usedcyclesales Posted January 31, 2012 Share #1 Posted January 31, 2012 I have to remove the gear cover to get at the slave cylinder to replace clutch line I removed all the bolts but before i go and try to pry it off I need to make sure theres nothing else to look for I only found 7 bolts and the service manual IS NOT very clear as to what to remove any one done it before??? Link to comment Share on other sites More sharing options...
dingy Posted January 31, 2012 Share #2 Posted January 31, 2012 Parts breakdown shows 7 bolts, in 3 different sizes holding cover on. Nothing else. Gary Link to comment Share on other sites More sharing options...
usedcyclesales Posted January 31, 2012 Author Share #3 Posted January 31, 2012 I see that, just seems like it's stuck on with glue and I'm just a bit leary about prying it off. I'll give it a shot thanks!! Link to comment Share on other sites More sharing options...
Squidley Posted January 31, 2012 Share #4 Posted January 31, 2012 Some of the gaskets really stick well, the middle gear cover on the G2 also holds the pivot shaft for the gear shifter. That could be a little sticky as well, you might want to cover the outside of the cover with a towel and give it a good rap with a rubber hammer to break the seal.... Link to comment Share on other sites More sharing options...
Owen Posted January 31, 2012 Share #5 Posted January 31, 2012 Some of the gaskets really stick well, the middle gear cover on the G2 also holds the pivot shaft for the gear shifter. That could be a little sticky as well, you might want to cover the outside of the cover with a towel and give it a good rap with a rubber hammer to break the seal.... And I will add... once it comes loose watch the sharp edges!!! Link to comment Share on other sites More sharing options...
usedcyclesales Posted January 31, 2012 Author Share #6 Posted January 31, 2012 Well I gave it a couple a good SMACKS!! and it finally came off!! Amazing a 1999 with 37K on it and everything in there looks brand new! Link to comment Share on other sites More sharing options...
djh3 Posted January 31, 2012 Share #7 Posted January 31, 2012 Well except the slave right? Link to comment Share on other sites More sharing options...
Condor Posted January 31, 2012 Share #8 Posted January 31, 2012 Well I gave it a couple a good SMACKS!! and it finally came off!! Amazing a 1999 with 37K on it and everything in there looks brand new! So... Used, when are we going to see 'supporting member' under your board name. With all the help and advice you've already received from members here I would think by now you would have thought joining the board would be a good idea.... Link to comment Share on other sites More sharing options...
Caveman Posted January 31, 2012 Share #9 Posted January 31, 2012 :sign yeah that:c'mon ya know it's worth it... Link to comment Share on other sites More sharing options...
Rick Haywood Posted February 1, 2012 Share #10 Posted February 1, 2012 Come on man...............time to fork over the 12 bucks and be like the rest of us. You know you want to and we'd miss ya if you dissappeared Link to comment Share on other sites More sharing options...
