Cowpuc, and he is one of the master mechanics of these machines, rides them to 250k miles before retiring them. But personally I would still simply top off radiator, fire up, and watch as it gets hot. The cap is easy to get at, and I'm not sure the overfill will be enough to get you started. Next I would pressure test, Autozone rents these simple kits. My extreme limited mechanical knowledge has me thinking a stuck thermostat and the system built up pressure. But in reality, it could be as simple as a split in a hose.
Patch Posted February 6, 2020 Posted February 6, 2020 All good advice IMHO.. Personally, if it were my 83 I would check the water pump impellar.. 4 of the 6 84/83's that I have retired still had the OEM plastic impellars in themand 3 of those impellars were scalped clean of the plastic edges that push the water. It is pretty hard for them to cool properly if the water pump is not flowing anti freeze. If it were mine and unless it showed that someone had changed the impellar, I would rebuild the pump completely so I didnt end up with an iffy shaft/seals when replacing the impellar.. Make sense? Puc is 100% correct! In order for a pump to cycle it must fall within design spec - or - it will only serve to stir! That is the starting point, period yah all good advice. I should look at the water pump, MUST but would that cause it to explode out of there. I mean it literally xploded all the coolant onto my leg. In looking at the manual it showed a little rubber plug on the side of the head, would water shoot out of there if the plug popped out? Now the overflow bottle up in the fairing, does that have a hose coming out of the bottom other than the one to the radiator? If so, would it all blow out of there all at once? Sorry if I'm asking stupid questions, this is my first water cooled bike. Not water cooled liquid cooled! I have changed water pumps and thermostats on my cars before but that's about it In addition, this water is the incorrect fluid to use outside of emergencies. You mentioned that you add a cup of water every other... OK well water can not handle the BTUs resulting from combustion heat, for one it hasn't the density and will by it nature generate hot spots. The fact that it requires constant topping off mean that the system is open somewhere. note: we see this model at times with over limit compression readings, this in and of its self causes over heating problems, such as slow to warm then over heating, then misfires. Like puc said then again like Puc said, "always start with a compression test" cept in this case pump first;)
Venture Capitalist Posted February 6, 2020 Author Posted February 6, 2020 Puc is 100% correct! In order for a pump to cycle it must fall within design spec - or - it will only serve to stir! That is the starting point, period In addition, this water is the incorrect fluid to use outside of emergencies. You mentioned that you add a cup of water every other... OK well water can not handle the BTUs resulting from combustion heat, for one it hasn't the density and will by it nature generate hot spots. The fact that it requires constant topping off mean that the system is open somewhere. note: we see this model at times with over limit compression readings, this in and of its self causes over heating problems, such as slow to warm then over heating, then misfires. Like puc said then again like Puc said, "always start with a compression test" cept in this case pump first;) ok I found the problem, the main hose going into the top of the head has a big crack in it, I just poured water into the radiator and it came gushing out without even firing it up. Anyone know what that hose is called. Since i'm going to be working on it I think I will get a new thermostat too, since apparently from what you guys are telling me that is probably what caused the pressure build up in the first place. And with summer right around the corner I might as well take a look at the water pump too. btw when I top it off I always use 50/50, I never put straight water in it accept just now to see what was going on with it. I just wanted to say thanks to all the guys here that helped me with the good advice. Time to call the parts store now. THANKS EVERYONE!!!
Venture Capitalist Posted February 6, 2020 Author Posted February 6, 2020 IMHO, DEFINITELY!!! But consider the source here brother,, I am as backyard of grease monkey as they come!! My logic (and it often gets me in trouble) is that if the impellar cannot move water (anti freeze) the coolant in the cooling jackets in the jugs will quickly turn to steam and POOF = high pressure on the entire system and then POOF again - something somewhere is gonna pop.. Also,, (and again,, take this with a grain of back yard wrench spinning thought) I would probably implore a pressure tester on the system (like used on cars) to see if I could detect what blew... Remove the cap, fill the system with water (no since in using anti freeze just for testing), attach the pump, run up to 13 pounds or so and watch for leaks.. Among other obvious places to check, I would look the head coolant bypasses over carefully.. They are located behind the plugs and you hav,, wait a sec,, watch this (with another grain of salt of course LOL): oh crap. look to me like the only way to get to the hose is to take the gas tank off. Is that the case? Looks like I might have to undo part of the frame. If that is the case I don't suppose you have any videos on that?
luvmy40 Posted February 7, 2020 Posted February 7, 2020 I'd venture:cool: to say the problem is 37 year old rubber heater hose. You said your temp gauge was in the normal range and the blowout did not burn you severely. I'd replace the T-stat just because and all the rubber hoses, cause they're old, ya' know. $0.02 YMMV
SpencerPJ Posted February 7, 2020 Posted February 7, 2020 Here's a part breakdown. Find the p/n, google it. You'll find what you are looking for. https://www.yamahasportsplaza.com/oemparts/a/yam/50042476f8700209bc787e2b/radiator-hose or the Master Part Breakdown https://www.yamahasportsplaza.com/oemparts/l/yam/50042475f8700209bc787e25/1983-xvz12tk-parts
Venture Capitalist Posted February 7, 2020 Author Posted February 7, 2020 I'd venture:cool: to say the problem is 37 year old rubber heater hose. You said your temp gauge was in the normal range and the blowout did not burn you severely. I'd replace the T-stat just because and all the rubber hoses, cause they're old, ya' know. $0.02 YMMV well I got the old hose off, but I think I have a problem. I was working the hose clamp up using a pair of needle nose while a friend was holding the light for me, he reached down and pulled up on the hose and if came off with a really thin piece of either aluminum or copper where the hose was clamped still attached to the hose. Now there is just a hole in the top of the head with no place to clamp the new hose. Did I break off a piece? Capital Yamaha didn't have that particular hose and said they couldn't order one. Nobody has it anymore and they told me to just take the old on down to an auto parts store and have them cut me one. Are you familiar with that part of the bike or that piece.
Venture Capitalist Posted February 7, 2020 Author Posted February 7, 2020 I'd venture:cool: to say the problem is 37 year old rubber heater hose. You said your temp gauge was in the normal range and the blowout did not burn you severely. I'd replace the T-stat just because and all the rubber hoses, cause they're old, ya' know. $0.02 YMMV I got the old hose off but I think I have a problem. while I was squeezing the hose clamp with a pair of needle nose my friend pulled up on the hose and when it came off there was a really this piece metal that the hose was clamped around still. now there is just a hole where the hose was clamped and nowhere to clamp the new one. i'm hoping maybe there is some kind of piece that screws in there and the hose then clamps to it. Are you familiar with that part at all.
Venture Capitalist Posted February 7, 2020 Author Posted February 7, 2020 I agree with Cowpuc, and he is one of the master mechanics of these machines, rides them to 250k miles before retiring them. But personally I would still simply top off radiator, fire up, and watch as it gets hot. The cap is easy to get at, and I'm not sure the overfill will be enough to get you started. Next I would pressure test, Autozone rents these simple kits. My extreme limited mechanical knowledge has me thinking a stuck thermostat and the system built up pressure. But in reality, it could be as simple as a split in a hose. I was able to undo the back part of the frame and get the tank out of my way but then I was holding the hose clamp together with a pair of needle nose and when I pulled up on the hose a really thin piece of metal came with it and still stuck to the end of the hose. Now there is just a hole in the top of the head with nowhere to clamp the new hose to. it was getting dark when I got it off so I couldn't see if there are any threads down in there, but it has me worried. is there some kind of piece that may you thread into it and clamp the hose to the end of that? I spent hours looking over the service manual and I didn't see anywhere that it says anything about replacing that hose.
Patch Posted February 7, 2020 Posted February 7, 2020 From here it sounds like you are referring to a "barb fitting" of sorts? Can you post a picture..
SpencerPJ Posted February 7, 2020 Posted February 7, 2020 Yup a picture OR at least look at the part breakdown links from above and give us a better clue. I wouldn't be surprised to find a broken off piece, especially if plain water has been added over the years, corrosive. Even the case, they make self tapping inserts etc, and parts are readily available for these machines. And you are correct, nothing magic about the hoses, but if you can find the correct one, it will have pre-bent corners etc, they do work much nicer. If you can get to a regular size computer screen, looking over the parts diagrams is much easier than if you are on your phone.
RDawson Posted February 7, 2020 Posted February 7, 2020 A trick I use on old hoses is to work a hooked pick between the hose and nipple to break it loose before I pull or twist on it. I know I'm a little late with this but it could save some trouble in the future.
cowpuc Posted February 7, 2020 Posted February 7, 2020 Sounds to me like you pulled the hose nipple from the casing and it is still in the hose? Pictures would help.. If hose connectors are not threaded and screwed in place, IMHO, it is not uncommon for them to be "smudge" fit and fairly easily removed when tugging on hoses.. The simple fix is to take a knife and slice the old hose (unless you are going to reuse hose - in your case you are replacing with new) to remove nipple.. Clean nipple and area in case where nipple was removed. Smear a light coat of YamaBond 5 or other sealant to area on nipple that will meet the wall of the case opening. Start nipple into hole by pushing down on nipple with finger being careful to not get it crooked.. Tap the nipple till you feel it bottom out with a plastic hammer - be careful not to damage it - use finess.. The smudge fit is common in places like carb, petcock and case fittings and as amazing and hard to believe as this sounds,, I have replaced many of them back into thier homes and never had a problem with them leaking and actually very seldom use a sealer when replacing em.. Does any of this make sense:fingers-crossed-emo
Venture Capitalist Posted February 7, 2020 Author Posted February 7, 2020 Yup a picture OR at least look at the part breakdown links from above and give us a better clue. I wouldn't be surprised to find a broken off piece, especially if plain water has been added over the years, corrosive. Even the case, they make self tapping inserts etc, and parts are readily available for these machines. And you are correct, nothing magic about the hoses, but if you can find the correct one, it will have pre-bent corners etc, they do work much nicer. If you can get to a regular size computer screen, looking over the parts diagrams is much easier than if you are on your phone. ok trying to send a pic
Patch Posted February 7, 2020 Posted February 7, 2020 a picture of wherre it connects to the head is needed.
