jonsmyth Posted March 26, 2010 Posted March 26, 2010 This is my first brake rebuild on this, my 87 model. I was getting leakage on the front wheel. and resulting loss of brake "pedal". When I took the caliper off the bike, I couldn't tell which of the four pistons was leaking. Now I realize I only have one set- not two, which is what i need to do both sides. I'm pretty sure the one closest to the banjo bolt was the culprit- I'll do the "outer" side. I guess it could have been the banjo bolt. I was going to pull the pistons. But how do you get them out without damaging them? Do I need a special tool? I thought this would be EZ. With a 14mm bolt stuck in the banjo bolt hole (inlet) I compressed one side with pliers but boy do they seem tight! Any advice?
Guest human4m Posted March 26, 2010 Posted March 26, 2010 This is my first brake rebuild on this, my 87 model. I was getting leakage on the front wheel. and resulting loss of brake "pedal". When I took the caliper off the bike, I couldn't tell which of the four pistons was leaking. Now I realize I only have one set- not two, which is what i need to do both sides. I'm pretty sure the one closest to the banjo bolt was the culprit- I'll do the "outer" side. I guess it could have been the banjo bolt. I was going to pull the pistons. But how do you get them out without damaging them? Do I need a special tool? I thought this would be EZ. With a 14mm bolt stuck in the banjo bolt hole (inlet) I compressed one side with pliers but boy do they seem tight! Any advice? This isn't Venture-Specific, but it's pretty much the way I've always gotten pistons out of every caliper I've rebuilt. http://www.hvccycle.com/Stuck%20Piston.htm
pick Posted March 26, 2010 Posted March 26, 2010 I held one in with a 2x4 and the other I used compressed air to "pop" it out
yamahamer Posted March 26, 2010 Posted March 26, 2010 I held one in with a 2x4 and the other I used compressed air to "pop" it out Thats how I do it also. The wood is very important, you don't want to shoot it across the garage.
LilBeaver Posted March 26, 2010 Posted March 26, 2010 Thats how I do it also. The wood is very important, you don't want to shoot it across the garage. not to mention the shower of brake fluid that follows )
CaptainJoe Posted March 27, 2010 Posted March 27, 2010 I know this is a little late but I have successfully used a grease fitting in brake calipers and pumped the stuck pistons out using a grease gun. Will work in a pinch... use C-clamps or welding vise grips to hold unfrozen pistons in. Only downside is cleaning up grease but that dissolves rather quickly using gasoline or keroscene.
saddlebum Posted March 27, 2010 Posted March 27, 2010 I know this is a little late but I have successfully used a grease fitting in brake calipers and pumped the stuck pistons out using a grease gun. Will work in a pinch... use C-clamps or welding vise grips to hold unfrozen pistons in. Only downside is cleaning up grease but that dissolves rather quickly using gasoline or keroscene.or brake clean. thats the way i do it also and because grease does not compress like air the risk of a flying missle is reduced
skydoc_17 Posted March 27, 2010 Posted March 27, 2010 This might help: http://www.venturerider.org/classifieds/showproduct.php/product/2443/cat/500 If you want to send the seal kits with the caliper I will cut the price in half. Earl
garyS-NJ Posted September 15, 2015 Posted September 15, 2015 This link isn't working for me. I've done single piston calipers before but with these dual piston calipers I was wondering if the caliper needs to be split in half// Earls ad isn't opening for me either.. This isn't Venture-Specific, but it's pretty much the way I've always gotten pistons out of every caliper I've rebuilt. http://www.hvccycle.com/Stuck%20Piston.htm
garyS-NJ Posted September 15, 2015 Posted September 15, 2015 whoops, just read the manual/ god damm wealth of information in there is one takes the time to actually read. But it says to replace the piston, piston seal, and the dust boot as an assembly. what! Well I see on ebay kits with the seals for $23-30 PER CALIPER. Is that the best I'm doing and is there a good brand to use? (Brake crafter or K&L on ebay). Oh, and from Yamaha it's $40/caliper..
dna9656 Posted September 15, 2015 Posted September 15, 2015 Use the Yamaha dealer as a last resort. If the caliper and piston are in good condition I see no reason not to re-use them. I re-used mine on all my bikes unless (of course) they were FUBAR. K & L is a long standing and trusted name. Brake Crafter is unknown to me but that doesn't mean they aren't any good.
