- Past hour
Good morning to all. Great weather is in store for us here in SE Pa. Looking like ride days all week. Ride safe.
Our store had 3 sets. I now have 3 sets, come down this way and get one, I’ll even pay for the coffee and donuts.
- Today
Marcarl started following Allen sockets.
Just to be clear on this, the level in the sight glass is with the bike vertical, not leaning on the side stand. When I had my Venture and my Royal Star, I used a mechanics mirror with an extendable shaft, so I could see the sight glass while straddling the bike to hold it vertical. Alternately a 1-1/2" to 2" thick piece of wood under the side stand will hold it almost vertical, just be careful not to bump the bike or turn the handle bars, as it could cause the bike to fall over to the right side .
Oil level should be below the midpoint. If above that it was overfilled or gas is getting in the oil. Overfill equals mess due to oil expelled. Gas in oil can result in blown engine
N3FOL started following Allen sockets.
That is a great price! Kobalt tools are top notch and if I am not mistaken, Lowes has a lifetime warranty on their tools. I have a similar tool set just like that from Sears. They are a must have, if working on the RSV and SVTC.
- Yesterday
Good morning to all and Happy Sunday. Hope you guys are having a great weekend. Sunny on this end and will cut the grass this afternoon. Enjoy your day.
Glad you did not go without your riding partner. lol It could have been a bonus ride to and from today and another ride next week. When it comes to remembering important dates like that, I always input them on my iPhone calendar. I love the iPhone calendar and it has saved me and reminded me several times over the years. Not that I've mentioned that, I just might upgrade my iPhone 13 to the upcoming new iPhone 17 by the end of the year. With your 'honey to do' list, you just made it happen. We all know this...A Happy Wife means A Happy Life.
I have a Deka AGM on my bike which I purchased for $94.00 Mar 8 2013 and it is still going strong 12 years later.
- Last week
It’s 9:30 am and I’m all dressed up and ready to ride to the Tomahawk Fall Ride in Tomahawk WI. I have to be there by noon and it’s almost a 2 hour ride. My riding partner is supposed to be here and he’s not. He is always on time or early so I’m thinking the worst. At 10 am I finally call him.. no answer! Then 5 minutes later he calls me back and I find out that the ride is next weekend!!! Now I’m doing honey do projects!😠😠😠😠
sleadhed started following Going to reseal my water pump:
So I noticed a spot the size of a 50 cent piece on the asphalt at work this week directly below the coolant drain hose. removed the side covers and coolant reservoir is well below the minimum. I know I have read posts on this forum of guys resealing their water pumps. I have sourced OEM parts $100+. So I guess I'll tackle this project in a couple of weeks. any thing I need to be looking for. hopefully the shaft will be in good condition. 70 RSV with 52K on the clock.
Good morning to all! Where is everybody this weekend? I may be able to ride over to the gym today. Ride safe.
Thank you Paul. I'll check the for gas. I did notice the oil level was at the top of the sight glass.
Still puzzling about the yellow oil patch. If you are in the habit of filling the oil up near the top of the sight glass it tends to blow out the crankcase and back into the air intake, then out the tubes. If there's more oil in the crankcase than you thought and it smells like gasoline you may have a stuck carb float letting gas into the engine and down into the crank. A lot of the guys on this site and the owners manual says to shut the petcock off between runs to avoid that problem. Hopefully that's not what you have going on.
I got a new lock nut and finished installing the shock this morning. I took it out to the Yamaha shop for a new rear tire, and it rode great. Going to take a ride down the Natchez Trace with my bro in law next week. I'll share a report on that ride when we got home.
Carburetor float valve seat seal
Pop replied to Pop's topic in Venture and Venture Royale Tech Talk ('83 - '93)
Thanks for the info cimmer. -
Good morning to all! TGIF.
cimmer replied to Pop's topic in Venture and Venture Royale Tech Talk ('83 - '93)
The parts are available from Yamaha still. Here is a link to a site I use all the time to purchase my Yamaha parts. https://www.partshark.com/oemparts/a/yam/50042b41f8700209bc78980a/carburetor The parts you are looking for are listed as item numbers 37-40, but I think that item 37 includes the other 3 but I am not sure.. If you dont order from this site least you will have the Yamaha part numbers to order from someplace else. I have not tried to replace these parts yet so I can not tell you how difficult it is but check out the tech pages and search for carburetor rebuild and you should find some other information there. Good luck Rick F. -
The clear yellow oil is the new Yamalube shock oil. The black stuff is what drained out of the shock. Well over 125ml. The engine hadn't been running for a couple of days before I saw the oil on the shop floor.
Ok now where did that plastic cup of clean oil come from? Is that your new shock oil that you put into the shock, or is that the mystery oil that came from somewhere else on your bike? If that isn't new shock oil, then the first thing I would suspect is crankcase oil blowing out breather tubes that come out down near where the lower shock mount is. But I'm at a loss as to what caused it to leak out if you didn't run the engine when you washed the bike. But also, your profile says this is a 2010 RSV trike. Never seen one up close. Does the trike setup have any additional oil reservoirs down under? Happy belated birthday by the way!
WELLLLLLL..... It was NOT the shock. The shock was had plenty of oil in it and was not leaking. However, since I had it off, I changed the O ring and oil. I was putting it back on, got all 3 bolts in and could not find the lock nut for the 3rd bolt. 🤔 So, I didn't get it finished today. I'll get a new nut tonight and finish it the first thing in the morning. The other side of the equation is the problem. Where did you clear yellow oil come from that was under my bike after we washed it. I didn't start it to move it out to be washed or when I moved it back in the shop. Here are some pics of the oil and the frame I built to fix it. To say the oil was dirty is an understatement. Now I will keep an eye out for oil leaks.
song219 changed their profile photo
Pop started following Carburetor float valve seat seal
1987 Venture Royalle 13 DT. I have had issues with my carbs overflowing. I have taken them off to clean them. One of the carbs has a sticking float valve. The seat that the valve sits in has burrs inside that won't allow the valve to move smoothly. I have tried a few things to shave the inside without luck. I don't know how it got that way. It had been working before I took it apart. It is difficult to get anything straight down in there. I have a rebuild kit that has a replacement valve and seat. If I can't smooth it out how hard would it be to replace it? Are the correct caps available? How hard is it to dislodge the valve seat. Thanks!
Good morning to all riders out there. We've had 11 straight days with no rain and we can need some rain in our area. The good news...rain may be coming this afternoon and tonight for a change. Everybody have a great day.
@bpate4homeUp to this day, I am very appreciative of the weather app that we have today on our cellphone. No more guess work on weather and doppler radar is our best companion on every ride. Always ride safe.
