VerntureVet Posted October 6, 2015 Posted October 6, 2015 So Please clear this debate up for Me Vs Another VR owner. The service manual states to add oil run engine then turn it off and check that the oil is between the MIN Max lines in the sight glass. So when I changed my oil I did just that. When the engine is running the pump draws up some of the oil and in the Sight Glass I am just @ the MIN level. Another VR owner was checking out my hack job and tells me that it should be @ MAX when its running. So check the level when running or when not running?
sldunker Posted October 6, 2015 Posted October 6, 2015 Not running. A lot of the oil is circulating inside of the engine when running.
Flyinfool Posted October 6, 2015 Posted October 6, 2015 The oil level should be at or slightly below half on the glass. IF you fill it to the max line you will get oil sucked up into the air cleaner box that will then make a mess. When doing a change, start the engine and let it warm up a bit to be sure all of the air in the oil lines are purged of air, shut it off and wait a good 15 minutes for the oil to drain back down from the top of the engine, now check your oil level with the bike level. I check mine on the center stand. When running, on the center stand, I have no visible oil in the sight glass. On the side stand there is never any visible oil in the sight glass.
eusa1 Posted October 6, 2015 Posted October 6, 2015 I have never seen a combustion engine that requires you to check oil level while its running? most automotive transmission fluid levels are checked while running. as stated above: engine off, engine level, just below center of window is perfect.
stanG Posted October 6, 2015 Posted October 6, 2015 There has also been discussion on this via this thread and the position of the bike when checking... whether on stand or not. http://www.venturerider.org/forum/showthread.php?106183-Oil-Warning-Light&highlight=sight+glass
Great White Posted October 6, 2015 Posted October 6, 2015 (edited) I do what the manual says. Never any issues. manual seems pretty clear to me..... Edited October 6, 2015 by Great White
VerntureVet Posted October 6, 2015 Author Posted October 6, 2015 Roger that when I changed the oil I was on level ground on my center stand. I added enough oil to just see it in the bottom of the sight glass then started the engine let it run a bit and turned it off. once everything settled down I topped it off to just below the top (max) line. I trusted the manual. This guy was very adamant that I was going to blow my motor from too little oil to the point he offered to buy me a quart to top it off. lol.
Karaboo Posted October 6, 2015 Posted October 6, 2015 I'll bet that other guy's air box is one sticky mess if he does what he asked you to do.
vzuden Posted October 7, 2015 Posted October 7, 2015 I'll bet that other guy's air box is one sticky mess if he does what he asked you to do. Yes and will run down the sides of the carbs too. Been there!
djh3 Posted October 7, 2015 Posted October 7, 2015 If its a second gen no center stand. Most folks I know have said they use a piece of 2x4 under the side stand. Thats pretty close to level.
