jarrejx Posted February 3, 2010 #1 Posted February 3, 2010 I ran across this neat little idea on Delphi Forums (DIY Cruiser Forum) and thought it was an easy and inexpensive way to possibly enhance our visual presence on the road. The Radio Shack part cost 2.39 each and was the only cost associated with this modification. Here is the link that contains the pdf instructions for performing this mod. I do not know if you have to be a delphi forum member to read their posts, but if you have any problems accessing it, let me know and I will see about posting the copy I downloaded. Attached are several pix of the mod on MyPalomino. http://forums.delphiforums.com/n/mb/message.asp?webtag=DIYCruisers&msg=11.1
Renne Posted February 3, 2010 #3 Posted February 3, 2010 Great idea! I can imagine many different ways to do this utilizing other "creative" parts..!! COOL! Renne............
jemorrisonjr Posted February 3, 2010 #4 Posted February 3, 2010 I'll be picking mine up on the way home
KB2RWW Posted February 3, 2010 #5 Posted February 3, 2010 that's pretty neat but Radshak's hear carries no parts just cell-phones. You got questions we got cell-phones:hurts:
Cougar Posted February 3, 2010 #6 Posted February 3, 2010 My eyes are seeing right today.. is that part number 277-710 ?? Thanks Jeff
oldandcrotchety Posted February 3, 2010 #7 Posted February 3, 2010 Well that's just pretty cool. May do that my own self.
Cougar Posted February 3, 2010 #9 Posted February 3, 2010 (edited) Think I found it. It is 272-710 it looked like 277 to me on the pdf. http://www.radioshack.com/product/index.jsp?productId=2102795 Oops, still looking that one is RED we need Orange. Nope I guess it was red after reading some of there post Well, I'm getting older too, so we may both get it wrong! However, I think that, while the turn signal lens is amber and the new jewel lens is red, ambient light shining through the amber lens and the jewel may have an orange tint. At night, the jewels shine ruby red. One person said something about using a single LED light.. Looking into that as well. Jeff Edited February 3, 2010 by Cougar
spear Posted February 3, 2010 #10 Posted February 3, 2010 That IS cool. But from a technical aspect (from one who spends a lot of time in his workshop doing OTHER things) it will be far easier to drill that 5/8" hole from the INSIDE of the reflector than it will be from the outside. Your drill bit will centre itself far easier in a depression than it will on an outer curved surface. And you'll be more accurate centering it on the bulb. (But you already figured that!)
Cougar Posted February 3, 2010 #11 Posted February 3, 2010 Spear, *LOL* Nope, thanks for the tip! I probably would have drilled like shown
SilvrT Posted February 3, 2010 #12 Posted February 3, 2010 spear said: That IS cool. But from a technical aspect (from one who spends a lot of time in his workshop doing OTHER things) it will be far easier to drill that 5/8" hole from the INSIDE of the reflector than it will be from the outside. Your drill bit will centre itself far easier in a depression than it will on an outer curved surface. And you'll be more accurate centering it on the bulb. (But you already figured that!) One should drill a small "pilot" hole first (either from inside or outside) ... appx 1/8 inch. It will make the 5/8 one easier, especially from the outside and the 1/8 will be a LOT easier from the outside. If you take a centre punch or something with a sharp point and give it a whack (not too hard) where you want the hole to be, the 1/8 bit will catch that and stay centred when you start to drill ... use a variable speed drill and start slowly and once the bit starts cutting you can pick up the speed (if drilling from the outside) just my $0.05
bryan52577 Posted February 3, 2010 #13 Posted February 3, 2010 SilvrT said: One should drill a small "pilot" hole first (either from inside or outside) ... appx 1/8 inch. It will make the 5/8 one easier, especially from the outside and the 1/8 will be a LOT easier from the outside. If you take a centre punch or something with a sharp point and give it a whack (not too hard) where you want the hole to be, the 1/8 bit will catch that and stay centred when you start to drill ... use a variable speed drill and start slowly and once the bit starts cutting you can pick up the speed (if drilling from the outside) just my $0.05 Totally agree with the 1/8" drill bit. But I would guess that the turn signal housing is plastic, not metal. So be VERY careful if you try a punch as it may crack your housing if it is very cold. I checked mine on the Honda (as it happen to be the closest at the time) and there is no magnetic pull at all with a magnet. Maybe someone knows better but the last two bikes I had the turn signal housings were plastic (Don't ask me how I found that out). Bryan
jarrejx Posted February 4, 2010 Author #14 Posted February 4, 2010 SilvrT said: One should drill a small "pilot" hole first (either from inside or outside) ... appx 1/8 inch. It will make the 5/8 one easier, especially from the outside and the 1/8 will be a LOT easier from the outside. If you take a centre punch or something with a sharp point and give it a whack (not too hard) where you want the hole to be, the 1/8 bit will catch that and stay centred when you start to drill ... use a variable speed drill and start slowly and once the bit starts cutting you can pick up the speed (if drilling from the outside) just my $0.05 Right on SilvrT. I started from the outside. I used a 1/8 inch drill bit as a starter hole then enlarged it with a 7/32 inch bit, without going all the way through. Just enough to make a crater in the housing that allowed the 5/8 inch bit to fit more securely into the starter hole without sailing across the surface. BTW, the housing is not 100% plastic but it is some type of plastic/metal composite. At least the shavings felt like there was some metal in it. Slow steady pressure should have the hole completed in a couple of minutes. Another BTW for Cougar--I looked for yellow but the only colors they had at Radio Shack were red and green. My light has an orange hue because of the yellow/red mix of the turn signal and the marker lens.
Guest human4m Posted February 18, 2010 #15 Posted February 18, 2010 (edited) There's another option available... being a musician, the idea struck me when I read this post. Try using a jewel from a Fender amplifier. Readily available at your local axe shop, or online here: http://www.guitarnucleus.com/gnstore/ampparts.html for $2.99 They transmit light a bit better than the RadioSplat jewel, and they come with a cool chrome accent... If you've got a few extra bucks in your pocket, order them from musician's friend, http://accessories.musiciansfriend.com/product/Fender-Amplifier-Jewel?sku=420518 they have a larger color selection. I plan on putting the blue dot in my tail light, (which I'm sure will result in lots of visits from the local boys in blue.) Edited February 18, 2010 by human4m
Cougar Posted February 18, 2010 #16 Posted February 18, 2010 Patrick, THANKS FOR THE TIP Ordering a couple tonight , is there any difference between the (2) places? same thing? And what size Diameter are they? Jeff HERE is my up-dated ver. if my lights. but gunna add Patrick's Idea to it. http://www.venturerider.org/forum/showthread.php?t=45100
Evan Posted February 19, 2010 #17 Posted February 19, 2010 Looks like a great mod. Almost makes me wish I had a 2nd gen.
spear Posted March 2, 2010 #18 Posted March 2, 2010 Evan said: Looks like a great mod. Almost makes me wish I had a 2nd gen. Dream on!
wngrr Posted March 29, 2010 #19 Posted March 29, 2010 Cougar said: Think I found it. It is 272-710 it looked like 277 to me on the pdf. http://www.radioshack.com/product/index.jsp?productId=2102795 Oops, still looking that one is RED we need Orange. Nope I guess it was red after reading some of there post Well, I'm getting older too, so we may both get it wrong! However, I think that, while the turn signal lens is amber and the new jewel lens is red, ambient light shining through the amber lens and the jewel may have an orange tint. At night, the jewels shine ruby red. One person said something about using a single LED light.. Looking into that as well. Jeff I used a 12 volt prewired LED and they work great. The one I used is made by Oznium... Ordered yellow and looks amber when lit. I drilled a 3/8 hole and filed to fit. Sealed the backside with silicone. http://www.oznium.com/prewired-superflux David
