- Past hour
Glad you did not go without your riding partner. lol It could have been a bonus ride to and from today and another ride next week. When it comes to remembering important dates like that, I always input them on my iPhone calendar. I love the iPhone calendar and it has saved me and reminded me several times over the years. Not that I've mentioned that, I just might upgrade my iPhone 13 to the upcoming new iPhone 17 by the end of the year. With your 'honey to do' list, you just made it happen. We all know this...A Happy Wife means A Happy Life.
I have a Deka AGM on my bike which I purchased for $94.00 Mar 8 2013 and it is still going strong 12 years later.
- Yesterday
It’s 9:30 am and I’m all dressed up and ready to ride to the Tomahawk Fall Ride in Tomahawk WI. I have to be there by noon and it’s almost a 2 hour ride. My riding partner is supposed to be here and he’s not. He is always on time or early so I’m thinking the worst. At 10 am I finally call him.. no answer! Then 5 minutes later he calls me back and I find out that the ride is next weekend!!! Now I’m doing honey do projects!😠😠😠😠
sleadhed started following Going to reseal my water pump:
So I noticed a spot the size of a 50 cent piece on the asphalt at work this week directly below the coolant drain hose. removed the side covers and coolant reservoir is well below the minimum. I know I have read posts on this forum of guys resealing their water pumps. I have sourced OEM parts $100+. So I guess I'll tackle this project in a couple of weeks. any thing I need to be looking for. hopefully the shaft will be in good condition. 70 RSV with 52K on the clock.
Good morning to all! Where is everybody this weekend? I may be able to ride over to the gym today. Ride safe.
- Last week
Thank you Paul. I'll check the for gas. I did notice the oil level was at the top of the sight glass.
Still puzzling about the yellow oil patch. If you are in the habit of filling the oil up near the top of the sight glass it tends to blow out the crankcase and back into the air intake, then out the tubes. If there's more oil in the crankcase than you thought and it smells like gasoline you may have a stuck carb float letting gas into the engine and down into the crank. A lot of the guys on this site and the owners manual says to shut the petcock off between runs to avoid that problem. Hopefully that's not what you have going on.
I got a new lock nut and finished installing the shock this morning. I took it out to the Yamaha shop for a new rear tire, and it rode great. Going to take a ride down the Natchez Trace with my bro in law next week. I'll share a report on that ride when we got home.
Carburetor float valve seat seal
Pop replied to Pop's topic in Venture and Venture Royale Tech Talk ('83 - '93)
Thanks for the info cimmer. -
Good morning to all! TGIF.
cimmer replied to Pop's topic in Venture and Venture Royale Tech Talk ('83 - '93)
The parts are available from Yamaha still. Here is a link to a site I use all the time to purchase my Yamaha parts. https://www.partshark.com/oemparts/a/yam/50042b41f8700209bc78980a/carburetor The parts you are looking for are listed as item numbers 37-40, but I think that item 37 includes the other 3 but I am not sure.. If you dont order from this site least you will have the Yamaha part numbers to order from someplace else. I have not tried to replace these parts yet so I can not tell you how difficult it is but check out the tech pages and search for carburetor rebuild and you should find some other information there. Good luck Rick F. -
The clear yellow oil is the new Yamalube shock oil. The black stuff is what drained out of the shock. Well over 125ml. The engine hadn't been running for a couple of days before I saw the oil on the shop floor.
Ok now where did that plastic cup of clean oil come from? Is that your new shock oil that you put into the shock, or is that the mystery oil that came from somewhere else on your bike? If that isn't new shock oil, then the first thing I would suspect is crankcase oil blowing out breather tubes that come out down near where the lower shock mount is. But I'm at a loss as to what caused it to leak out if you didn't run the engine when you washed the bike. But also, your profile says this is a 2010 RSV trike. Never seen one up close. Does the trike setup have any additional oil reservoirs down under? Happy belated birthday by the way!
WELLLLLLL..... It was NOT the shock. The shock was had plenty of oil in it and was not leaking. However, since I had it off, I changed the O ring and oil. I was putting it back on, got all 3 bolts in and could not find the lock nut for the 3rd bolt. 🤔 So, I didn't get it finished today. I'll get a new nut tonight and finish it the first thing in the morning. The other side of the equation is the problem. Where did you clear yellow oil come from that was under my bike after we washed it. I didn't start it to move it out to be washed or when I moved it back in the shop. Here are some pics of the oil and the frame I built to fix it. To say the oil was dirty is an understatement. Now I will keep an eye out for oil leaks.
song219 changed their profile photo
Pop started following Carburetor float valve seat seal
1987 Venture Royalle 13 DT. I have had issues with my carbs overflowing. I have taken them off to clean them. One of the carbs has a sticking float valve. The seat that the valve sits in has burrs inside that won't allow the valve to move smoothly. I have tried a few things to shave the inside without luck. I don't know how it got that way. It had been working before I took it apart. It is difficult to get anything straight down in there. I have a rebuild kit that has a replacement valve and seat. If I can't smooth it out how hard would it be to replace it? Are the correct caps available? How hard is it to dislodge the valve seat. Thanks!
Good morning to all riders out there. We've had 11 straight days with no rain and we can need some rain in our area. The good news...rain may be coming this afternoon and tonight for a change. Everybody have a great day.
@bpate4homeUp to this day, I am very appreciative of the weather app that we have today on our cellphone. No more guess work on weather and doppler radar is our best companion on every ride. Always ride safe.
I forgot to wear mine when riding yesterday. Would have been interesting. Got in 100 mi but dodging some rain drops.
Could the rear brake pads have grease on them?
I give up.
Share some pics when you can! Here's mine just now - dry 950 miles later. And if yours was low on shock fluid and was pogo sticking, you will be amazed at how much better the ride is when you get it fixed.
- Earlier
I got the shock off this afternoon. It took about 20 minutes to get it set in the vise and start draining it. I made the bracket to press it up to change the O ring but stopped for dinner. It looks like it will be an easy fix, but I didn't get the fork oil today so it will be Tuesday before I can reinstall it.
Brakes are not linked on Royal Star Ventures. May be a collapsed line somewhere. Start at the outlet of the master cylinder break that connection and press on the pedal, if fluid freely flows, reconnect and work your way down the line until you find a point where the flow is diminished, if you get to the bleeder valve on the caliper and do not find an issue, maybe the calipers are stuck or dirty to the point they will not move freely.
Hmmm.. I do know from experience that when replacing, or in your case rebuilding a master cylinder it can be a pain to get the juice to flow at first. With the master full and the brake line disconnected at the master, what happens when you pump the brake handle? I don't think the front / rear brakes are linked on the second gen...not sure though. If they were I'd wonder about the proportioning valve. Someone should chime in and confirm or deny that they're linked. It doesn't seem that it should be this difficult, but I've had similar situations. (Don't make sense) I feel your pain, but I think if you stick with it you'll find the answer. It sounds like (so far) you've been checking all the boxes.
I hooked my vacuum to the bleeder and took line loose at master cylinder, and it pulled a vacuum on my finger. It is open. I took MC off and went back in to make sure seals were correct, had a friend look also, they were correct. We fill the MC with fluid the best we could and filled the reservoir down to MC the best we could and connected lines. Still can not get a pedal. Tried reverse fill with a large tube like a syringe all while working the brake pedal. Tried reverse fill again. Still cannot get a pedal. I have now tied the brake pedal all the way down and will leave overnight. (old trick). I also beat and vibrated the brake lines from MC back to caliber especially where the line has high spots. If This does not help, I plan to take it to someone that is supposed to know. Has anybody else had this problem bleeding the venture?????
