sportssonny1968 Posted October 11, 2008 Share #1 Posted October 11, 2008 Now this is strange,just got back off a arkansas bike trip.Had all my camping gear on my bike about 40 pounds.When i take my hands off the handle bars it starts to shimmy bad,I mean bad.I unloaded my gear off the back of it and no shimmy.Most of the weight was on the passenger seat with very little on the luggage rack.If it shimmys with that little weight on the back i can just imagine what it would do with a passenger. I have 36 PSI in the front tires and 42 PSI in the rear tire.Also 7 PSI in each front fork. Any ideas on what could be causing the shimmy.Oh yes. it has stock Dunlop tires on it with plenty of rubber left. Link to comment Share on other sites More sharing options...
royalstarjac Posted October 11, 2008 Share #2 Posted October 11, 2008 Checked your steering head bearings lately? They might need tightening. Also, why are you running 7 psi in the front forks, that is the max recommended. Try running them around 2 psi and see if that helps. How much psi are you running in the rear shock? I usually run 20-25 in the rear and 2-3 in the front. Link to comment Share on other sites More sharing options...
sportssonny1968 Posted October 11, 2008 Author Share #3 Posted October 11, 2008 I am running about 35 PSI in the rear shock,I will adjust the front to about 2 PSI, I run 0 PSI for a year i guess i should have left it alone.Thanks for the advice. Link to comment Share on other sites More sharing options...
eddy1156 Posted October 11, 2008 Share #4 Posted October 11, 2008 I had the same problem, my front tire appeared to have plenty of rubber; however, I decided to change it out. Problem solved, no more shimmy. May not fix your shimmy but it did mine. Link to comment Share on other sites More sharing options...
jozipp Posted October 11, 2008 Share #5 Posted October 11, 2008 I had the same experience and after replacing both tires it was gone. I keep 0-2 psi in front shocks and 16-20 psi in rear mono. Keeping the bearings lubricated and torqued properly is smart maintenance. Link to comment Share on other sites More sharing options...
SaltyDawg Posted October 11, 2008 Share #6 Posted October 11, 2008 I highly doubt taking the weight off the rear would make a difference in the tires. I think it's the steering head bearings. Tighten them up. Link to comment Share on other sites More sharing options...
99silver Posted October 12, 2008 Share #7 Posted October 12, 2008 I highly doubt taking the weight off the rear would make a difference in the tires. I think it's the steering head bearings. Tighten them up. What he said !! Worked for me ! there should be a link here for that minor adjustment. Link to comment Share on other sites More sharing options...
RedRider Posted October 12, 2008 Share #8 Posted October 12, 2008 Roll forward slowly and lock the front brake. You will likely hear a clicking sound of the front bearings moveing back and forth. It is likely your steering head bearings being loose. Been there, done that. RR Link to comment Share on other sites More sharing options...
hillrider Posted October 12, 2008 Share #9 Posted October 12, 2008 In No. Georgia, on old 9 between Dalondega and Dawsonville, there are enough tar snakes to fill a rodeo. In the summer, the Venture (05) becomes downright unruly with front end wiggle. My V-Star is solid as a rock. Had tree different tires - tire pressure high and low - tightened head bearings. All to no avail. Either the tubes are just a little weak for the load, or the fork oil is low on one tube. Don't want to think about the fork oil aspect. Is there an easy way of checking the fork oil?? Link to comment Share on other sites More sharing options...
Marcarl Posted October 12, 2008 Share #10 Posted October 12, 2008 You might check for cupping on the front tire. Just run your hand over the outer side of the tread or use a light and you might find that the rubber is wearing more at the lead of the cut tread than it is at the trailing edge. Link to comment Share on other sites More sharing options...
Squidley Posted October 12, 2008 Share #11 Posted October 12, 2008 You might check for cupping on the front tire. Just run your hand over the outer side of the tread or use a light and you might find that the rubber is wearing more at the lead of the cut tread than it is at the trailing edge. Lots of good info from all here, but I'm on the same lines as Carl. I had an Avon on the rear of my '99 and there was reasonable tread left but it was starting to cup. Bike didn't handle for crap, replaced the tires...all gone. The pressures in the forks are another look see. I usually keep my rear at about 40 psi as I like a bit stiffer ride for performance. The fronts at about 4 or 5, it's all about how you want it to feel. I also agree with checking the steer head bearings. Loosen the top triple tree nut, which a 1 1/16" wrench will work I do believe, and tap the retaining nut under the chrome cover with a long punch clockwise and tighten the nut after it's snug, dont reef on it. Link to comment Share on other sites More sharing options...
Squeeze Posted October 13, 2008 Share #12 Posted October 13, 2008 Lots of good info from all here, but I'm on the same lines as Carl. I had an Avon on the rear of my '99 and there was reasonable tread left but it was starting to cup. Bike didn't handle for crap, replaced the tires...all gone. The pressures in the forks are another look see. I usually keep my rear at about 40 psi as I like a bit stiffer ride for performance. The fronts at about 4 or 5, it's all about how you want it to feel. I also agree with checking the steer head bearings. Loosen the top triple tree nut, which a 1 1/16" wrench will work I do believe, and tap the retaining nut under the chrome cover with a long punch clockwise and tighten the nut after it's snug, dont reef on it. And don't forget to open the Pinch Bolts on the lower Tripple Tree before working on the Lock Nut Link to comment Share on other sites More sharing options...
