posting ettiquete question?
baylensman
Dont tell Carbon One but I was so excited about actually owning a MK1 with a working second gear that I just HAD to spin up his old bike and see what she'ld do in second.. Creeped real close to 80 before grabbin third = MAN that felt good :big-grin-emoticon:.. Suckers will spin up if ya let em!!
Speaking of spinning em up,, any of you lop eared varmints ever spin up an R1? Never owned one (still on my bucket list) but rode a buddies,, told me to pin it in 1st gear and hang on - tap it out to the rev limiter and check my speed = 103 IN FIRST GEAR :guitarist 2::guitarist 2::guitarist 2:
Hum who is this crazy lop eared varmint haven't seen him for a second. Seems he be out there lurking in the shadows.
Living life one curve after the other. Vroom scooting, thru the countryside.
@videoarizona
Since no one else has asked, I will. What is the secret to a long trailer bearing life as stated by the Bearing Buddy lady? :detective: :scratchchin:
When I get some time after this weekend, I'll try and find my original post on the TS forum. If not, I'll do my best to remember all that she said to me. The discussion came when I was confused about the different types of "bearing buddies" on the market so I called the original company direct and asked them. We got into an hour long discussion on the phone about bearings, trailers, salt water, grease and bearing tension within the hub. Very interesting...and quite simple , really.
david
I once rode my 1st gen so fast the earth's rotation reversed....... But only for a short period.
I remember when you did that...I loved being 19 again and able to go back and ask that cute blonde out after all...then you slowed down before she could answer.... I only needed 2 more minutes.... next go faster and LONGER... now back to the reality of life and old age... :doh:
So If I'd have kept going on the Kaw the earths rotation would have reversed? I could have slung that Kaw into low earth obit. NOW YOU TELL ME!:doh:
:rotf:
I also had one of those Kaw time machines 500 triple with expansion chambers. The only bike I ever red-lined in high gear looked down at the speedo bouncing on a 140. Got to the point I just couldn't see fast enough too ride it. Was it ever fun playing with all those Hondas and Harley's.
@videoarizona
Bearings and boats. Or....how not to worry about your trailer bearings.
I couldn't find the original post so I'm sitting down to re-write it here...
A number of years ago, I ended up speaking with a lady from the
company that makes Bearing Buddies. I was talking to her because I
was very concerned about my trailer bearings. I had heard many
horror stories from "experts" on the Trailer Sailor Forum and didn't
want to have any of those things happen to me in the wilds of the
Arizona Desert.
Starting at the beginning:
My boat is a 23' sailboat made by Coastal Recreation in 1974. The
Aquarius 23 is a very well designed boat, (Peter Barrett) handling just
about any weather I care to be in and has held up extremely well
considering it's age. It's 4200 pounds total average weight on two 3500
pound axles.
The trailer is an original Trail-Rite dual axle trailer, made and built
specifically for my hull number. Yep...the original trailer. I had new
bearings put in in 2004 when I bought the boat as that was the one
place where I knew I could get into trouble on the road. I also had to
have the frame rail bent back into shape and an additional frame rail on
each side welded on top of old one as the original owner used to run
the boat into the beaches of Mexico and launch anywhere. The trailer
had taken a beating...
So back to the phone call with BB's lady expert. Basically the
conversation boiled down to a simple thought: She asked me "How
often do you replace your car bearings? Rarely ever, right? So why do
all these people burn out boat bearings?"
That got me to thinking....
She then told me the simplest way to get good bearing life:
1: Take the wheels apart. Look closely at the bearing races and the
axle. If everything looks good on the axle end, buy new bearings of
good quality (Like Timco or any good USA made bearing) and have
the inner bearing race pressed properly with a new, good brand seal.
2: Then hand pack the bearings with a good water proof type grease.
The blue/green stuff at auto parts stores is best. Yes, handpack.
Nothing like being able to get the grease in every nook and cranny of
the bearings.
3: Fill the cavity between the inner and outer race with grease. Place
the inner bearing in and snug down the axle nut tightly. This seats the bearing in the race properly.
Release the tension on the axle nut and re-tighten. Tighten only enough to get
"most" of the movement out of the wheel. Grab the tire at 3 o'clock
and 9 o'clock and see if the wheel moves from side to side. You want
just a touch of movement. Do the same at 12 and 6 o'clock. If too loose,
tighten 1/4 turn and try again. Do NOT take out all the movement in the
wheel. When you think you have it right, snug up axle nut just enough
to get the cotter key through the nut. BUT make sure the wheel can be moved just a touch.
Done with that.
"You see," she said, "the number 1 killer of boat bearings is they end up being to tight.
Tight means heat, heat means bearing death."
4: Now fill the inner cavity of the bearing buddie (BB) with same
grease...making sure the BB plate and spring are clean and the plate
moves against the spring pressure freely when you push with finger.
Put the BB on the axle and tap it in. Now add grease to the BB until the plate pushes out about 1/2
way. This is the proper "pre-load" for the BB...giving you about 3 lbs of
positive pressure in the hub. This is what really keeps out the water
and dirt!
5: Go for a drive. Go for at least 30 minutes at highway speeds to burp
out any air in the bearing cavity...then pull over and stop. Pull over
slowly, if you have brakes, so they don't heat up the axle. Check your
temps. Bearings should be cool to touch. One side may be warmer
than other if road is crowned as that side will have more weight on it.
The BB's and hubs should not be warmer than the ambient air.
Also...look at the BB plate and note it's position. If it's moved inwards
a touch...you are good. Any more than that, you need a shot of grease
to bring it back out. Then go home.
6: Now here is the kicker. Every year, you should jack up the trailer
and check each bearing for roughness or noise. You can do this with
the wheels on or not...your choice. BUT...whatever you do...DO NOT
TOUCH the BB or the bearings at all if they feel good. If they feel/sound
noisy, then replace the bearings in the axle....but if you bought good
ones, chances are you will go years without having to do anything
more than taking off the BB's and cleaning them then putting new
grease in to replace what you took off to clean the BB and fill the cavity
up again. Go for a test ride, check temps and the pressure plate and
forget about them for another year.
7: Now on each and every trip, when I stop, I check the hub temps with
my hand. A simple walk around...touching the hubs and looking at the
tie downs, the mast, the motor, etc.. It's normal for me to do this.
Bottom line: Same bearings on the boat since 2004. Different BB's as
some have fallen off on the road, others had become so grungie I felt
it was smart to replace them. My bearings still run cool...even towing
at 65 mph across the Arizona desert toward California at 115 degrees
outside.
In November, just a few weeks ago, we went out to the lake for the first
time in two years. Before that it was two years again before the boat
had seen the water. And one of those years, 2013, I towed her from Arizona
to New Hampshire where she sat for a year through the New England
Winter...buried in 4 feet of snow then towed back to Arizona. All
without any problems on the bearings. I simply checked for noise and
roughness, added grease if needed and drove off...
As I mentioned at the beginning...this is really simple. But it amazes
me how many people still have troubles with their bearings.
Now if you don't run BB's on your trailer, fine. Then you should pop off
the cap each season and check for dirt. A little water may drain out
and that's ok...since the waterproof grease will stick to the bearing
surfaces and water will not. So if it gets in, it will do no harm. If the
bearings do get really dirty, then yes, pop them off, clean them, grease
them up by hand and put them on with the proper tightness...which is
really loose! As long as they are clean and not scored...the bearings
should last a very long time!
Remember at the beginning of this conversation I was asked by the
BB lady how often I changed my car bearings? Now you know why she
asked. With good bearings, properly installed..there is no reason why
the bearings shouldn't last for years. With minimum maintenance.
Now you know.
Arizona Desert.
pound axles.
the bearings.
Done with that.
and dirt!
outside.
Now you know.
http://www.venturerider.org/forum/attachment.php?attachmentid=107864
Thanks for re-writing that post. Pretty much how I've always taken care of my trailer bearings, my trailers, boat and utility have dexter ez-lube spindles that keep the cavity filled and work good. I've never had a bearing failure while on the road.
Sent from my SM-N920V using Tapatalk
