Du-Rron Posted January 16, 2018 Posted January 16, 2018 Don't you just hate it when you get a puncture in your brand new tire? The Fix: a plug that I will watch closely.
Flyinfool Posted January 16, 2018 Posted January 16, 2018 I don't know if I would trust just a plug on a MC tire. Even if you watch it close, if it does go the tire will go down faster than you can stop. I would trust a T Plug where it is a combination of a patch on the inside and a plug in the hole, But only if the original puncture did not cut a bunch of tire cords. A blowout on a car is no big deal, just a big inconvenience, a blow out on a bike is very bad.
bongobobny Posted January 16, 2018 Posted January 16, 2018 Actually, I found out this last February with my new car that plugs are illegal in NY state now! Myself I wouldn't trust a plug on a motorcycle tire, you only have 2 wheels contacting the ground! It would be better to pull the tire and put a vulcanized patch on the inside IMHO...
baylensman Posted January 16, 2018 Posted January 16, 2018 i've ridden plugged rear tires several times! Properly applied they are okay. Its always been on a rear tire. If a plug lets go its just like any other leak. the entire circumference doesn't go just one spot and you get a slow leak like picking up a nail usually enough warning to get over and stop. Now my brother had the new valve stem on his HD snap off, he barely had time to get stopped from 70MPH on the interstate. Tire plugs are not illegal in NY state, only in certain circumstance i.e closeness to side wall and less than certain tread depth remaining, which applies to all types of repair. The law also state that a "proper repair" is a combination of interior patch and a plug. It is only illegal to sell a tire as "new" that has been repaired with a plug.
Du-Rron Posted January 16, 2018 Author Posted January 16, 2018 Yeah... I've ridden with a plug more than once. If the plug fails then I am back to the same leak I had when I started. About 3psi a day. No catastrophic air loss all at once. The maximum mileage I have ridden with a rear tire plugged was on a Dunlop 404, which also got punctured when new, and I rode that one out for 7K miles.
vzuden Posted January 16, 2018 Posted January 16, 2018 Brand new bike (Venture) and on first long trip at 400 miles from home the rear tire was flat in a hotel parking lot. Aired it up and took it to the local dealer and it had two small nails in it about 1/2 inch apart. Luckily they had a new Avon in stock (only the one tire) and it was nearly too old to sell due to the date code. Got a great discount on it and still wore it out before it reached the 5 year mark.
djh3 Posted January 17, 2018 Posted January 17, 2018 I had a brand spanking new Shinko. I had like 1000 miles or less on it. Got a 3/4" or so cut right in the tread. I also thought it was to close to the sidewall for my comfort. I could have patched it, but once off I didnt like the angle and length. It happened about 20 miles from home. I had a plug kit with me and plugged it. I also think given a choice I'll patch vs plug if possible.
WildBill1 Posted January 17, 2018 Posted January 17, 2018 Seen several m/c tires plugged but none hold more than a month or so. Reason even in the tread the tire is too thin for a plug. Inside hot patch would be my choice till I got a new tire.
Yammer Dan Posted January 18, 2018 Posted January 18, 2018 I have done the plugs depending on hole and where it was. To feel safe I would put the plug patch from the inside but if caught out with that one I carry a plug kit. Plug Patch to feel safe.
dbikers Posted January 18, 2018 Posted January 18, 2018 Plugs are for car tires, so......GET A CAR TIRE!! jk...I’m with the majority on this topic...a plug may get you home but YOU DESERVE a new tire!
Zzyzx Posted January 18, 2018 Posted January 18, 2018 Use Ride-on sealer/balancer and it will help prevent puncture leaks. I’ve use it in both bikes and in the 99 the past 4 years and would not ride without it. Here’s a video deminstraiion link on how well it works.
