XV1100SE Posted August 24, 2015 Share #76 Posted August 24, 2015 If you read the comparisons in the mags you know that in comparisons to the big tourers... Venture came in 1st or 2nd. Try the things suggested (start with the least expensive or has the highest potential to resolve your issue). Great bike and you'll enjoy it for thousands of trouble free riding. Link to comment Share on other sites More sharing options...
douglasp.burdick Posted August 25, 2015 Author Share #77 Posted August 25, 2015 Well, I got to ride Rmar's venture today and what a difference. He has the Baron's risers and the Michellen 130/90/16 up front and it's a much easer bike to handle at all speeds, not just low speeds. The shorter tire up front makes it noticably eaiser to get on and off of and seems to lower the center of gravity. Now to make those changes in my bike and switch oil to 20/50 and see if that helps with the noise. I'll post my results later. Thanks for all the help guys! Link to comment Share on other sites More sharing options...
rbig1 Posted August 26, 2015 Share #78 Posted August 26, 2015 is your clutch fluid dark brown. it may not be releasing all the way. Mine about drove me crazy when I first got it. changed fluid then replaced clutch discs and spring. pulls a little harder but will never get ride of bike till its dead and cant find parts. Link to comment Share on other sites More sharing options...
Flyinfool Posted August 26, 2015 Share #79 Posted August 26, 2015 But the big question, while you traded bikes, did you determine that your noise is "normal" or a problem in the making. Link to comment Share on other sites More sharing options...
douglasp.burdick Posted August 26, 2015 Author Share #80 Posted August 26, 2015 is your clutch fluid dark brown. it may not be releasing all the way. Mine about drove me crazy when I first got it. changed fluid then replaced clutch discs and spring. pulls a little harder but will never get ride of bike till its dead and cant find parts. Hard to tell by just looking through the small sight glass on the resivor, so I plan on just changing it, along with the front and rear brake fluid. Link to comment Share on other sites More sharing options...
douglasp.burdick Posted August 26, 2015 Author Share #81 Posted August 26, 2015 But the big question, while you traded bikes, did you determine that your noise is "normal" or a problem in the making.Well, it's louder than RMAR's bike. So I figure I'll switch from the 10/40 to a 20/50 and see if that helps quite things. He said that at or around 70, the noise fades but I seldom ride that fast, so hopefully thicker oil will help. Link to comment Share on other sites More sharing options...
XV1100SE Posted August 26, 2015 Share #82 Posted August 26, 2015 Just make sure the oil is for a wet clutch with no friction modifiers. Link to comment Share on other sites More sharing options...
douglasp.burdick Posted August 26, 2015 Author Share #83 Posted August 26, 2015 Just make sure the oil is for a wet clutch with no friction modifiers. Right! Link to comment Share on other sites More sharing options...
Ace Posted August 28, 2015 Share #84 Posted August 28, 2015 Well, it's louder than RMAR's bike. So I figure I'll switch from the 10/40 to a 20/50 and see if that helps quite things. He said that at or around 70, the noise fades but I seldom ride that fast, so hopefully thicker oil will help. Just in case you aren't aware, RSV's speedometers read high so at 70 on the speedo you are only going approximately 65MPH. On my bike the noise fades drastically when I run 72 on the speedo then all the way to about 80 its good. Heavier oil does help a wee bit. Link to comment Share on other sites More sharing options...
douglasp.burdick Posted August 29, 2015 Author Share #85 Posted August 29, 2015 (edited) I switched to 20/50 today and I swear it is better. The frequency of the whine is lower, not as loud. Edited August 29, 2015 by douglasp.burdick Link to comment Share on other sites More sharing options...
Flyinfool Posted August 29, 2015 Share #86 Posted August 29, 2015 different brands of the same weight oil will make a difference also. But the oil that makes one bike the quietest may be the loudest oil in the next bike. Link to comment Share on other sites More sharing options...
TDunc Posted September 5, 2015 Share #87 Posted September 5, 2015 Hey Joe, We just need to grab him and take him to the mtns.... That whine will disappear...!!! lol Link to comment Share on other sites More sharing options...
Mike G in SC Posted September 5, 2015 Share #88 Posted September 5, 2015 Doug, I just saw this thread tonight. Not as frequent on the forum as I was. I live in Lugoff,,, right down Hwy 34 from you. I am semi-retired. You have already changed oil and if that has got it, good. Else, we can hook up and let me ride yours,,, you ride mine type thing. I have a 2009 RSV and a 2006 RSTD. Both lowered and lot's of miles on them. No whine on the RSTD,,, but has loud cans. The first owner DID change the basket under warranty. Some whine on the RSV but usually just in the mountains going up. It does have a stock basket. Anyhow, if you want to compare notes send me a PM and can exchange phone and email. Can meet you at the Sonic in Winnsboro, buy me a shake. Mike G in SC Link to comment Share on other sites More sharing options...
Rmar Posted September 8, 2015 Share #89 Posted September 8, 2015 Doug, How is the project progressing. Have you done much riding. Update please. Ricky Link to comment Share on other sites More sharing options...
douglasp.burdick Posted September 9, 2015 Author Share #90 Posted September 9, 2015 As a follow up, the 20/50 oil is helping with the noise, and the 130/90/ commander front tire has helped with low speed handling. we are getting there! Link to comment Share on other sites More sharing options...
videoarizona Posted September 10, 2015 Share #91 Posted September 10, 2015 Yep...good. Now lower the front end between 3/4 to 1 inch...and while you are there, test the steering bearings for being to loose. Techniques and quick fix threads are both fairly recent here in the forum...check the tech area... Link to comment Share on other sites More sharing options...
