OutKast Posted September 17, 2012 Share #1 Posted September 17, 2012 Bad front wheel bearings 540-309-3601 if you can help. 04 second Gen 3pm Mon Link to comment Share on other sites More sharing options...
mm482 Posted September 17, 2012 Share #2 Posted September 17, 2012 Yamaha of Lumberton NC. has two front wheel bearing for your bike. They are 19.00 each plus tax. Their # is 919-738-1454 . All the dealers in Florance are closed today. Earl Link to comment Share on other sites More sharing options...
djh3 Posted September 17, 2012 Share #3 Posted September 17, 2012 I see a couple guys in the Columbia are in the assistance section. Probably about as close as you can get. Unfortunatly most dealers are closed on Sun and Mon. Link to comment Share on other sites More sharing options...
Kirby Posted September 17, 2012 Share #4 Posted September 17, 2012 Take the bearing to a parts house and see if they can cross match the bearing. Link to comment Share on other sites More sharing options...
Sleeperhawk Posted September 17, 2012 Share #5 Posted September 17, 2012 (edited) Outcast called me but I was at work. I knew someone had the bearing numbers. Tried to call him back but no answer. Update: Just talked to Outcast, Kitty is about there with the trailer. Could not find anyone in Florence that had the bearings. He will call me if he any more issues arise, otherwise they will go on home tonight. Edited September 17, 2012 by Sleeperhawk Link to comment Share on other sites More sharing options...
Eck Posted September 18, 2012 Share #6 Posted September 18, 2012 I called Outcast a while ago ( around 3:30pm..). He already recieved the bearing numbers from Muffinman and he was at some place trying to get the bearing numebrs cross refferenced since motorycle shops are closed on Mondays in that area. Outcast said his wife was on the way with trailer, but he was hopeing that he could get the bearings cross refferenced and and get them installed before his wife made the 2 (or 3) hour trip to where he was with the trailer.. I left him with my phone number in case he needed any more bearing information or help of any kind. Sorry I did not post this earlier.. I was not thinking I guess.. Link to comment Share on other sites More sharing options...
RandyR Posted September 18, 2012 Share #7 Posted September 18, 2012 per another thread here: All Balls makes a front bearing kit with seals that sells for about $25.00 That's half of what yamaha gets for the oem parts ordered individually. The part number for the kit is 12-5545 Ragtop69gs Link to comment Share on other sites More sharing options...
ragtop69gs Posted September 18, 2012 Share #8 Posted September 18, 2012 per another thread here: All Balls makes a front bearing kit with seals that sells for about $25.00 That's half of what yamaha gets for the oem parts ordered individually. The part number for the kit is 12-5545 Ragtop69gs Also you will need a blind hole bearing puller to remove the bearings, you can rent one for free at autozone or most oyher chain parts stores. Good luck with the repair. Link to comment Share on other sites More sharing options...
etcswjoe Posted September 18, 2012 Share #9 Posted September 18, 2012 Did Outkast get out of Florence ok? Link to comment Share on other sites More sharing options...
OutKast Posted September 18, 2012 Author Share #10 Posted September 18, 2012 And here I thought the "engine cutoff" was gonna kill me. But not one single symptom of that during the trip. Thanks everyone that called and tried to help. Muffinman got me the bearing number B6004, but guy at advance was unable to locate or crossreference. Kid at ORielly immmediately cross-referenced it to Timken 104 or National 104, but did not have one and by then was after 5 pm, so warehouse was closed. Took the new number back to Advance, and it came up then immediately, and even cross-referenced to several manufacturers using 6004 as part of thier part number. Go figure that one. But now was too late to get from thier warehouse also (maybe same one?). So Kitty was a trooper, getting truck and trailer to Florence about 8:30, we loaded and left. Shortly thereafter, the guy riding the 1980 CB900 custom was down in Asheboro. using an astronomical amount of fuel, a full tank was only going about 30 miles. So we stopped and picked him up too. Too fit on my little 5x10 trailer, we had to strip off his vetter, engine guards and saddle bags. But we got them both on there. Arrived at my house at 4:16 am. Had to leave for work at 5:30 am. Hope I don't fall asleep at my desk!!!! Thanks again all. I Will be adding a set of these bearings in my existing travel kit I carry with spare bearings for the trailer, etc. Maybe a few months working and we will be able to afford to travel to catch up with you guys. THANKS EVERYONE! Link to comment Share on other sites More sharing options...
colesgrandpaw Posted September 18, 2012 Share #11 Posted September 18, 2012 Outkast I have a 2006 venture and the 6004 bearings were to small. I got the number from Yamaha dealer parts book. The number that worked was a NSK 60/22DU (yamaha 93306-0042) Link to comment Share on other sites More sharing options...
ragtop69gs Posted September 19, 2012 Share #12 Posted September 19, 2012 Outkast I have a 2006 venture and the 6004 bearings were to small. I got the number from Yamaha dealer parts book. The number that worked was a NSK 60/22DU (yamaha 93306-0042) I was given the 6004 set by one shop, got home only to find they do not work on a second gen. Thats when I ordered up the All Balls set. Link to comment Share on other sites More sharing options...
OutKast Posted September 19, 2012 Author Share #13 Posted September 19, 2012 Outkast I have a 2006 venture and the 6004 bearings were to small. I got the number from Yamaha dealer parts book. The number that worked was a NSK 60/22DU (yamaha 93306-0042) YES The number Muffinman gave me was B6004, which I understand to be different from the more common 6004. I couldn't tell you why!! Link to comment Share on other sites More sharing options...
colesgrandpaw Posted September 19, 2012 Share #14 Posted September 19, 2012 KIMPEX® 60/22 DU BALL BEARINGS 60/22 DU, 44 mm o.d. x 22 mm i.d. x 12 mm large, 2 seals Yamaha – 93306-00420-00 Front Axle Replaces Yamaha 93306-00412-00 by removing both seals on the bearing. 1979-80 EC 540 1980-83 SS 440 1980-93 SR 540 except 1984 1981 SRX 440 1983-93 VMX 540 1984-94 PZ 480 1985-86/88 XL 540 1987-93 EX 570 1989-94 CS 340/VT 480 1994-98 ET 410 Yamaha – 93306-00412-00 Front axle 1971 GP 396 • SS 433 • SW 396 • 1971-73 SL 292 • SR 433 1971-74 SL 338 • 1972-73 EW 433, 643 • GP 643 • SR 643 • SW 433 1972-74 SL 433 • 1972-75 GP 292, 433 • 1973 EL 433 • SR 292 1973-74 GP 338 • SM 292 • 1974 GP 246 • TW 433 1974-75 GPX 338, 433 • TL 433 • 1975 GS 338 1976 GP 300 • GS 250 • SRX 340 • 1976-77 GS 300 • PR 440 STXX 340, 440 • 1976-78 EX 340 • GP 440 • GS 340 1976-80 SRX 440 • 1976-81 EX 440 • 1978 SSR 440 Yamaha – 93306-00412-00 Rear Axle • 1971 SS 433 1971-72 SR 433, 643 • 1971-73 GP 292, 396, 433, 643 SW 396, 433 • 1971-74 SL 292, 338, 433 1972-73 EW 433, 643 • 1973 EL 433 • 1974 TL 433 Item Item Code M.S.R.P. OEM No. 93306-00412-00 ADVERTISER INFORMATION PRIVACY STATEMENT COPYRIGHT TERMS DEALER INFORMATION © Copyright 2012, Dominion Enterprises All rights reserved. KIMPEX® 60/22 DU BALL BEARINGS 60/22 DU, 44 mm o.d. x 22 mm i.d. x 12 mm large, 2 seals Yamaha – 93306-00420-00 Front Axle Replaces Yamaha 93306-00412-00 by removing both seals on the bearing. 1979-80 EC 540 1980-83 SS 440 1980-93 SR 540 except 1984 1981 SRX 440 1983-93 VMX 540 1984-94 PZ 480 1985-86/88 XL 540 1987-93 EX 570 1989-94 CS 340/VT 480 1994-98 ET 410 Yamaha – 93306-00412-00 Front axle 1971 GP 396 • SS 433 • SW 396 • 1971-73 SL 292 • SR 433 1971-74 SL 338 • 1972-73 EW 433, 643 • GP 643 • SR 643 • SW 433 1972-74 SL 433 • 1972-75 GP 292, 433 • 1973 EL 433 • SR 292 1973-74 GP 338 • SM 292 • 1974 GP 246 • TW 433 1974-75 GPX 338, 433 • TL 433 • 1975 GS 338 1976 GP 300 • GS 250 • SRX 340 • 1976-77 GS 300 • PR 440 STXX 340, 440 • 1976-78 EX 340 • GP 440 • GS 340 1976-80 SRX 440 • 1976-81 EX 440 • 1978 SSR 440 Yamaha – 93306-00412-00 Rear Axle • 1971 SS 433 1971-72 SR 433, 643 • 1971-73 GP 292, 396, 433, 643 SW 396, 433 • 1971-74 SL 292, 338, 433 1972-73 EW 433, 643 • 1973 EL 433 • 1974 TL 433 Item Item Code M.S.R.P. OEM No. 93306-00412- Link to comment Share on other sites More sharing options...
OutKast Posted October 3, 2012 Author Share #15 Posted October 3, 2012 (edited) Time to conclude. Never got a crossover to the B6004 number. Removed bearings were the NSK 60/22DU noted above. I purchased the All Balls kit 41-3414. The bearings in that kit are KML 60/22-2RD. Maybe this will help some else crossover. But might as well get the kit as you will also probably need the "oil" seals. As for another thread about carrying extra bearings on trips, I am sure glad I ending up NOT trying this along the road. The OK bearing was no problem, a long blunt instrument and careful tapping from behind drove out both the bearing and seal intact, in about 5 minutes. The "bad" bearing had completely come apart, the inner race and balls came out with the axle. The outer race sits down and bottoms in a pocket. The long blunt instrument from behind will NOT contact the inner race. You CANNOT get behind the race to catch it with an "inside" bearing puller. The only place to catch it is the tapered groove the balls ride in. Prying from the front is futile. 3 hours later, by mis-applying a "pilot bearing puller", using a pair of channel locks to catch the legs of the puller on, and heavy beating on the puller from behind with the blunt tool, the outer race was out. sigh but all is well with that now. My suggestion, when in doubt change them. My bike has 67k miles Edited October 3, 2012 by OutKast give mileage Link to comment Share on other sites More sharing options...
