This stream auto-updates
  1. Yesterday
  2. How much for just the saddlebags?
  3. Good morning to all! Glad I was able to cut the grass yesterday. Off to church then washing the truck later this afternoon. Enjoy your day.
  4. I had one hydro lock but fortunately the piston with fuel must have been at TDC so no clunk and no damage, Took the plugs out and it sprayed fuel all over when it turned it over,
  5. Last week
  6. I think it depends if another cylinder fired with that one going up on compression stroke, that’s the big clunk. They’ll sometimes run for a little while until the bent rod lets go, often opening an inspection hole in the block.
  7. Hydrolock was the first thing that came to my mind. Doesn't that usually bend a rod instantly?
  8. Sorry to hear about your brother, my condolences. I will be here when you want to talk about lighting.
  9. I have used your harnesses before; they are awesome! Was struggling with what I thought was a harness problem recently; turned out to be the stator, but your relays and harnesses are installed on this trike. Considering talking to you about more lights; will start a new thread about it. My brother died an hour ago; I'm a bit preoccupied right now.
  10. If you’re anywhere near west Ky I’m trying to clear all of this out of my shop. $400 for it all. Chrome forks, both fenders, saddlebags, trunk, fairing.
  11. I build light bars for Ventures, you could attach one to the cargo tray if you wanted to, it will give you tail lights, brake lights and turn signals. In this photo it is mounted under my trunk. Completely plug and play.
  12. Hey Everyone! I have been in and out of this forum for a long time. I have had a 09 Venture that I bought from my Dad when he had a mini stroke and couldn’t balance the bike anymore but i was working on his bike long before it was mine. I had dropped the bike a few times when I first got it and damaged the left saddlebag. I had originally fixed it with some hot staples and that worked well enough to keep stuff inside of the saddlebag. I dropped it again about a year after that and that same spot broke again. I wasn’t able to fix it because I was missing pieces of plastic. I had a lot of stuff going on for a while so I put off buying a new one. I am looking at the saddlebags out there for the bike and they are more expensive than they were when I first looked at them a few years ago. Is there any good places to buy cheaper saddlebags and plastics for the bike. I was also thinking about 3D printing my own if I can find someone with a printer that would print one if I supplied the materials. Thank you to all of you who have posted in the tech forums for your help over the years. I have been able to fix a lot of problems by referring to your conversations and insight!
  13. @sleepy2 My thoughts and prayers to you and your nephew's family and close friends. My your nephew rest in peace. Not surprised about the price of anti-freeze from a moto dealer. The next time I do my anti-freeze, I am simply sticking with Prestone which I seem to have no problems with. Take your time and enjoy the install. The fruits of your labor will show in no time. Got called in to work once again, but at least I was able to ride and take advantage of the nice weather we are having.
  14. Haven't had much time this past week as Nephew passed away from liver and pancreas problems he had been battling for a few years, he did pass peacefully though! Was able to pick up some Antefreeze the other day(boy has it gone up)from dealer! One had it at $20 per liter and other was $13 per liter (Ipone) Have all cooling drains tightened up and am ready to fill with Antifreeze but will triple check everything first. Also ready to install new Voltage Regulator, oil filter then fill with oil.
  15. Pull the plugs and see if it’ll turn. Check the oil to see if it’s full of gas to Rule out a hydrolock situation.
  16. I ordered an Air Filter for my SVTC, but I got the wrong air filter. This is what they sent me (see pic) and it will have to go back as a return. The one I got is way too big. Would anyone know the exact part number of the air filter for the 2018 SVTC?
  17. Looking for set up for little cargo attachment for tow ball. With cargo it blocks rear lights and tag
  18. Good morning to all! TGIF. Weather is great here in SE Pa. Have been riding for the last 2 days after all the rain last weekend. Cutting the grass today and I just might have enough daylight to wash the truck. Enjoy your Friday.
  19. I own a 2009 Royal Star Tour Deluxe S. It is a weekend rider for short trip and only has 7500 miles on it. It has been meticulously maintained and I've never had an ounce of trouble with it. I recently experienced a starting issue where I heard a loud "clunk" like metal hitting metal when attempting to start and then the motor would not turn. The solenoid would click, but the engine did not turn. I thought my battery had lost charge, so I put it on the charger overnight. The next day, she started fine. After a handful of rides, the issue repeated itself. Again, thinking my battery was low, I put it on the charger and it started fine the next time. Unfortunately, it happened a third time and the solenoid clicks, but the motor will not turn even after a battery charge. I had the battery load tested and it passed with no issues. I replaced the solenoid, but that did not help. After reading through a few posts, I am thinking it might be my starter clutch. Perhaps something has broken internally and not allowing the motor to turn? I would like some advice on how I could diagnose the root cause to ensure I am fixing the right problem. If it is the starter clutch, is it a repair that I can do myself and are there any available instructions? Thanks in advance for your help!
  20. I was in the Army from 67 to 70 when we had a half million GIs in Viet Nam. Fortunately for me, I was sent to S. Korea. But, a friend died over there, my first cousin was shot in the abdomen but survived and another friend came home with a creased helmet that was shot off his head. Almost everybody my age, 82, knows someone who died over there. I am a student of history and the heroes who sacrificed themselves in WWI and WW2, the Korean war and all the others are owed a tremendous debt. If anyone would like to know more about the war in the Pacific during WWII, watch Battle 360 on youtube. It's a series of programs mostly following the Aircraft carrier Enterprise, the only carrier we had that survived the entire war. It's an amazing story.
  21. Amen. We owe them more.
  22. I used AI to generate this image. The message is something I posted in 2024 after a friend called. He lost his son to suicide because of PTSD. Please feel free to take, share and use it however you like. I believe it's an important message to get across. I've seen several posts this year from friends and family that have lost people they love to this unseen ghost.
  23. I remember when I bought my TriGlide and rode it home it had gotten dusty dark and started a light rain before I got home I could not find the right switch for anything. The next day I went out and just sit on that bike and look at the location of the different switches. That may have played into the reason I went and got my RSV back. But both of those bikes are gone now.
  24. Dog gone it, I hope you and your small dog are okay and we get to see ya in Asheville
  25. Earlier
  26. We have rain this weekend and maybe all of next week here in the Bluegrass State.
  27. Asheville is only about 80 miles from me. If I can make it work out, I'll ride up for at least a day visit. I've had some rotator cuff surgeries on both shoulders. Thought I was doing well until 2 weeks ago when I dislocated my left shoulder saving my small dog from the neighbor's pitbull's jaws. My dog survived with some punctures and muscle damage. My shoulder MRI is this Wednesday, May 27th. Hopefully, I won't have any residual damage.
  28. I have no need for lit up switches on my RSV MM or my VR. But last year, a 78 year old friend gifted me his '02 Goldwing. At least for my needs, it could really use some (at least dim) switch illumination. I think Honda added illumination from 2004 or newer.
  1. Load more activity
