Freebird Posted August 23, 2017 Share #1 Posted August 23, 2017 I am going to buy a speedo calibrator for my '05 Midnight. I had a Speedohealer on the '99 and it worked great but the SpeedoDRD is about $30.00 or so cheaper. Anybody have any real experience with both? I like having it read right....just in case I ever get time to ride it again. Link to comment Share on other sites More sharing options...
eagleeye Posted August 24, 2017 Share #2 Posted August 24, 2017 I put a speedoDRD on my 650 vstrom this past spring, and it works great and easily adjusted to whatever setting you want, and I have a speedohealer on the RSTD and it also works great. I think I'd go with the DRD-so simple to set it exactly where you want it, in terms of setting the odometer and speedometer. Set it, go out for a ride and come back and adjust another tenth of a mile. Link to comment Share on other sites More sharing options...
BratmanXj Posted August 24, 2017 Share #3 Posted August 24, 2017 Well good timing...I was looking at the healer over the weekend but didn't pull the trigger yet. I assume the 2005-2014 listed on the 12oclocklabs.com website is the same for a '99-2004 since these bikes went virtually unchanged? Link to comment Share on other sites More sharing options...
bongobobny Posted August 24, 2017 Share #4 Posted August 24, 2017 I'm interested too! I use my GPS as a speedometer due to a big error caused by going to bigger tires on my trike... Link to comment Share on other sites More sharing options...
videoarizona Posted August 24, 2017 Share #5 Posted August 24, 2017 (edited) I've run the 12 O'Clock Labs SpeedoDRD's on 3 scoots now....and can say it's perfect. It's tiny, plug N play, very easy to calibrate and works. It's adjustability can get you down to as accurate as you want to be. Plus, I've heard Motomummy's warrantee service is excellent. It's now running on my 05RSV. Very pleased.... Model Y1. I mounted mine under the seat where the speedo connector is... Believe it's on sale now as well.... https://www.motomummy.com/chain-kits-with-steel-front-and-rear-sprocket/12-oclocklabs-speedodrd/?gclid=CIWaoIXx0rUCFYtU4Aod0G4ADg Edited August 24, 2017 by videoarizona add Link to comment Share on other sites More sharing options...
MikeWa Posted August 24, 2017 Share #6 Posted August 24, 2017 OK this has been irritating me for some time now. So I pulled the trigger and ordered the SpeedoDRD. Mike Link to comment Share on other sites More sharing options...
Kirby Posted August 24, 2017 Share #7 Posted August 24, 2017 Been running the Speedohealer for several years now, works great. After reading other's comments , I may have to try out the Drd next time. Sounds simpler to set up. Link to comment Share on other sites More sharing options...
Condor Posted August 24, 2017 Share #8 Posted August 24, 2017 OK watched the Video about the setting and all the posts. I'm still in the dark about how this thing is mounted between the sensor and the speedo?? Does it have a housing?? And... does it correct the odo as well?? Behold the real mpg's!!.... :-) I guess you'd need a GPS to figure out how far off the original mph percentage the speedo actually is??? Link to comment Share on other sites More sharing options...
Freebird Posted August 24, 2017 Author Share #9 Posted August 24, 2017 I've run the 12 O'Clock Labs SpeedoDRD's on 3 scoots now....and can say it's perfect. It's tiny, plug N play, very easy to calibrate and works. It's adjustability can get you down to as accurate as you want to be. Plus, I've heard Motomummy's warrantee service is excellent. It's now running on my 05RSV. Very pleased.... Model Y1. I mounted mine under the seat where the speedo connector is... Believe it's on sale now as well.... https://www.motomummy.com/chain-kits-with-steel-front-and-rear-sprocket/12-oclocklabs-speedodrd/?gclid=CIWaoIXx0rUCFYtU4Aod0G4ADg OK...that pushed me over the edge. $70.00 with free shipping is good enough for me to give it a try. Just placed my order. I ordered the Y1....I assume that is correct. Link to comment Share on other sites More sharing options...
videoarizona Posted August 24, 2017 Share #10 Posted August 24, 2017 OK...that pushed me over the edge. $70.00 with free shipping is good enough for me to give it a try. Just placed my order. I ordered the Y1....I assume that is correct. Should be...it's what's on my 05rsv....grins... Link to comment Share on other sites More sharing options...
videoarizona Posted August 24, 2017 Share #11 Posted August 24, 2017 OK watched the Video about the setting and all the posts. I'm still in the dark about how this thing is mounted between the sensor and the speedo?? Does it have a housing?? And... does it correct the odo as well?? Behold the real mpg's!!.... :-) I guess you'd need a GPS to figure out how far off the original mph percentage the speedo actually is??? 1: Mounted between the sensor and the speedo. Unplug the connector, plug in the DRD and done. Sorry I'm 150 miles away from my scoot otherwise I would take a picture... 2: No housing. It's protected by a shrink wrap stuff....very well done. 3: assume so since my mpg's have gone down now that my speedo is correct. 4: No you don't. You can do the math. On the web site you can clink on a link that takes you to the adjustment page. Either enter the gear ratios, etc., or enter the gps/speedo speeds and it will calculate for you and give you a % of correction. It's all explained on the web link I sent... Link to comment Share on other sites More sharing options...
Freebird Posted August 25, 2017 Author Share #12 Posted August 25, 2017 The GPS method would certainly be the easiest and perhaps best way to do it. If you don't have a GPS though, there are numerous free speedometer apps that you can download for most any smart phone. It would be nice if you could calibrate the odometer and speedometer separately but since only one signal is sent from the speedometer sensor, that is not possible. They explain that on their website. You have to choose if you want the speedometer or the odometer to be dead on or if you would rather choose a compromise somewhere in between. I personally want my speedometer to be dead on. Link to comment Share on other sites More sharing options...
Kirby Posted August 25, 2017 Share #13 Posted August 25, 2017 I generally add back the percentage of correction to get thempgs. Link to comment Share on other sites More sharing options...
Freebird Posted August 25, 2017 Author Share #14 Posted August 25, 2017 That works but if I remember right, the odometer is off also, just not as much. I don't remember but I'm thinking that it was off like 3 or 4 percent. So you wouldn't add it all back. Link to comment Share on other sites More sharing options...
BratmanXj Posted August 25, 2017 Share #15 Posted August 25, 2017 I assume the 2005-2014 listed on the 12oclocklabs.com website is the same for a '99-2004 since these bikes went virtually unchanged? SpedoHealer shows the same part number from '96 - '13...so bit the bullet and buy the SpedoDRD Y1 for my '99. Link to comment Share on other sites More sharing options...
eagleeye Posted August 25, 2017 Share #16 Posted August 25, 2017 Took a trip out west earlier this summer on the Vstrom and having the DRD adjusted to where I wanted it, 50 and below spot on and 60+, the speedometer was 1 mph slow, and at 75+ the speedometer was 2 mph slow. I kept track with my GPS and of course speedo. Odometer showed .988% less on the speedo. I checked it at fill ups and at the end of my trip. 4,481 miles I wanted the speedo to be on at those 25-35-45 mph zones and read a bit low at highway speeds. Link to comment Share on other sites More sharing options...
TDbiker Posted September 1, 2017 Share #17 Posted September 1, 2017 (edited) 1: Mounted between the sensor and the speedo. Unplug the connector, plug in the DRD and done. Sorry I'm 150 miles away from my scoot otherwise I would take a picture... 2: No housing. It's protected by a shrink wrap stuff....very well done. 3: assume so since my mpg's have gone down now that my speedo is correct. 4: No you don't. You can do the math. On the web site you can clink on a link that takes you to the adjustment page. Either enter the gear ratios, etc., or enter the gps/speedo speeds and it will calculate for you and give you a % of correction. It's all explained on the web link I sent... I also ordered a SpeedoDRD (received it yesterday). Before I go hunting for it, can someone tell me where to look for the speed sensor connector? I'm guessing it's either under the seat somewhere, or maybe behind the left side cover. Thanks in advance. Oh, and it's an '05 RSTD... Edited September 1, 2017 by TDbiker include bike year & model Link to comment Share on other sites More sharing options...
eagleeye Posted September 1, 2017 Share #18 Posted September 1, 2017 I also ordered a SpeedoDRD (received it yesterday). Before I go hunting for it, can someone tell me where to look for the speed sensor connector? I'm guessing it's either under the seat somewhere, or maybe behind the left side cover. Thanks in advance. Oh, and it's an '05 RSTD... Yep Link to comment Share on other sites More sharing options...
Sergeant Sooner Posted September 1, 2017 Share #19 Posted September 1, 2017 I have the SpeedoDRD, works perfect, easy to install and adjust. Just my 2 cents. - Gary Link to comment Share on other sites More sharing options...
Freebird Posted September 1, 2017 Author Share #20 Posted September 1, 2017 Mine was delivered yesterday. Hopefully, will find time to install it this weekend. Link to comment Share on other sites More sharing options...
bongobobny Posted September 1, 2017 Share #21 Posted September 1, 2017 Don't forget to take pictures! Link to comment Share on other sites More sharing options...
videoarizona Posted September 2, 2017 Share #22 Posted September 2, 2017 Mine was delivered yesterday. Hopefully, will find time to install it this weekend. And if you would, Don, please let us know what your correction ended up being, rear tire size, etc... It might be good to keep track of this to see if the speedo's are accurate (in their own way)! Link to comment Share on other sites More sharing options...
TDbiker Posted September 4, 2017 Share #23 Posted September 4, 2017 And if you would, Don, please let us know what your correction ended up being, rear tire size, etc... It might be good to keep track of this to see if the speedo's are accurate (in their own way)! I installed mine yesterday. I don't have any product comparisons, but I have to admit the installation and programming couldn't have been any easier. Took a ride before starting to get my baseline readings using a GPS. Plugged the numbers into their calculator on the website to get my correction value. Installed and programmed the unit and took another ride to check the readings. They appeared to be dead-on. My correction value is -8.3. Now my only concern is, after riding this bike for 8 years without correction, that I now remember the speedo is accurate... Link to comment Share on other sites More sharing options...
Freebird Posted September 4, 2017 Author Share #24 Posted September 4, 2017 Well, that tells us that the error is not consistent between bikes. I haven't installed mine yet but did check the error yesterday on our ride. I checked it multiple times and made sure that my speed was stabilized each time. I set the bike's speed at 60 MPH and my Garmin GPS showed that I was actually running 56 MPH. That means that my error is -6.7%. This is on my 2005 RSV. I don't remember exactly but I know that my '99 was somewhere around 8%. This means that each person is going to have to figure the error on their particular bike. Something else that could affect this to a small extent is different tires. Not all tires are the same OD. I'm running Dunlop E3's right now. Link to comment Share on other sites More sharing options...
videoarizona Posted September 4, 2017 Share #25 Posted September 4, 2017 Well, that tells us that the error is not consistent between bikes. I haven't installed mine yet but did check the error yesterday on our ride. I checked it multiple times and made sure that my speed was stabilized each time. I set the bike's speed at 60 MPH and my Garmin GPS showed that I was actually running 56 MPH. That means that my error is -6.7%. This is on my 2005 RSV. I don't remember exactly but I know that my '99 was somewhere around 8%. This means that each person is going to have to figure the error on their particular bike. Something else that could affect this to a small extent is different tires. Not all tires are the same OD. I'm running Dunlop E3's right now. Agreed. Tires would be a factor. As well as mileage on the tires. I'm running stock size Pirelli Routes. I was hoping we can get a reasonable consensus on error. Be interesting what others say. I may check mine this week and see where I'm at on my 05 RSV. Link to comment Share on other sites More sharing options...
