Grisolm1 Posted August 28, 2010 Share #1 Posted August 28, 2010 I'm researching the best way to drastically improve front brakes while keeping my integrated brakes intact. I really like the integrated system as it keeps the rear from locking and does a pretty good job stopping the bike. My front brake is "OK", but I know it can be a lot better. Options to consider mixing and matching R1 Caliper 14mm master cylinder from 03 FJR or newer Star V Twin EBC HH pads in stock caliper Stainless lines I know I can use the 14mm master in conjunction with a pair of R1's as many have done, but then I lose the integrated brakes. Anyone put on a single R1 right front caliper and did you use stock or 14mm master? Stainless will be a must. Any real world experience is appreciated. Link to comment Share on other sites More sharing options...
muffinman Posted August 28, 2010 Share #2 Posted August 28, 2010 Staineless lines and EBC HH pads will make a huge improvement if you pull hard enough you can do stoppies with hh pads Jeff Link to comment Share on other sites More sharing options...
friesman Posted August 28, 2010 Share #3 Posted August 28, 2010 Ever since Rocket put ss lines on my 85 my stopping has improved amazingly. I am at least 1/3 less distace to stop than it used to. Brian Link to comment Share on other sites More sharing options...
Rick Butler Posted August 28, 2010 Share #4 Posted August 28, 2010 Well Grisolm, If you like what the integrated system is doing for you on your 88, my suggestion would be go to EBC HH pads and stainless lines. But to put stainless lines in this configuration, you will be required to have Cycle Brakes build you a set of custom lines since I don't think anyone ever offered a set for the 1st gen. The line from the metering valve to the front left caliper is not a common line and also includes the bleeder valve up at the neck. But stainless lines would be much more simple if you delinked the front brakes, where you will need a larger front brake reservoir for another 4 pistons. Unless your current 4 piston calipers are shot, there is no reason to go to R1s because your calipers are just as good. If you did go to R1s and keep them integrated, you will need to replace all 3, as well as go to stainless lines because their banjo bolts are on the side and require straight connections. But like you probably know, the only way you are going to get maximum braking from your front calipers is to apply both brakes at the same time. Hope this helps in your decision, Rick Link to comment Share on other sites More sharing options...
friesman Posted August 28, 2010 Share #5 Posted August 28, 2010 Well Grisolm, If you like what the integrated system is doing for you on your 88, my suggestion would be go to EBC HH pads and stainless lines. But to put stainless lines in this configuration, you will be required to have Cycle Brakes build you a set of custom lines since I don't think anyone ever offered a set for the 1st gen. The line from the metering valve to the front left caliper is not a common line and also includes the bleeder valve up at the neck. But stainless lines would be much more simple if you delinked the front brakes, where you will need a larger front brake reservoir for another 4 pistons. Unless your current 4 piston calipers are shot, there is no reason to go to R1s because your calipers are just as good. If you did go to R1s and keep them integrated, you will need to replace all 3, as well as go to stainless lines because their banjo bolts are on the side and require straight connections. But like you probably know, the only way you are going to get maximum braking from your front calipers is to apply both brakes at the same time. Hope this helps in your decision, Rick I beleive Rocket ordered the ones for my 85 G1 from Buckeye and they came with the extra bleeder up at the top of the triple tree to make bleeding easier too. Brian Link to comment Share on other sites More sharing options...
Snaggletooth Posted August 28, 2010 Share #6 Posted August 28, 2010 Yep...The HH pads and SS lines will be a huge change. I can lock front and back if I whack 'em hard. Just the front brake alone with the SS line will will be such a different feel it will surprise you. I got my set from Rick at Buckeye Performance custom fit for the 1st gen. That included the front bleeder for the metering valve on the back of the tree. Big help in bleeding. http://www.buckeyeperformance.com/p04.htm I think Skydoc_17 here is involved in making lines also. I had an incident a couple of weeks back that proved to me that the brakes are more than effective. Mike Link to comment Share on other sites More sharing options...
Rocket Posted August 28, 2010 Share #7 Posted August 28, 2010 Well Grisolm, If you like what the integrated system is doing for you on your 88, my suggestion would be go to EBC HH pads and stainless lines. But to put stainless lines in this configuration, you will be required to have Cycle Brakes build you a set of custom lines since I don't think anyone ever offered a set for the 1st gen. Hope this helps in your decision, Rick Nope, I have a set for my 86 from Buckeye, waiting to be installed next month, after I get back to base & work. I am currently keeping an eye on the rooster, prior to Bubber geting here in a weeks time, for PIP. Link to comment Share on other sites More sharing options...
Rick Butler Posted August 28, 2010 Share #8 Posted August 28, 2010 Well Mike, It's nice to know that Rick and Buckeye have done something for us that the big guys couldn't (wouldn't) do during the years of 83 to 93. Rick Link to comment Share on other sites More sharing options...
a1bummer Posted August 28, 2010 Share #9 Posted August 28, 2010 Going with SS lines and the pads from Buckeye is my plan as well. I don't have a problem with the brakes on my MKI as they are. But an improvement never hurts. Link to comment Share on other sites More sharing options...
Grisolm1 Posted August 28, 2010 Author Share #10 Posted August 28, 2010 Based on the responses I'll go with EBC HH in the right front caliper and a DIY stainless line just for that circuit. Less than $100 for all. There is a company that makes a mix and match stainless kit. You order the correct banjo's and the line for your application. The banjo has a special fitting, cut the line to length, insert and tighten the fitting. Link to comment Share on other sites More sharing options...
Flyinfool Posted August 29, 2010 Share #11 Posted August 29, 2010 I went with the EBC HH on the right front, with the old original rubber brake line still, and unfortunately yesterday I had to find out that that is enough to lock up the front tire even with no application of the foot brake. Link to comment Share on other sites More sharing options...
tvking63 Posted August 30, 2010 Share #12 Posted August 30, 2010 ............There is a company.......... Any chance you might grace us with the name of the company? Link to comment Share on other sites More sharing options...
jasonm. Posted August 30, 2010 Share #13 Posted August 30, 2010 (edited) YES, SS lines and HH pads are the deal for sure. BUT,If you delink the brakes on the 1300. Be aware the piston sizes on the 1300 1st gen calipers are NOT the same on both fronts!. And the pads will wear faster on one side vs. the other. Edited August 30, 2010 by jasonm. Link to comment Share on other sites More sharing options...
dingy Posted August 30, 2010 Share #14 Posted August 30, 2010 YES, SS lines and HH pads are the deal for sure. BUT,If you delink the brakes on the 1300. Be aware the piston sizes on the 1300 1st gen calipers are NOT the same on both fronts!. And the pads will wear faster on one side vs. the other. Like they don't wear at different rates with integrated brakes. And one of the biggest hazards with linked brakes on an MKI is the anti dives are independent on the front forks. If you only use the front brake, only the one forks anti dive engages. Same with only use of rear brake. This was resolved with the electric anti dives on the MKII's Gary Link to comment Share on other sites More sharing options...
Grisolm1 Posted September 1, 2010 Author Share #15 Posted September 1, 2010 "Any chance you might grace us with the name of the company? " Just dug it up http://magnumshielding.com/brake_lines.htm Link to comment Share on other sites More sharing options...
coy55boy Posted September 1, 2010 Share #16 Posted September 1, 2010 This is great stuff...glad I found this place! Link to comment Share on other sites More sharing options...
tvking63 Posted September 4, 2010 Share #17 Posted September 4, 2010 "Any chance you might grace us with the name of the company? " Just dug it up http://magnumshielding.com/brake_lines.htm Thanks for the info. Link to comment Share on other sites More sharing options...
