V7Goose Posted November 21, 2007 Share #1 Posted November 21, 2007 I really struggled to get the residual stick-um off the tank when I took the stickers off my 05. Some people say Goo Gone works, but didn't do nuthin for me. I also tried acetone, paint thinner, lighter fluid, WD-40, alcohol, etc. etc., and NONE of it really seemed to help much. Some softened the goo to make it a little easier to scrape, but still left a lot of residue. Took me a long time and a lot of hard scrubbing with a rag to eventually get it all off. I dreaded this chore on my 07, but I found a perfect solution! Goof Off (any hardware store) will eat at the plastic sticker and soften the stick-um, making it pretty easy to scrape the sticker off with a thumbnail, but the leftover stick-um will still be hard to wipe completely off. I found a spray can of stuff from MG Chemicals at Fry's Electronics called Label & Adhesive Remover that takes the glue off just as easy as wiping up jelly with a wet sponge! Didn't seem to do much on the sticker, so I made it a two step process - Goof Off first to scrape the sticker, then a quick spray on the leftover goo and a wipe with a rag and done. Sooooo much easier than the fight I had with my first RSV, and no waiting around for the stuff to eventually get soft - almost instant gratification. The whole job couldn't have taken more that a couple of minutes. Goose Link to comment Share on other sites More sharing options...
Condor Posted November 21, 2007 Share #2 Posted November 21, 2007 Sooooo much easier than the fight I had with my first RSV, and no waiting around for the stuff to eventually get soft - almost instant gratification. The whole job couldn't have taken more that a couple of minutes. Goose It's called chemical warfare!!!! Link to comment Share on other sites More sharing options...
BuddyRich Posted November 21, 2007 Share #3 Posted November 21, 2007 If you swing by your local auto paint suppler they usually have 3M automotive Adhesive Remover. Link to comment Share on other sites More sharing options...
robertbob Posted November 22, 2007 Share #4 Posted November 22, 2007 Way not use a hair dryer. :rotf: Link to comment Share on other sites More sharing options...
Squidley Posted November 22, 2007 Share #5 Posted November 22, 2007 Way not use a hair dryer. :rotf: Sounds logical....but it doesn't work. They really use good adhesive to put them on. The eyebrows on the front fairing are even worse to get off Link to comment Share on other sites More sharing options...
robertbob Posted November 22, 2007 Share #6 Posted November 22, 2007 Sorry Squidley, I don't have a clue as to what you are taking about! ""The eyebrows on the front fairing are even worse to get off"" The tank stickers on my 05 came off with the hair dryer in three min. Link to comment Share on other sites More sharing options...
Squidley Posted November 22, 2007 Share #7 Posted November 22, 2007 Sorry Squidley, I don't have a clue as to what you are taking about! ""The eyebrows on the front fairing are even worse to get off"" The tank stickers on my 05 came off with the hair dryer in three min. The chrome eyebrows that I am talking about are on the upper front fairing at a 45 degree angle from the headlight. Link to comment Share on other sites More sharing options...
Marcarl Posted November 22, 2007 Share #8 Posted November 22, 2007 Just leave the stuff on there, it helps to make it look faster. PROBLEM SOLVED.:happy65: Link to comment Share on other sites More sharing options...
Pilot Posted November 22, 2007 Share #9 Posted November 22, 2007 I used a commercial heat gun and Goo Be Gone to remove the tank emblems, tank gas warning sticker and the Yamaha emblem on the trunk lid. It took about an hour to remove all these and the left over residue, what there was of it. Be careful with this type heat gun because it can get very hot. I put my hand next to the area I want to heat up and judge the temperature using me hand. If I want to move my hand then it’s hot enough. The 3M double sided tape used to attach the emblems just came loose after about 2 minutes of applied heat. The left over tape residue just came off with Goo Be Gone, no rubbing required. The secret with using Goo Be Gone is to cover the area with a clean rag, soak the rag with Goo Be Gone, let it sit for about 5 minutes and then use the wet rag to clean the area. After use a wet rag with a bit of soap, rinse it off, apply some wax and your good to go. At least that’s how I did mine. Ohh forgot that the hour was interrupted by 2 beers. Link to comment Share on other sites More sharing options...
Mariner Fan Posted November 22, 2007 Share #10 Posted November 22, 2007 Thanks Goose. I'm going to take the sticker off my tank tomorrow. Link to comment Share on other sites More sharing options...
Bodean Posted November 22, 2007 Share #11 Posted November 22, 2007 I pealed the sticker off with my finger nail and used gasoline on a rag to wipe off the glue worked pretty fast. Had to wax the tank afterwards but needed it anyway. Link to comment Share on other sites More sharing options...
junkyardog53 Posted November 22, 2007 Share #12 Posted November 22, 2007 just a hair dryer and your spray that you clean your bike with,got mine off in 3 minutes Link to comment Share on other sites More sharing options...
Eugene Posted November 22, 2007 Share #13 Posted November 22, 2007 Just peel off after using a heat gun or hair dryer -then use...... PEANUT BUTTER!!!!! Its worked for me for many years on many stickers - takes all the goo away with no damage Link to comment Share on other sites More sharing options...
Guest leemcd Posted November 26, 2007 Share #14 Posted November 26, 2007 You can remove tank stickers using a heat gun and/or "3M General Purpose Adhesive Cleaner" (GPAC), p/n 08984, available at most auto body supply stores. I use this to remove body adhesive backed mouldings. If you soak a rag with this stuff and let it sit on the decal for a few minutes, you can remove it easily with you finger nails or a plastic bondo paddle or by rubing the decal with the GPAC. It may take several applications. After you've wiped off the remaining glue, follow up with you favorite wax, glaze, or detailer. The whole operation takes about 10-15 minutes. Simple! I've done lot's of tanks for my friends and have not marred any yet. They come out great and the tank looks better without those ugly CAUTION labels. Link to comment Share on other sites More sharing options...
WIKD Posted November 27, 2007 Share #15 Posted November 27, 2007 Eyebrows came off quick with dental floss. Cut right thru most of the double sided tape and then Goof Off made short work of the little bit of adhesive that was left. Link to comment Share on other sites More sharing options...
eagleeye Posted November 27, 2007 Share #16 Posted November 27, 2007 I must be missing something here. Why are you taking the stickers off? Steve Link to comment Share on other sites More sharing options...
Brake Pad Posted November 27, 2007 Share #17 Posted November 27, 2007 Because the New Harley Davidson ones just came in and he can't wait to install them:stirthepot: Goo Be Gone work best for removing the Glue AFTER peeling off the stickers Link to comment Share on other sites More sharing options...
