cowpuc Posted October 7, 2016 Posted October 7, 2016 Got the bike out for a ride yesterday, I think all these new VOLTS have added about 50HP to my ride Everything is working good, but I have some popping from the left pipe now, must have ruined one or two exhaust gaskets, they'll wait till the to get fixed. FIDDY HORSE?? FIDDY MORE HORSEYS!!! I WANT FIDDY MORE HORSE!! Now which wires do I cross Raggy? Come on - GIVE !!!
ragtop69gs Posted October 7, 2016 Author Posted October 7, 2016 FIDDY HORSE?? FIDDY MORE HORSEYS!!! I WANT FIDDY MORE HORSE!! Now which wires do I cross Raggy? Come on - GIVE !!!
cowpuc Posted October 7, 2016 Posted October 7, 2016 You lop eared wiley tight lipped bandit varmint!!! Next year during a Hot Dog feast I guess I will just have to dismantle your scoot while your not looking and see if I can figure it out for my own self...
Flyinfool Posted October 7, 2016 Posted October 7, 2016 Got the bike out for a ride yesterday, I think all these new VOLTS have added about 50HP to my ride Everything is working good, but I have some popping from the left pipe now, must have ruined one or two exhaust gaskets, they'll wait till the to get fixed. FIDDY HORSE?? FIDDY MORE HORSEYS!!! I WANT FIDDY MORE HORSE!! Now which wires do I cross Raggy? Come on - GIVE !!! Yea GIVE IT UP............. Well since you asked for so you can disassemble............................ It must be time to dust off the SNOWPER CHARGER .................. Puc you better duck, your kind of in the middle.
cowpuc Posted October 8, 2016 Posted October 8, 2016 Yea GIVE IT UP............. Well since you asked for so you can disassemble............................ It must be time to dust off the SNOWPER CHARGER .................. Puc you better duck, your kind of in the middle. Up,, up I say UP,,, aim that chute UP Fool,, we all the new members on here waiting to experience their first official Wisconsin White Washer, fully Snoper Charged winter extravaganza you need to point that chute UP so it gets to em!!! Ol Pucster is ALWAYS willing to share brother - UP = POINT IT UP!!
Flyinfool Posted October 8, 2016 Posted October 8, 2016 With the new long range nozzles, (so I can spread the enjoyment) and the new to me 1.21 gigawatt flux capacitor (Stole it out of an old DeLorean I found in the bone yard) powering the Snowper Charger that feeds into the white washer, if I aim it to high it will hit London or even Paris and f the wind is right even Moscow. The velocity is so much higher now that I have to aim low.......................... And it just seems that your buddy @saddlebum opened up that back door and sent down a blast of that Canadian air that I need for mixing.
bongobobny Posted October 8, 2016 Posted October 8, 2016 Yes, I see you gave it a trial run over Utah...
bongobobny Posted October 10, 2016 Posted October 10, 2016 The other day coming home from my Step daughters place I figured out what /how his problem happened. Jay has a relay primary winding hooked up between the accessory plug and battery ground. When that ground wire got hooked up to the battery plus, the relay coil acted as just a long piece of wire directly to the plus side of the accessory plug, and the voltage went through the accessory fuse back into the audio fuse and to the radio power line, so the radio ALWAYS had power even with the key off. Mystery solved!!
Flyinfool Posted October 11, 2016 Posted October 11, 2016 Dan Electricity is really clever at finding a path to keep flowing. Does that make more sense?
Yammer Dan Posted October 11, 2016 Posted October 11, 2016 Jeff I spent 20 yrs as a lineman before I quit working and became employed by the State!! I play with Hi Voltage enough to know that stuff can do some Crazy things!! But the big stuff is easy compared to our little 12 volt stuff.
Flyinfool Posted October 11, 2016 Posted October 11, 2016 Naaa Works the same, just bigger consequences
saddlebum Posted October 11, 2016 Posted October 11, 2016 With the new long range nozzles, (so I can spread the enjoyment) and the new to me 1.21 gigawatt flux capacitor (Stole it out of an old DeLorean I found in the bone yard) powering the Snowper Charger that feeds into the white washer, if I aim it to high it will hit London or even Paris and f the wind is right even Moscow. The velocity is so much higher now that I have to aim low.......................... And it just seems that your buddy saddlebum opened up that back door and sent down a blast of that Canadian air that I need for mixing. Ok Flyinfool you just Just hold on one doggone minute here .............. I am being framed ..............I aint left no door open .........YET
Marcarl Posted October 11, 2016 Posted October 11, 2016 The other day coming home from my Step daughters place I figured out what /how his problem happened. Jay has a relay primary winding hooked up between the accessory plug and battery ground. When that ground wire got hooked up to the battery plus, the relay coil acted as just a long piece of wire directly to the plus side of the accessory plug, and the voltage went through the accessory fuse back into the audio fuse and to the radio power line, so the radio ALWAYS had power even with the key off. Mystery solved!! No flippin wonder they won't let him across the border,,,, that could be catching and then how do you stop it from spreading.
Flyinfool Posted October 11, 2016 Posted October 11, 2016 Ok Flyinfool you just Just hold on one doggone minute here .............. I am being framed ..............I aint left no door open .........YET I found FROST on my windshield. It is obvious someone has been exercising the door hinges up there.
saddlebum Posted October 11, 2016 Posted October 11, 2016 I found FROST on my windshield. It is obvious someone has been exercising the door hinges up there.Sure ........Soooo the 1st guy you blame is innocent ole me.
Flyinfool Posted October 11, 2016 Posted October 11, 2016 Sure ........Soooo the 1st guy you blame is innocent ole me. Thank you for understanding just how this works................
cowpuc Posted October 12, 2016 Posted October 12, 2016 Sure ........Soooo the 1st guy you blame is innocent ole me. Thank you for understanding just how this works................ Amazing how deathly quiet it gets around here when the Saddle Fly's start their yearly infamous activities!! :witch_brew:
Yammer Dan Posted October 12, 2016 Posted October 12, 2016 Charlie used to be bad about forgetting to close that door!! Where are ya Charlie?
Yammer Dan Posted October 12, 2016 Posted October 12, 2016 I don't know who left it open but trip out on deck tonight in my Fruit of the Looms was short lived!! Brrrr.
snyper316 Posted October 17, 2016 Posted October 17, 2016 Well the past few days have been mild and today it was 85. Tomorrow its supposed to be 90!! This darned Missouri weather is just friggin crazy. FYI this weeken its supposed to be in the 60's.. I thought it was October but it sure don't feel or look like it. I have only seen one tree with changing colors.
